Question about Ovens
My built in whirlpool oven has no power
New elec box installed in July. Used oven today for the 1st time since! Bakng went fine. When replacing pans back in the oven for storage I discovered oven had no power. I checked the breakers (dble) and they were not tripped. reset anyway, still no power. Odd that this happens the first time I use it after having the box replaced. Could it be a defective breaker? I have contacted the electrician by email, it is Sunday night and I expect he will call me tomorrow night. If not the breakers any other possibilities? I believe it was installed in 2002 or 2003. I purchased this home in 2009. Unit obviously not abused, etc., etc. I don't use it much but would like it to work certainly Thanks for any insight/help you can suggest. j
    Top Expert:
  • 9,472 Answers
What is the model number of the unit?
Posted on Nov 06, 2012
  • 4 more comments
  • Janelle MacLean Nov 06, 2012
    the model number is RBS245PDT16. I think it was installed in 2004. The electrician who installed the new breaker box will check the breaker hopefully sometime this week. Otherwise. . . .? Thank you for responding.
  • Richard Roth
    Richard Roth Nov 06, 2012
    OK, let me know what he finds. I will be here! :)
  • Janelle MacLean Nov 07, 2012
    I know it is not hard to test the breaker, and it would not be hard to test the plug for the oven but I cannot find it. Could it be possible that the hole unit would have to be pulled out?
  • Richard Roth
    Richard Roth Nov 07, 2012
    Yes, you would need to pull the unit out.
  • Janelle MacLean Nov 08, 2012
    OK, the breaker is fine, and the unit was pulled out and there is power to the unit. Now the fix is. . . .? The oven still looks new. I do not want to replace if possible.
  • Richard Roth
    Richard Roth Nov 08, 2012
    OK, if you have power to the unit and it will not come on, you will need to replace the control board. There are no other fuses or relays since they are built onto the control board. Here is the part to order. http://click.linksynergy.com/fs-bin/clic... The part comes with a 365 day, any part, any reason return policy.
Powerman
  • 68 Answers
SOURCE: Kenmore Gas oven is giving F8 error code
Unfortunately the F8 usually means an EEPROM data shift error. Try turning the power on and off several times. If error continues, you have no choice but to replace the ERC. Check on line for the best price. There is a group in the Chicago area that repairs ERCs. Check them out at www.cgiltd.com The failure of the your power system may have been associated with a surge either as the power went off or when it came back on. It may have been the surge that did the damage.
Posted on May 19, 2007
Krazytech
  • 725 Answers
SOURCE: Microwave not working
Hi your microwave is a total separate unit. first check to see it it is plugged into your oven. If it is then to check the fuse. You will have to remove the cover first unplug the microwave remove the screws from the back and side ...pull the cover to the back remove cover. there is a small board on the right side toward the back with a dark gray cartridge fuse. that is you main fuse. you can check it with an ohm meter to make sure it is blown... let me know what you find out?
Posted on Aug 26, 2007
revamos
  • 16 Answers
SOURCE: Whirlpool Oven Shutdown Fuse
you need a new fuse it is not resetable should use renches but be carful if not comfortable call service
Posted on Apr 19, 2008
  • 1891 Answers
SOURCE: Frigidaire ES200/300 316257123
look for a shorted bake element .. you should be able to see where it poped. ( some times ) if you have ohm meter you can ck for an open element . **** //
Posted on Dec 04, 2009
SOURCE: Frigidaire gallery stove, oven not working,
Morison,
The same thing happened to me about a week ago. I was preheating our electric oven, heard a very loud bang/pop. Checked and the oven had PF (power failure) I went downstairs and the breaker was tripped. Came back upstairs and to look at stove, the burners are working fine so I continued to preheat oven after a half an hour the oven was only slightly warm. Did you ever find out what was wrong?
Posted on Aug 07, 2010
No power on double oven after a storm
I have a RBD275PRS00 built in double oven. Had an electric
www.fixya.com/support/t8971528-rbd275prs00_built
Apr 16, 2011 - Had an electric storm the other night and ever since the oven won't -Whirlpool ... Question about Whirlpool RBD275PR Electric Double Oven ... For an oven to require parts after 2.5 yrs of service and 2 self cleanings tells me ... fiest press the on key see if the display comes if not the turn the power off for 5-8 ...
Whirlpool panel buzzing Ovens Questions & Answers - Fixya
www.fixya.com > Forum > Tags > panel buzzing > Ovens
Whirlpool ovens panel buzzing related questions and answers. ... the control panel on my Whirlpool electric double oven Model is RBD305PDS14? ... No power on control panel During self clean cycle the power to the panel went out. ... panel the instrument panel on an oven won't change time because of a storm problem.
Jan 01, 2016 | Whirlpool RBD275PR Electric Double Oven
What do I need to do to fix a blank screen on a whirlpool built in oven?
Often the Whirlpool built in ovens have a control board failure which causes the screen to go blank. May be intermittent and may be accompanied by an E6 F2 failure code on the display (before it blanks out). We rebuild a lot of control boards for this problem. For example see:
http://www.fixyourboard.com/boards/8302967.html
Mar 18, 2015 | Whirlpool Ovens
We have a double oven built in Model KEBC208Kss04.We had a power failure. When the power came back on we tried to set the clock but the "start?" appears in the window.. When you push start the clock goes...
