Question about HTC Desire Cell Phone
You need a network connection to use this application. Pleas turn on moblile network or wi-fi in settings and they are on
3 Suggested Answers
bendjmiller
  • 109 Answers
SOURCE: "use phone data connection when
Do you have a 3g connection or are you trying to use a wireless connection when you attempt to connect? Have you ever been able to connect or is this the first time this has occurred?
Posted on Mar 02, 2011
adracamas
  • 344 Answers
SOURCE: I want to connect my
It is not possible to Ad-hock wifi across the two devices. They weren't intended or programmed for that use.
Posted on Mar 24, 2011
HOW TO CHANGE THE INTERNET SETTINGS IN THE HTC WILDFIRE A3333
Wi-Fi provides wireless Internet access over distances of up to 100 meters (00 feet).
To use Wi-Fi on your phone, you need access to a wireless access point or "hotspot". The availability
and range of the Wi-Fi signal depends on the number, infrastructure, and other objects
through which the signal passes.
Turning Wi-Fi on and connecting to a wireless network
From the Home screen, press MENU, and then tap Settings > Wireless & networks.
Select the Wi-Fi check box to turn Wi-Fi on. The phone then scans for available wireless
networks.
Tap Wi-Fi settings. The network names and security settings of detected Wi-Fi networks
are displayed in the Wi-Fi networks section.
If the wireless network you want to connect to is not in the list of detected networks,
scroll down the screen, and then tap Add Wi-Fi network. Enter the wireless network
settings, and then tap Save.
Tap the Wi-Fi network you want to connect to.
If you selected an open network, you will be automatically connected to the network.
If you selected a network that is secured with WEP, enter the key and then tap
Connect.
Depending on the network type and its security settings, you may also need to enter more information
or choose a security certificate.
When your phone is connected to a wireless network, the Wi-Fi icon appears in the
status bar and tells you the approximate signal strength (number of bands that light up).
The next time your phone connects to a previously accessed secured wireless network, you
will not be prompted to enter the key or other security information again, unless you reset
your phone to its factory default settings.
Jan 28, 2015 | HTC Wildfire A3333 Cell Phone
Tip
How to set up internet on Samsung Jet
Ensure that you have the appropriate network key code needed to enable you to access a secure Wi-Fi network.
If you are connecting to a secure Wi-Fi network with MAC address restrictions, you will require pre-authorisation for the router. You will need to find your Samsung Jet's MAC (Media Access Control) address. This is a 12-character code which may be needed by the network controller to enable the phone to connect. See Getting the Samsung Jet's MAC address below.
You can get to the Wi-Fi application either via the main menu or using a homescreen Wi-Fi Widget.
  1. To get to the Wi-Fi application via the main menu, press the MENU button (either on the home screen or the hexagonal button beneath)
  2. In the main menu, swipe your finger sideways to go through the menu pages until you see the Wi-Fi icon. Press to select.
  3. The Wi-Fi application opens.
  4. Alternatively, to use the Wi-Fi Widget, from standby, press the home screen. The Widget toolbar opens up.
  5. Scroll down to find the Wi-Fi Widget icon. Press the Wi-Fi Widget. The Wi-Fi Widget will pop up on the main screen.
  6. Press the Wi-Fi Widget on the main part of the display to launch the Wi-Fi application. The Wi-Fi application opens.
  7. Once in the Wi-Fi screen, press the large Wi-Fi button in the middle of the screen to turn it on. Wi-Fi is activated and the button turns blue.
  8. Press SEARCH Nearby Wi-Fi access points (APs) will appear as small circles on the display, with their names next to them.
  9. Press the circle representing the Wi-Fi Netowrk you want to connect to. An options panel appears.
  10. You can press CONNECT to connect to the network or press ADD if you want to add it to a list of preferred networks for easy access later.
  11. You are taken into a settings menu for the Wi-Fi access point. If the Wi-Fi access point requires a network key code, scroll down to the Network Key panel. Press to select.
  12. The numberpad appears. Type in the network key code and press DONE. You are returned to the previous settings screen. Press SAVE
  13. A list of connections appears. Press the back arrow button
  14. If you initially pressed CONNECT, the phone will connect to the selected Wi-Fi network and a confirmation message will appear. The display now shows the new connection, illustrated by blue dots linking the circles onscreen (Figure 15).
  15. If you initially pressed ADD, you will be returned to the Wi-Fi screen. Press the circle representing the Wi-Fi network you want to connect to. A pop up panel appears.
