2006 compaq charger tip broke, now I only have wires, the new adapter has prongs, what do I do
  • 805 Answers
Need to Repair or change it immediately.
Posted on Nov 05, 2012
2 Suggested Answers
frankzjm
  • 191 Answers
SOURCE: connecting laptop tip to auto adapter
you may look the jack(tip) show here:
1ecfef4.jpg 1) your car adapter, the red color wire is + pole which connect to the hole of jack(tip), the black wire is - pole which connet to outcover metal of the jack(tip). that is very common.
2) your new jack: check as smae as above. usually white color connect to red color, and black to black is ground connect to outcover of tip.
then you need check again the voltage pole, the tip 's hole should be possitive "+" and the outcover metal is negative "-" pole, it is very important.
hope help you fix it, please feedback any question any time, pleaae take a rating let me know how much helped you thanks!
Posted on May 28, 2009
Electric Mobility: Replacement scooter charger
Rob, If need be, possible you can adapt you old chargers connector onto new charger if not the same plug. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
24 Volt 4 0 Amp On Board Battery Charger for Rascal Scooters and Power...
RASCAL 600 600t HANDICAP MOBILITY SCOOTER PRISM 24V BATTERY CHARGER...
Aug 17, 2016 | Electric Health & Beauty
Ac adapter broke
Buy a RIM Blackberry Rapid Charger. It uses another connection:the one with the three magnetic contacts.
It was about $10 on amazon today. And it charges fast.
Feb 24, 2013 | RIM Blackberry Ac Adapter 5 V Dc 1.80 A...
Replacing the OEM 18.5 V 3.5 A ac adapter with an 19V 4.74 A adapter for my c551nr compaq, should not give me problems, will it? It should be within spec, hopefully.
Specification of Compaq Presario C551NR AC Adapter:
Power: 65W
Output: DC18.5V 3.5A
DC Connecter (Barrel) :
Internal Diameter: 1.7mm
External Diameter: 4.8mm
But it's OK to use a 90w 19V 4.74A adapter on your laptop only if the connector tip fits your laptop.
Thefollowing three conditions should be met for you to use an ac adpater safely. 1)Output Voltage is within +/- 5% of your old charger's output.
For example, ifyour old charger provides 19.5V, then you can use a charger that provides 20.5Vor 18.5V.
2) Output Current is the same or higher than that of your old charger.
For example, ifyour original adapter provides 3.42 Amps, then you can use a charger thatprovides 3.42 Amps, 3.9 Amps or higher.
3) Connector tip must fit securely into your laptop.
Mar 29, 2011 | Compaq Presario C551NR Laptop Charger...
Asus netbook ac power cord adapter stopped working...no blue light on...not charging computer...what to do and need new one?
You need a replacement AC adapter, it's very cheap online.
Jul 15, 2010 | ASUS AC Adapter- Universal Notebook AC...
Hp compaq nc6320 doesnt charge
i thibk the charger head went out thats what happend to my gateway just cut the part of the charger that goes into the computer (if its not the prob u can fix it back later) cut it open and see if any of the wire has broke off if so use a soutering iron (i dont know how to sourtering)
and some souter and souter it back on thats the best i can help
ps i done this to my gateway labtop and it worked fine
Oct 02, 2009 | HP Compaq nc6320 Notebook
Have lost charger or the 2 prong adapter. Not sure as we have a 16 volt charger with single prong that may be for our light. Need to know what voltage required for the light to be sure.
According to the instruction manual for these swimming pool lights, the charger specifications are the following:
USA and CANADA: 14 VAC,1.5A UL/CSA-approved wall plug
adapter and charger
AUSTRALIA and NEW ZEALAND: 240VAC 50Hz/14VAC 1.5A wall
plug adapter and charger
EU: 220-240VAC 50Hz/14VAC 1.5A CE-approved wall plug
adapter and charger
SOUTH AFRICA: 220-240VAC 50Hz/14VAC 1.5A wall plug
adapter and charger
UK: 240VAC 50Hz/14VAC 1.5A CE-approved wall plug adapter
and charger
Aug 13, 2009 | NRS CANTAR GLOW BUOY FLOATING POOL LIGHT...
Canon CA-590 compact power adapter
have that adapter tested, found defective diode sb260 near dc output, however after replacing different specs of diode it powered up then diode was busted again.
Nov 19, 2008 | Canon CA-590 Compact Power Adapter...
Computers & Internet Logo
29 people viewed this question
David Payne
David Payne