Unfortunately this is a frequent result of a power failure. You should know that during power failure we often have also a voltage variation. This variation is burning out thousands of clocks - control board in many ovens, fridges e.t.a. usually is a partial damage on the clock-control board however there is not any solution but to replace it with a new one.
However in your case first in not an ordinary control of about $150-$200 but it is cost $407. In addition you have mention that the oven work normal so you should decide if you would live with it since the damage in only for the clock time or go on to replace it.
Here below we have a link with the parts layout of your oven in which you can also see the parts codes and the price of the control board and if you wand you can even order it.
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5133074&diagram_id=948876
Cntrl-elec
Part Number: AP3591485 made by WHIRLPOOL
Oct 10, 2010 | Ovens
I own a whirlpool double wall oven. The top is self cleaning but the bottom is not. I purchased this oven in early 2005. Today when I tried to use the self cleaning feature the entire oven went off but the...
Sounds Like the clock control unit may be bad, or the auto latch assy itself. I may have the part for you. What is the model number of the unit?
Sep 15, 2010 | Whirlpool Ovens
Our home has a Whirlpool Gold built-in convection oven. The home is @5 years old. We've lived here for one year. Today, the display had an error message (E6). After we cleared the error message, the...
Hello!
This blank display is a common control board problem. If the buttons beep when pressed, then the control board is getting adequate power. If the buttons beep.. and your oven light still turns on when the oven door is open.. this a text book control board failure. We at Fixyourboard.com can solve this problem for you, and back the remanufacture with a two year warranty.
GBD RBD Whirlpool Oven Problems Causes and Solutions
Apr 21, 2017 | Whirlpool GBD307PD Electric Double Oven
I used the oven at 425C for about 30 minutes, turned it off, took the food out, left the door open (the fan and light was on. During dinner, we smelled a strong chemical smell, like melting plastic or hot...
your mostlikley correct on the buring wires. The only thing that can be done at this point is to unplug the machine and start tearing in to it to find the bad wires.
Jan 08, 2010 | Whirlpool RBS275PD Electric Single Oven
Whirlpool 27" wall oven. no heat after self clean
Self cleaning features are not recommended by most appliance technicians. The ovens are not constructed satisfactorily to expel the 1000 degree heat, Therefore the thermal fuses blow as well as other parts failures.
Remove the oven. Remove the rear panel. Replace the thermal fuse in the back of the oven. Use Easy Off next time.
May 12, 2009 | Whirlpool RBS245PDS Electric Single Oven
Whirlpool electric oven problem
thermal fuse to board blows, relays turn fans off, the thermal cut out on rear of oven kills element. change both fuses, install new style oversized blower.
Sep 22, 2008 | Ovens
Whirlpool rbd275pdb double wall oven died during self clean
The first time we used our Whirlpool oven the same thing happened - no power and yet the circuit breaker was not blown. I called Whirlpool, and they sent out a technician to check it out as it was still under warranty. He said the temperature was off (too hot) by 20F - he adjusted. He also replaced the blower. What he did not tell me was that the thermal fuse had blown, and he replaced it - this was the REAL cause for the failure. I got the impression that he did not want to let me in on the secret. He did not note on the paperwork that he replaced the thermal fuse. Last week I decided to run the oven through the self-cleaning cycle (the oven is now 8-1/2 yrs old) - I don't believe that we cleaned the oven but a couple of times since the first time that it was "repaired." I used the default 3-1/2 hour setting. Everything appeared to be fine - the oven went through the cleaning cycle with no apparent problems. The display now read "cool down" - I went to bed thinking everything was okay. I got up the next morning only to find out that the power was out. I called Whirlpool and demanded that they repair the unit again as they clearly never fixed it correctly in the first place. They offered me 15% off on a new oven - WHOOPEE! I asked to speak with the supervisor - he did not budge either. I was upset, and I told him that I would NEVER purchase a Whirlpool appliance again! I decided to tear into the oven to see if I could detect anything wrong. I pulled out the front panel - everything looked okay. I then noticed the "thermal fuse" - I did not know what it was called at the time, but it looked familiar. I checked voltage on either side of the fuse and found the voltage to be zero on the downstream side of the fuse. I pulled it out and read the information on the device: Microtemp 110C. I called a local appliance repair shop - they told me that it would cost $50 to purchase a new fuse! I told them that seemed very high. I ended up stopping at Radio Shack. They have thermal fuses in various temperature and voltage ranges. I got a 144C 10A fuse and carefully soldered the connectors to it and replaced the protective plastic sleeve. I actually bypassed the thermal fuse in order to use the oven before I found the replacement fuse. While it is a good idea to have a protection device for the slim chance that an oven may malfunction by overheating, it is not a necessity for the functionality of the oven. Hopefully, the thermal fuse will not fail during my next attempt to self-clean the oven. I do have a concern about the 10 amp rating, but I'm sure that it will work fine.
Mar 22, 2008 | Whirlpool GBD307PDS Electric Double Oven
Digital Display
July 8, 2009
My display went completely dead. Been dead for a while. Just today I fixed it. You have to change a small capacitor, on display board labelled C3. Very hard to find the exact one which is, 35V - 68 microfarad, so I replaced it with 35V - 100 microfarad. Works just fine. You have to be handy, or find a friend that can do this, cause you will need to solder.
Anyways hope this helps. By the way the capacitor cost me 15 cents canadian.
Good Luck
Nov 17, 2007 | Jenn-Air JJW8230D Electric Double Oven
Ovens Logo
102 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