  16. Press CONNECT. You will be connected and the connection illustrated onscreen.
Press the back button to return to the home screen.
  1. From the home screen press MENU to enter the main menu (Figure 1).
  2. In the main menu, press INTERNET
  3. Choose which browser option you want (Home, Enter URL, Bookmarks, etc.) (Figure 18) and press to select. If you press Home you will be taken to the pre-loaded home page.
  4. If required, use the numberpad to type in an URL or scroll a list to select bookmarks. When an URL is completed press GO. Alternatively press the bookmark you wish to access. You will taken to the web page requested.
  1. Activate Wi-Fi and press SEARCH, as before.
  2. When the Wi-Fi access point you want to connect to appears on the display (Figure 8), press it to select.
  3. A pop up options panel appears (Figure 9). Press DETAILS
  4. Details of the Wi-Fi access point appear onscreen.
  5. Scroll down by dragging your finger up the screen. Towards the bottom of the settings list, DEVICE MAC appears, with a string of 12 charactesr beneath (Figure 21). Each handset has an individual MAC address, and this panel will display your Samsung Jet's unique Mac address.
Make a note of the MAC address. You will need it if you want to use the Samsung Jet's Wi-Fi to access a secure Wi-Fi network using MAC address restrictions. This can be added into the wireless router settings access list.
on Apr 17, 2010 | Samsung Jet S8000 Cell Phone
My ipod recognises the wifi network but can't connect
The iPod touch has the ability to connect to Wi-Fi networks, giving you access to information while on the go.
The iPod detects both protected and unprotected networks, and can remember which Wi-Fi networks you have used before, eliminating the need to enter passwords more than once.
Your iPod touch should automatically detect wireless networks, but you can also manually connect to a network or switch to a new one.
Tap the "Settings" icon on the home screen and tap the "Wi-Fi" button.
Tap the "On/Off" button to turn your Wi-Fi on. Press the "Home" button to return to the home screen.
Tap the Safari Web Browser application or any other application that requires Internet access.
A list will automatically open on your screen that names all available networks.
Tap the network you wish to use from the list.
The networks listed are all wireless networks detected by the iPod.
Protected networks will have lock icons to the right of their names.
Enter the password if the network you have selected is protected.
Your iPod touch will store this password for future use.
Type in the name of the network you wish to use if it is not listed.
A network that is set to not broadcast will not show up on the list of available networks.
Check the top left of the screen for the Wi-Fi icon to be sure you have connected.
The number of bars on the icon indicates the strength of the signal.
Manually Connect
Tap a network listed under "Choose a Network..."
A network set not to broadcast will not show up on the list of available networks.
http://support.apple.com/kb/HT2031
Nov 15, 2013 | Apple iPod touch
Ipod will not connect to wifi
Connect to WiFi for Your Apple iPod touch b> The iPod touch has the ability to connect to Wi-Fi networks, giving you access to information while on the go. The iPod detects both protected and unprotected networks, and can remember which Wi-Fi networks you have used before, eliminating the need to enter passwords more than once. Your iPod touch should automatically detect wireless networks, but you can also manually connect to a network or switch to a new one.
Tap the "Settings" icon on the home screen and tap the "Wi-Fi" button. Tap the "On/Off" button to turn your Wi-Fi on. Press the "Home" button to return to the home screen. Tap the Safari Web Browser application or any other application that requires Internet access. A list will automatically open on your screen that names all available networks. Tap the network you wish to use from the list. The networks listed are all wireless networks detected by the iPod. Protected networks will have lock icons to the right of their names. Enter the password if the network you have selected is protected. Your iPod touch will store this password for future use. Type in the name of the network you wish to use if it is not listed. A network that is set to not broadcast will not show up on the list of available networks. Check the top left of the screen for the Wi-Fi icon to be sure you have connected. The number of bars on the icon indicates the strength of the signal. b> Manually Connect Tap the "Settings" icon on the home screen and tap the "Wi-Fi" button. Tap the "On/Off" button to turn your Wi-Fi on. Tap a network listed under "Choose a Network..." The networks listed are all wireless networks detected by the iPod. Protected networks will have lock icons to the right of their names. Enter the password if the network you have selected is protected. Your iPod touch will store this password for future use. Type in the name of the network you wish to use if it is not listed. A network set not to broadcast will not show up on the list of available networks. Check the top left of the screen for the Wi-Fi icon to be sure you have connected. The number of bars on the icon indicates the strength of the signal.
b>
Feb 06, 2013 | Apple iPod Audio Players & Recorders
Wifi will not connect
The below info is from user manual ... downloadable version @ www.pantech.com
Connectivity
This chapter introduces useful tips on how to connect to the
network available that enables applications of the phone to
run.
