Question about Bosch SHU3306UC Built-in Dishwasher
Bosch rinse aid dispenser cover doesn't stay closed
The rinse aid dispenser has a cover which normally you can close. My cover will not stay closed. I notice inside of cover has white calcium stuff on it as we have hard water, but the cover used to close. I think it should be closed so only the right amount of dispenser is released.
5 Suggested Answers
  • 677 Answers
SOURCE: Dishes do not clean same detergent and rinse no change to amount
The problem is hard water. There is a new product out called the dishwasher filtration system. It filters the water before it enters your dishwasher. It works amazing and has a money back guarantee. You will love the way your dishes look after the first load. It is also very affordable (like 70 bucks). Go to www.dishwasherfilter.com to find out more info.
Posted on Mar 30, 2010
heatman101
  • 43501 Answers
SOURCE: Residue on dishes/glasses - Hard water? How to clean?
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
Dishwasher Residue and Film on Dishes
heatman101
Posted on Mar 04, 2011
Macmarkus
  • 2605 Answers
SOURCE: Bosch washer reverts to rinse
Hello, welcome to FixYa.
If you can provide the model number (usually on inside of door frame or tub frame around door opening as shown here for bosch)
...I'll see what I can find for you.
There are many possible scenarios so I'll need to clarify the make & model before moving forward.
Regards,
Macmarkus :)
Posted on Jun 17, 2011
  • 4 Answers
SOURCE: Soap dispenser cover won't close
Main detergent cup won't close on GE Potscrubber 700 GSD700.A workaround is to add the additional detergent with rinse aid 18 minutes intothe wash cycle. To repair, switch off power through circuit breaker. Set timerknob to 12 o'clock. If the detergent cup lever spring opens the cup after it isclosed, remove screws on panel that holds detergent cup and remove the panel upand out of door. Remove timer cover by moving it right and pulling up to exposetimer, see photo 1. _1909.jpg If a spring is loose, it can be reattached as follows.Remove two screws that hold timer, then remove timer. Do not remove timer knobfrom front of GSD700 because knob is designed for removal from rear of panel,after the timer is out. If spring attachment point broke off, reinforce it withepoxy (JBKwik), see gray cone upper right of center in photo 2. _1910.jpg After epoxy cures, drill and tap a hole for a metric 3 - 0.5mm-8mm screw (4-40 may also work). Install spring between new screw anddispenser linkage and tighten screw, see photo 3. _1911.jpg Install timer, jiggle knob so it engages timer and securetimer with two screws. Pull dispenser lever down to make sure it moves andsprings back. Replace round switch and cover. Install white cover with leverextended through it. Install cover screws, close soap door, and rotate timer,soap door should open after about 90 degrees of rotation followed by rinse aidactuation.
Posted on Sep 04, 2011
Why does it keep dispensing soap?
What do you mean "keep dispensing soap"? Is this a GE dishwasher with an automatic soap dispenser? Or do you mean that the soap lid won't latch or stay closed? Or are you talking about the rinse-aid dispenser leaking rinse-aid (which is fairly common)?
May 11, 2015 | Dishwashers
Where do you put rinse aid
For most dishwashers, there will be port on the door. Usually it will be near the detergent dispenser. On mine, the two items are in one grey plastic enclosure. The rinse aid port is on the right side of the area as you look at the dishwasher door from the front of the dishwasher. Look for a knob surrounded by a few numbers and a few symbols/words. In one direction, the dispenser will be closed; no rinse aid will be released. Turn the knob fully in the other direction, it's open and the cover can be pulled up to allow for refilling the dispenser.
I hope this helps. Please add a comment with your dishwasher's make and model number for more information.
Apr 06, 2015 | Dishwashers
Why does the low rinse light stays on?
The obvious answer is that you need to add rinse-aid to the rinse-aid dispenser. Barring that, then you probably have a bad level sensor in the dispenser and would need to replace the whole detergent/rinse-aid dispenser assembly. On the other hand, it could just be a loose or disconnected wire going to the detergent/rinse-aid dispenser.
Oct 09, 2014 | Samsung DW7933LRABB
Where to put rinse aid in cdw10 dishwasher
Rinse aid makes dishes sparkle more as it improves their drying. The rinse aid container is situated on the inside of the door. You should fill the rinse aid container when indicator lights up on the container and the rinse aid indicator light on the control panel flashes. You can use simple vinegar as a rinse aid (white is best but apple or malt is fine).
Adding rinse aid.
To open the dispenser, turn cap anticlockwise. Take care when you pour in the rinse aid to avoid it overflowing. You can regulate the amount of rinse aid used by the dishwasher, move the adjuster which you will find under lid. The amount of rinse aid needs to be increased if the dishes appear dull or you can see circular stains. The amount of rinse aid needs to be reduced if the dishes are sticky or see white streaks.
You can choose from six different positions. It is normally set to 4.
Jun 07, 2014 | Hotpoint 24 in. FDW60 Free-standing...
