Question about Husqvarna Craftsman 200 Mph 430 Cfm Gas BlowerVac
How to remove the housing for 358797342 gas leaf blower to replace gas line
Model 358 797342
4 Suggested Answers
boscia
  • 163 Answers
SOURCE: Husqvarna leaf blower, replace starter cord Model 132 HBV
remove the starter housing, usually only 3 or 4 bolts or screws. on the inside should be a large white or black wheel, hold the outer case with one hand and rotate the wheel counter-clockwise with the other as many times as can without force. on the inside of the wheel should be a small hole, rotate the wheel to line it up with rope guide hole on the outer case/housing. use a nail or small screwdriver to help hold in place. feed the start rope through the 2 holes and tie a knot at the end, single or double depending on the size of the hole. if the end of the rope is frayed, use lighter to melt and twist to a point to make it easier to handle. when reassembling you may need to jiggle the handle for realignment. it works on an inner spring coil tensioner system, so if the cable has no tension when rotated or doesn't recoil back, the starter assembly will need to be replaced.
Posted on Nov 30, 2008
jdlipscomb41
  • 157 Answers
SOURCE: what is the ratio of oil to gas for Husqvarna leaf
i mix my husky and stihl the same 50;1 ratio that way i know it has enough oil not to burn the piston
Posted on Oct 26, 2009
  • 198 Answers
SOURCE: Husqvarna Leaf Blower won't start
yes, it is. i suggest checking to make sure the plug is firing--you can check by removing it, plugging it back into the plug wire and resting the threads of the plug on any ground--usually right outside the spot where the plug screws in. have someone pull the cord while you see if the plug fires. DON'T touch the plug while the engine is being cranked. also, even if you see a spark, it may not fire inside the engine. if the spark is weak, you may want to put in a new one.
Posted on May 12, 2010
Hello, I have a sears leaf blower 358.794762 that will not start. It's almost like the primer bypasses the carb
Craftsman Leaf Blower Model 358.794762 (358794762) Parts
www.repairclinic.com/.../Model-358794762-Craftsman-Leaf-Blower-Par...
This part fits your Leaf Blower. Husqvarna fuel filter. If the fuel filter is clogged, it willrestrict the flow of fuel to the carburetor. As a result, the engine may not start.
Hello, I have a sears leaf blower 358.794762 that will not ...
Nov 25, 2015 | Sears 25 cc Gas Blower
My craftsman leaf blower won't start. It gets gas and spark. Is there an ignition issue I should be looking at. The same thing happened with my Poulan blower a couple of years ago and the re
Remove the carburetor carefully noting which fuel line goes where. Remove the section of the carb that the fuel lines attach to. Examine the main carb housing that attached to the part that you removed and you should see a very small screen that is probably blocked from fuel additives that the government requires. Clean that screen and reassemble and reinstall the carb and use fresh fuel/oil mix and use a fuel stabilizer in your mixed fuel.
Nov 16, 2014 | Craftsman Garden
Primer bulb on my craftsman leaf blower #358797342 wont prime
Check age of gas. Cannot be more than 30 days old.
Make sure to use fresh gas w/synthetic 2-cycle oil @ 40:1 ratio (1 gal.) Gas to 3.2 oz. Oil). Do not use old or stale oil/gas mixture. Always use the proper oil/gas mix. If you do not, your engine will suffer rapid, permanent damage.May need to clean or replace carburetor.
Dec 30, 2011 | Craftsman Garden
Need to replace both fuel lines on My BVM200 LE leaf blower, 1 large and 1 small fuel line, can You tell what size they are??
On your blower, it looks like the small line supplies fuel to the carburator which will be connected to the fuel filter in the tank, and the large line looks like the fuel return line.
http://www.ereplacementparts.com/poulan-type-gas-blower-parts-c-16962_31724_131359.html
Jul 19, 2011 | Poulan Pro 25CC 2Cycle Gas Blower
I have a Homelite "Vac Attack" leaf blower model
The fuel line is replaceable by itself, you don't need a new tank. Just make sure you get the same size line or it will leak where it goes into the tank. Any local small engine repair shop should have the line. There are two lines that go into the tank, the pickup line has the filter on it. It not only filters the gas but keeps the end of the line down in the fuel.
Nov 02, 2010 | Homelite Garden
Gas does not seem to be getting to the carburetor
Check the fuel lines going to the carburetor from the tank to make sure none of lines have decomposed or gotten soft also check the fuel filter inside the tank to make sure gas can get through...if the lines or filter are bad... replace them...bulk fuel line and filters available at any mower shop or mower parts house....a fairly easy job !!! hope this helps... ;-D
Aug 11, 2010 | Weedeater Gas Blower
I have a Ryobi Leaf Blower (Model 310 BVr) which
Look for a cracked fuel line, or a loose fuel line around the fuel tank. I'm going to lean towards the cracked fuel line.
Feb 01, 2010 | Ryobi Garden
Craftsman gas blower model #358.797130. replaced gas line and filter.Had to take gas tank out to connect line. Cannot find how to connect the carbuetor to stay on the gasket. diagram in the book doesn't...
Probably a couple of screws that you took out to access the carb from inside the air filter housing. Probably Torx head screws. You line up the carb and put the air filter housing back on over the carb, lining up the holes in the engine block.
Does this look like the answer you were seeking? Or did I mis-understand?
Nov 01, 2009 | Craftsman 4 Cycle Blower/Vac
Gas line connections
The thicker of the two lines goes on top nearest to the primer ball
Mar 21, 2009 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
Husqvarna Craftsman 200 Mph 430 Cfm Gas BlowerVac Logo
210 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