Using a Wi-Fi network
Connecting to a Wi-Fi network
1. Tap Settings from the applications menu.
2. Tap Wireless & networks > Wi-Fi settings.
3. Tap Wi-Fi to activate the technology.
4. Select and tap a network. You should enter the password
if the network is secured. indicates a secured Wi-Fi
network.
5. Tap Connect. Once the network is remembered, the phone
will automatically connect to it when in range.
Activating Wi-FI Connecting to a Wi-Fi
network
Note The icon next to each network indicates the strength of the
signal. For example, indicates the signal is poor while indicates
the signal is strong.
Using the Easy Setting
1. Tap on the top of the home screen and drag it down, or
press n in idle mode and tap Notifications.
2. Tap in Easy Setting. The icon turns red when the
function is on.
About network notifications
You are informed by default when a Wi-Fi network is available
around you. The message in the status bar indicates a
network is available. Tap Network notification in the Wi-Fi
settings if you do not want to be informed the availability of the
network.
Setting Wi-Fi networks
4. Tap Network notification if you want to know an open
network available.
5. Tap Automatic connection if you want the phone to
connect to Wi-Fi network automatically.
6. Tap WPS button connection if you want to establish a
new wireless connection using the Wi-Fi Protected Setup
(WPS). You should press WPS button on your Wi-Fi access
point within two minutes.
Searching for Wi-Fi networks
Jan 17, 2013 | Pantech Pocket
I cant get an internet connection on this phone, do i need to set it up manually?
There are two ways you can connect to the internet over your phone. You can purchase a data plan from a company like AT&T which you can use anywhere. The other option would be to use your phone to connect to a wireless access point(WI-FI).
What are the differences? Wi-fi is usually free unless at a cofee shop etc but has a smaller area in which you can access(you have to be within a certain distance of the wireless router). A data plan cost money and is typically slower, however, you can use it at anytime as long as you have a signal on your phone.
You can click here to access the user guide for your phone.
If you have a data plan purchased and are using the SIM card they gave you then whenever you use a application on your phone that requires internet access it will connect.
If you go to page 83 of the manual it will go over the steps you need to take to enable Wi-Fi. In short, first active Wi-Fi
1) In Idle mode, open the application list and select Settings
? Wireless and network ? Wi-Fi settings ? Wi-Fi.
1) Then under Wi-Fi settings click Wi-Fi networks, select the Network you wish to connect to then click Connect.
Reference the user manual as it goes into more details about the features on your phone and how to use them.
Regards,
G33k
Jul 29, 2011 | Samsung Galaxy S GTI9000 Smartphone
How do i connect to the wifi
If you need to connect your HTC Wildfire to a Wi-Fi network then check out this simple, step-by-step user guide to getting connected wirelessly
If you're using your HTC Wildfire for the first time, you can easily select the Wi-Fi network you'd like to join using the setup manager.
When you opt in for either Mobile Network or Wi-Fi, or just Wi-Fi, the Wildfire will by default try to connect to a Wi-Fi network near you.
Select the network you wish to connect to, enter the password if required and you're set up.
If you want to change the settings, or set it up for the first time, you can do this through the Settings menu.
Note: If you're attempting to access a network-based page or app, you may be required to set up a new Wi-Fi connection. When prompted, select the option to set up a new connection.
  1. Access the Wi-Fi settings menu by navigating to the Wireless & networksmenu
  2. Select Wi-Fi settings
  3. Choose a listed network, or add a hidden network by selecting Add Wi-Fi network
  4. If you choose one of the listed networks and it's secured, enter the password, press Connect and you'll be connected to that network
  5. If you wish to access a hidden network, select Add Wi-Fi network and enter the SSID
  6. If a password is required, you'll be prompted to enter this before connecting
If Wi-Fi is turned off, you can now turn this on by ticking the box in the Wireless & networks menu.
links that may helphttp://www.htc.com/uk/howto.aspx?id=3381&type=1&p_id=316 http://www.knowyourcell.com/htc/htc-wildfire/wildfire-guides/487458/how_to_set_up_a_wifi_connection_on_the_htc_wildfire.html
Jul 28, 2011 | HTC Wildfire Cell Phone
Ipod wi fi conection
Wi-Fi Functionality
  1. Connects over the last Wi-Fi network you used that's available.
  2. If no Wi-Fi networks you've used are available, iPod touch will scan for Wi-Fi networks and show a list of Wi-Fi networks in range. Tap a network and, if necessary, enter the password to join. Networks that require a password show a lock icon (307189_1.jpg) next to them.
