Question about Panasonic TC-P42X1 41.6 in. Plasma HDTV
Panasonic TC-42PX14 wont turn on power light flashes 1 time
Bought the tv with this problem. Power supply relays click when power button pressed. Tv attempts to start. Green led lights on SC board. There is 5v standby power on power supply. HDMI 2 input pins were shorted on A board. I straightened the pins and the tv turned on with good picture and sound. Cycled power and now no start with the same symptoms.
  • Anonymous Mar 25, 2014
    I hit the power button and the tv will not power up. I replaced the 2 power supply boards and still no luck getting the tv to power up.
    Top Expert:
  • Panasonic Master
  • 14,553 Answers
You may want to shop for that board or at least consider removal of the HDMI socket in question---tested for shorts there I presume?
Posted on Nov 05, 2012
  • jmachalik
    jmachalik Nov 05, 2012
    Yes. I removed the damaged HDMI socket. Tested fro shorts and visually inspected the board, no signs of other damage. I did notice a SONY! chip that controls the HDMI ports. Iam assuming the chip was damaged when the pins shorted. I've located a refurbished board for $104. Everyone else was sold out of the A board for this tv. That must mean that it's either a common problem or they stopped manufacturing this board. I tried unplugging the ribbon cables one at a time on the A board but still no luck. This must be the problem with this set. Thanks for your reply. Jim.
2 Suggested Answers
SOURCE: Panasonic TH-50PE700U red light flashing 6 times
Replaced the sc board and tv works fine again.
Posted on Jan 22, 2009
I have a Panasonic PT-52LCX66 television that I bought just over 4 years ago. I have replaced the bulb for the second time just 3 months ago and now the set will just shut off after about 3 minutes of...
Tv making and have clicking sounds as tv shutdown as lights flashes?Yes.The board that call the Ballast board might be dying and dead soon.This Ballast board job responsible only are to ingnite the tv projection lamp only.
Jun 30, 2011 | Panasonic PT-52LCX66 Projection Television
My 42 inch tv wont turn on model nu 42pfl5603d/10
what you need is trouble shooting and a good digital tester to fix that problem. since the problem is power off start at the back light check if their is a small maldischarge at the module then check if their is a click on relay and then if the front LED is turn from red to green. then check the power supply if normal, check the low and high voltage except the stand by supply. then check the Y board the Va and Vs supply look for the blown fuse. and then the Z board check the 5v and Va supply, check also blown fuse.
Apr 28, 2011 | Philips Televison & Video
Hi I have a TH50PZ80U that is flashing two red lights when I plug it in. If i press the power button for 5 seconeds it will flash 10 times. When applying power the AC relays click, after pressing the...
Hi bschaub796,
10 times blinking of your unit indicated that the processor sense the missing 15v from the power supply. This problem is quite technical since I've already read your post that you have a reading of 15v in P25.
Now, we have to examined it deeply to determine where the fault came from between the two board.
If you have a 15v coming from the power supply but its go to 0v after a while which trigger the 10 blinks, you have to check the feedback circuitry of the power supply for faults. If you can't find any faulty parts on that section means that the feedback circuitry trigger to shutdown because it sense fault in the D board.
Remember that it has a good regulation output from the power supply, the issue here is the feedback circuitry that sense the fault. If you are going to ask my opinion I've suspected that the fault is in the D board.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Mar 17, 2011 | Televison & Video
Bought in Dubai 3 years ago Pan.Viera LCD 32"\r\nStandby light flashing red/green. Have to switch on with on/off button after a few minutes switches off itself..........then back on itself
Power LED Blinking timing chart
When an abnormality has occurred the unit, the protection circuit operates and reset to the stand by mode. At this time, the defective block can be identified by the number of blinks of the Power LED on the front panel of the unit.
blinking
1 dg board, (stv 5v sense time out)
2 d board
3 d board
4 p board
5 d board
6 su sd sc boards
7 su sd sc boards
8 ss board
9 panel config
10 digi board-
11 pb board
12 h board
13 dg board
Tom Miller
Broadcast Eng
Mar 04, 2011 | Panasonic VIERA TX-32LXD80 32 in. HD-Ready...
Panasonic TC-P42X1 41.6 in. Plasma HDTV Logo
641 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
