Question about Watches
Bulova quartz mantel clock instructions - Watches
  • 580 Answers
SOURCE: How do I set the date on an old bulova caravelle men's watch
Pull the stem out 2 clicks the in 1 click turn stem clockwise for day and counter-clockwise for month. to set time pull stem out again 1 click, when finish push in 2 clicks
Posted on Jul 09, 2009
  • 15 Answers
SOURCE: I NEED THE INSTRUCTIONS FOR SETTING THE CHIMES/TIME ON MY WESTMIN
Manually turn the minute hand forward until the 16 westminster chimes sound and then the hour strikes. Then remove the minute hand (it will go on in four positions) and put it back on at the 12 o'clock position. The chimes should now be back into sync.
Fred
Posted on May 10, 2010
  • 16 Answers
SOURCE: Quartz president wall clock, I need to set the chime
I have a pendulum wall clock from the president collection. If yours is the same or similar, the following may help:
*Look at the back for a slide switch labled "start" at the top and "set" at the bottom and move it to "set"
*Look for for small push buttons. They represent the hours and minutes. Push each in turn, the number of pushes to represent the time, ie, for 09:45, ignore the first(0), push the second 9 times(9)-push the third 4 times(4)- push the 4th 5 times(5). When done, push the slide switch back to "start".
If yours is the same as mine - a wall hung pendulum clock with Westminster chimes, made around 1988. I would be happy to scan and send a copy of the instructions.
John
Posted on Nov 03, 2010
  • 1416 Answers
SOURCE: I have a Bulova Millenium
ALARM: Sound a clock or watch makes to awaken the sleeper at a certain time. Bulova produce a number of alarm clocks to help you get to work on time with varied sounds, including bell, double bell, chirp, beep, buzz and melody. Some Bulova watches are also fitted with an alarm which will either beep at a preset time or vibration on your wrist.
ALTIMETER: A feature found on pilots watches that indicates the altitude based on barometric pressure changes.
ANALOG/DIGITAL: A watch or clock that has both an analog display, has a face with hands, and also a digital display like a calculator.
ANALOG: The traditional method of displaying the time by means of hour, minute and second hands.
Posted on Dec 22, 2010
SOURCE: I have a Bulova Mantel clock that is chimming off
I have a B1987 bulova baradwell mantel clock that is chiming off I can't find my instructions book. please help me to fix this problem thanks
Posted on Jul 20, 2011
Wich battery number may i use in this watch bulova 96t63 ??thanks
cant see that model watch on the Bulova web site user manuals
http://www.manualslib.com/brand/bulova/watch.html
if unsure if it needs a battery go to a jeweler or watch or battery seller
some model Bulova Watched instructions
IF YOUR NEW WATCH IS A MECHANICAL WATCH
(no battery)
Mechanical watches differ from Quartz watches in several
respects:
1. No battery changes are needed - they are powered by a main-
spring, which is wound either by wrist movement; or in some
models by daily winding of the setting crown.
2. Because it is a mechanical device, it's accuracy is subject to
the effects of gravity and temperature. You can expect, on the
average, a daily variance of up to 10 to 20 seconds for
mechanical watches.
3. Just like automobiles, these watches require routine mainte-
nance. Due to their mechanical complexity, mechanical
watches require cleaning and new lubrication every 3 to 5
years to run at optimum efficiency.
FOR THE AUTOMATIC SELF-WINDING
MECHANICAL WATCH
it must be wound at least six or seven times before you wear it.
After that, your daily activity should wind the watch sufficiently
to keep it running at night when it is not being worn. If your
normal daily activity is not sufficient, occasional supplementary
manual winding may be necessary. It is suggested that your
mechanical watch be cleaned and oiled periodically to insure
optimum performance. As a mechanical watch, quartz watch
accuracy cannot be expected. References to the power cell do
not apply to Automatic watches
May 02, 2016 | Bulova 96T53 Watch for Women
Bulova mantel clock won't keep time
Sounds like a broken escapement, definitely a job for a horrologist (watchmaker)
Sep 29, 2013 | Watches
Bulova mantel clock won't keep time. New batteries and will chime. It's about 25 years old at least.
Try CAREFULLY cleaning the mechanism with naphtha lighter fluid. Lighter fluid is high grade naphtha. Be careful not to allow it to run on to the face and electronics. It may damage the face with stain or remove any decals or cemented numerals. It may only take a small amount to clean the shaft bearings. The lighter fluid cleans and lubricates without leaving a film. If you can, while the fluid is on the gears, manually turn the clock forward 12 hours. That will rotate all the gears fully. Us the fluid sparingly!
Apr 14, 2011 | Bulova Watches
I have a Bulova Quartz World Timer (B2100-this is printed on a sticker on the bottom of the clock). I am unable to set it and have checked the internet. I have checked the Bulova website and posted the...
If it is a desk type clock, hold down the 'mode' button, then the up or down button till the time is correct. To set the alarm, hold down the alarm 'on' button til it flashes the time then the 'up' or 'down' button.
Jan 15, 2011 | Bulova Millennia World Time 98G66 Wrist...
The clock runs fast , 20 plus minutes a day... Is there an adjustment and or how do I deal with this problem? Mantel 8 day clock. Thanks Ron
mcdevito75 here, There should be a F/S on the back of the clock, if so place it in the middle, if not, check out a small watcg repair shop in your area.
Jun 26, 2010 | Bulova Hyannis Desk Clock With Engraving...
How do I find my serial number on my bulova watch
Serial numbers are generally on the back of the watch.
You may be able to find two or three numbers on the watch.
A case number, a movement number and a serial number.Alternatively you might find a style number (which in your case is 26B44) and a serial number.
Mar 05, 2010 | Accutron Swiss Watch by Bulova 26B44
I am trying to find a complete W993 Quartz
Go to any watch or jewelry shop.
Dec 27, 2009 | Watches
I have a Bulova Mantel clock that is chimming off the hour how do I reset it?
Aug 02, 2009 | Bulova Watches
Watches Logo
233 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