  3. Option to manually enter your Wi-Fi network name/SSID (if the Wi-Fi network is configured not to broadcast or be displayed to the public). If necessary, enter the password to join.
When iPod touch is connected to a Wi-Fi network, the Wi-Fi icon (307189_2.jpg) in the status bar at the top of the screen shows connection strength. The more bars you see, the stronger the connection.
Wi-Fi Settings
  1. Turn Wi-Fi on or off.
    Choose Settings > Wi-Fi and turn Wi-Fi on or off.
  2. Set iPod touch to ask if you want to join a new Wi-Fi network.
    When you are trying to access the Internet, by using Safari or YouTube for example, and you are not in range of a Wi-Fi network you have previously used, this option tells iPod touch to look for another network. iPod touch will display a list of all available Wi-Fi networks that you can choose from. Networks that require a password appear with a lock icon (307189_1.jpg).
    If "Ask to Join Networks" is turned off, you must manually join a network to connect to the Internet when a previously used network is unavailable.
    Choose Wi-Fi and turn "Ask to Join Networks" on or off. If you turn "Ask to Join Networks" off, you must join new networks manually.
  3. Join a Wi-Fi network manually.
    Choose Wi-Fi, wait a moment as iPod touch detects networks in range, then choose a network. If necessary, enter a password and tap Join. Networks that require a password appear with a lock icon.
  4. Make iPod touch forget a network, so that the device doesn't join it automatically. Choose Wi-Fi and tap the arrow (307189_3.jpg) next to a network you've joined before. Then tap "Forget this Network."
  5. Connect to a closed Wi-Fi network (an available Wi-Fi network that isn't shown in the list of scanned networks).
    Choose Wi-Fi, then tap Other and enter the network name. If the network requires a password, choose Security, tap the type of security the network uses, and enter the password. You must already know the network name, password, and security type to connect to a closed network. Some Wi-Fi networks may require you to enter or adjust additional settings, such as a client ID or static IP address. Ask the network administrator which settings to use.
  6. Adjust settings to connect to a Wi-Fi network
    Choose Wi-Fi, then tap the arrow (307189_3.jpg) next to a network.
Dec 27, 2010 | Cisco Linksys Wirelessn Router Black...
I can't connect to my wi-fi settings
Activate and connect to a WLAN
1.In range of WLAN network, access an application or menu that needs a wireless connection.
2.On the Home screen, press <Start> → <More> → Settings → Connections → More... → Wi-Fi.
3.Press <Menu> → Turn On Wi-Fi.
The device will display available WLAN connections.
4.Select a network profile from the list.
The device will attempt to connect to the WLAN.
5.Select a network type and press <Next>.
6.Enter a pre-shared key for WLAN and press <Next> or <Finish>.
7.Set the IEEE 802.1x access option and the extensible authentication protocol (EAP) type and press <Finish> (if necessary).
Create a new WLAN
1.On the Home screen, press <Start> → <More> → Settings → Connections → More... → Wi-Fi.
2.Select New...
3.Enter a network name, configure connection settings, and press <Next>.
4.Enter network authentication settings and press <Next>.
5.Set the IEEE 802.1x access option and the extensible authentication protocol (EAP) type (if necessary).
6.When you are finished, press <Finish>.
Jan 08, 2010 | Samsung Omnia Pro B7320 Smartphone
Cannot get ipod touch to connect to wireless network
Many Wi-Fi issues can be resolved by doing the following:
Basic troubleshooting
  • Tap Settings > Wi-Fi and turn Wi-Fi off and then on again.
  • Verify that you are in range of your Wi-Fi router or base station.
  • Confirm that your Wi-Fi router and Cable/DSL modem are connected to power and turned on.
  • Check whether other devices (portable computers, for example) are able to connect to the Wi-Fi network and access the Internet.
Jan 01, 2009 | Linksys Wireless-G WRT54G Router
HTC Desire Cell Phone Logo
Top HTC Cell Phones Experts
Ashutosh Khandelwal
Level 1 Expert
D. E. Hev
Tech Leprechaun
Tech Leprechaun
Are you a HTC Cell Phone Expert? Answer questions, earn points and help others