Soap residue on glasses, dishes & flatware...what can I do..I use Cascade & JetDry
Instructions Things You'll Need:
  • Vinegar or lemon juice
  • Gel dishwasher detergent
  1. dishwashers have a rinse aid dispenser. If your dishwasher has this dispenser, fill it up periodically and it will release the appropriate amount of rinse aid automatically at the right time during the wash cycle. This will help your dishes rinse more cleanly.
  2. Rinse aid in solid form
    Some older dishwashers or basic models do not have an automatic rinse aid dispenser. In this case, you can buy rinse aid in solid form that attaches to your dishwasher rack. Solid rinse aid can be hard to find in stores because it is not commonly used, but it can be purchased online.
  3. Vinegar or lemon juice
    Appliance repairmen will tell you that one of the common problems they see with dishwashers is the buildup of excess detergent. If there is too much detergent in your dishwasher, your dishes will not rinse cleanly, no matter how good the dishwasher is or how much rinse aid you use. To clean the excess detergent that has built up inside your dishwasher, put 3 tablespoons of vinegar or lemon juice (concentrate is fine) in the empty dishwasher and run the dishwasher through a complete cycle with no dishes. Do this twice, for two complete cycles of the empty dishwasher with only vinegar or lemon juice added. The acid in the vinegar or lemon juice will break up the detergent that has built up in your dishwasher's interior.
    After you have cleaned the detergent buildup from the inside of your dishwasher, follow the steps below to keep the buildup from happening again and to help your dishes rinse cleanly and prevent residue from accumulating on the dishes.
  4. Gel dishwasher detergent
    Switch to a liquid or gel dishwasher detergent. Any brand will do.
  5. Fill one compartment half full Dishwashers will effectively clean dishes with much less detergent than manufacturers often recommend. The bleach in the detergent, combined with the extremely hot water used in the dishwasher wash cycle, will clean and sanitize your dishes completely, even in small amounts, and using less detergent helps prevent buildup and residue from accumulating on your clean dishes.
    Fill only one detergent compartment(the one that snaps closed) half full with gel detergent. Snap the opening closed and run your dishwasher as you normally would. Your dishes will come out sparkling clean with no buildup or residue, plus you'll save money by using less detergent!
Feb 02, 2011 | Dishwashers
My dishwasher is now leaving my dishes cloudy. What causes this?
Make sure that the rinse-aid(jet dry) container is full. If it is full have you noticed if it's level has not dropped. It is possible that the rinse-aid dispenser is plugged. This will cause the dishes to be cloudy. You can also try running the dishwaher empty and add a cup of vinegar to the bottom before your start. There is also this stuff called "dishwasher magic" that you can try running in the dishwasher to clean it. Try using a soap with the rinse-aid in it or install a basket with a rinse-aid tablet and see if that helps clear up those cloudy dishes.
Nov 08, 2009 | Frigidaire Dishwashers
White film on dishes, glasses and silverware.
white film is actually from the calcium and magnesium found in hard water. your dishwasher is fine. its the water leaving the residue and spots. go to www.dishwasherfilter.com . they have a new product out exactly for this reason. very affordable and works amazing. you will love it.
Oct 06, 2009 | Dishwashers
At some point the dishwasher leaks onto the floor. what could be the possible problem?
this are the possibilities for the leak :-----
Door gasket loose/torn
Corner gaskets or door baffle/vent gasket
Door lock/latch loose/broken
Split spray arm
Over filling with water...usually the level is just under the heating element is normal
Something leaking through the door...like the soap or rinse agent dispenser gasket, silverware basket button.
Door hinge(s) bent
Wrong soap was used...dish sink soap instead of dishwasher soap
Rinse aid being used with mechanically softened water ( makes foam or suds inside the dishwasher )
Leaks from under the unit:
Look for whiting or calcium stain on the motor and pump assembly = motor and pump assembly seal leak...access panel removal help
Hose for upper spray arm split
Fill hose split or fill hose spout air inlet is calcium covered
Drain hose is split
Rusted liner...metal liners only
Fill valve leaking or allowing water to fill all the time
Heating element ends....where they come out through the dishwasher liner
Float or float gasket.
Sep 23, 2009 | Whirlpool 24 in. GU980SCG Built-in...
It sounds like it may be stuck between cycle steps.(this sometimes happens if the washer is open during a cycle)Try and run it through one full wash cycle as it is.Then check to see if the soap door will close.If not,the lack may be broken
Jan 09, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Dishwasher problems
Hi Bmissy,
I had the same problem with my dishwasher. In my washer the problem was caused by a buildup of water deposits throughout the machine. I increased the temperature of the water, used three bottles of "Dishwasher Magic" and now my machine is working well. I read that the rinse aid dispensers do not disperse enough of the product for extremely hard water, the solid rinse aid dispensers work better. I know that adding a little water softener to your washer when you run it can help. If you can't find "Dishwasher Magic", you might want to try running your dishwasher with a few quarts of white vinegar to remove the deposits on the coil. You may need to clean out the deposits in your washer regularly to keep the machine working well.
HTH!
Ann
Nov 02, 2007 | Dishwashers
Bosch SHU3306UC Built-in Dishwasher Logo
48 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
