Question about Vivitar 100-400mm f/4.5-6.7 Series 1 Lens for Pentax AF
Will an auto focus Vivitar Series 1 100-400mm work on a nikon d80
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Vivitar Master
  • 102,366 Answers
Vivitar Series 1 lenses were available with a variety of lens mounts for different camera makes. If the lens has a Nikon mount then it will work on a Nikon D80. If it has some other mount then it will not fit.
Posted on Nov 05, 2012
3 Suggested Answers
cammedic
  • 667 Answers
SOURCE: New Vivitar 100-300 f?5.6-6.7
If your lens is like the one here:
http://www.slrgear.com/reviews/showproduct.php/product/329/cat/49
It should auto focus on your D40
Posted on Dec 27, 2007
FIXYA Benny
  • 165 Answers
SOURCE: I can not auto focus this lens on my Nikon D60
first check if you lens is compatible with the camera.
is your camera a digital or film camera?
this lense is designed for a film camera and is discontinued
Posted on May 04, 2009
D80 Digital Camera with 18-135mm Lens: My nikon d80 will not auto focus when I push the s...
The r11 is in the lower right of the top LCD or view finder that is in the D80 manual page 36 it speaks about the buffer. The r with a number is how many shots the buffer at that moment can handle. It is not an error message. For auto focus issue is the lens in AF as well as the camera?
May 17, 2010 | Nikon D80 Digital Camera with 18-135mm...
My D80 nikon camera was not working specially on
Check the following:
- Make sure your lens is screwed on correctly. Try to remove it and put it on again.
- Make sure the dial is squarely pointed to Auto
- Make sure the Auto-Focus switch in front of the camera is turned to A (not to M)
Dec 29, 2009 | Nikon D80 Digital Camera with 18-135mm...
D80 auto focus broken
AF lenses normally have a subtle grinding noise when used. Make sure your AF switch is turned on. If this still does not work, you may wanna consider bringing it in for repair
Dec 02, 2009 | Nikon D80 Digital Camera with 18-135mm...
My D80 will not auto focus with any of my 3 Nikkor lenses. It will fire on auto focus when you manually focus while in that auto focus mode.
Press the AF button on the top of the camera (to the right of the window) to select an AF mode & make sure the M/A (Manual / Auto focus) switch on the lens set to "A"
More info below:
http://www.kenrockwell.com/nikon/d80/af-settings.htm
Oct 05, 2009 | Nikon D80 Digital Camera with 18-135mm...
I can not auto focus this lens on my Nikon D60 I tried to do it as the write up but I need a manual or info Vivitar Series 1 28-300mm f/4.0-6.3
May 04, 2009 | Vivitar Series One 28-300mm f/4.0-6.3 Auto...
Auto focus at full zoom not responding Nikon D80 with 18-200mm VR
Hi - I own this lens and it manually focuses at all focal lengths (hard to see at 18mm unless your subject is extremly close). You may need to get the lens checked. BTW - Mine was set as follows when I checked for you:
  • D80 was "on"
  • M/A
  • VR = Off
  • Normal (not Active)
Hope this helps!
Apr 09, 2009 | Nikon 18-200mm f/3.5-5.6 G ED-IF AF-S VR...
Nikon D80. Vivitar 4600 Flash unit
That particular unit is probably not a good choice for the D80 because the trigger voltage (the electricity which flows from the flash through the camera circuits to fire the flash) is 19.5 volts, according to http://www.botzilla.com/photo/strobeVolts.html - this could possibly damage your camera electronics.
You don't have to stick with Nikon brand Speedlights, but get a modern flash which says it is I-TTL compatible for Nikon.
Jan 01, 2009 | Vivitar 850AF for Nikon TTL Flash
Quantaray lense
Yes, the Quantaray Autofocus lens will focus automatically on the D80.
Sep 27, 2008 | Quantaray 135-400mm f/4.5-5.6 for Nikon AF
Nikon D80 Autofocus problem
sir, replace ur lens image reading sensor
Apr 06, 2008 | Nikon D50 Digital Camera
Old vivitar lens to adapt to a new digital camera
The nikon d80 you pointed out is a solid good camera. Id suggest buying it, if you are sure your lenses fit, didnt bother to check But I know Nikon is the way to go!
Mar 28, 2008 | Cameras
Vivitar 100-400mm f/4.5-6.7 Series 1 Lens for Pentax AF Logo
112 people viewed this question
Top Vivitar Cameras Experts
SHARCNET-USA
SHARCNET-USA
James Woodgreaves
James Woodgreaves
Are you a Vivitar Camera Expert? Answer questions, earn points and help others
