Question about Kenmore 62602 Electric Dryer
Dryer will start when you set the timer don't have to pust start
Start knob doese not need to be pushed
  • 640 Answers
Push to start swich bad,,,replace
Posted on Jan 05, 2009
Roper dryer repair manual
90% it's the timer
Jan 30, 2014 | Dryers
Dryer has power to timer, but won't start...I have an Amana electric dryer that allows me to set the timer and I can hear it running, but when I push in the the timer knob to start the dryer (drum
The fuse is mounted on the heater element. When it blows nothing in the heater or motor circuit works but the power to the timer is not interrupted therefore you can hear. Service manual
Feb 11, 2013 | Amana Dryers
The dryer timer knob won't set, therefore when you push to start, nothing happens
Try to twist the outside ring around the timer knob. The knob could be faulty and freewheeling, so turning the outside ring (I'm assuming you have a mechanical timer, not an electronic one) does the same thing as turning the knob while it is "out". When you've set the timer, then push the knob in to start. Hope this helps - I made some assumptions about your machine that I hope are correct... Good luck.
Nov 28, 2009 | Dryers
When i push the push knob the dryer will not start...the electric is there i need to know how to repair the push knob
If you are talking about the starting switch "knob", you will not normally repair that, you will replace it.
If you are talking about the timer switch you normally do not repair the timer switch either...replace it.
If you do decide to replace either switch, remove and replace one wire at a time, this will save you problems with the wiring.
Sep 26, 2009 | Crosley CDE6000 Electric Dryer
Knob will not pull out to start dryer
i dont there is a pull out knob on dryer there should be a start button knob is to set time make sure door is closed and push all buttons ans see what happens
Sep 11, 2009 | Hardware & Accessories
TIMER NOT WORKING
The knob does not pull out on dryers. Turn the timer to the desired setting and push the start button. Eric
Sep 10, 2009 | Dryers
GE Dryer bought 08/08/07 First it stop bewfore cloths were finished, if I hit start button it would finish, now it will not start.
The dryer knob on timer was cracked, when removed, therefore it was not actually engaging the
timer proper. Replsaced knob now it is fine.
Jun 03, 2009 | GE Dryers
Dryer just stopped working. Turned knob to desired time and pushed start, nothing happens. When knob is on OFF position and I push the start button, it makes the regular BUZZ sound - times up, clothes...
Remove and inspect the timer knob for a crack or missing tension clamp.
Carefully place it back on the timer shaft while paying attention to the (D) shape in the knob and the shaft.
If they are aligned correctly notice where the position arrow is pointing, ie; off---run--etc.
You may well need a new knob.
Feb 21, 2009 | Dryers
Removing Timer knob on Kenmore Electric dryer
Normally, to remove the timer knob, simply push in on the timer knob and turn the knob counter clockwise. it should unscrew itself. If it does not, the shaft inside the timer has broken and the shaft simply free wheels so then you need to take a needle nose pliers to hold the shaft and then you can turn the knob or pull it off
Let me know if you have any further questions
Jun 04, 2008 | Dryers
Kenmore 62602 Electric Dryer Logo
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De GO PATS
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
