Question about Refrigerators
I put it in the wrong outlet of 220 and now it stopped working
    Top Expert:
  • Refrigerators Master
  • 9,472 Answers
What is the model number of the unit?
Posted on Nov 05, 2012
Is the Hunter portable AC High Effiency Model 31125 to be plugged into a 220 outlet only?
if the plate on the side says 220 volts then it will only work on 220 -250 volts outlet
at a 110 volts outlet it will fail and at anything more than 250 volts it will burn up
Apr 20, 2016 | Hunter Heating & Cooling
I can't find an electrical outlet that the plug will fit into
Probably because it requires a different electrical current. Is your machine made to run on 220 volts? If so, it will not work on regular 110 volts (standard household current). You'll need to have a special line and outlet to power 220. The outlets are different because you really don't want to be plugging a 110v appliance into a 220v outlet, or vice versa.
http://www.usatourist.com/english/traveltips/electric-power-tips.html
Mar 29, 2016 | Welding Tools
Don't have money to buy new dryer timer ($85-$95). Can I just put a 220v timer between panel and 220 outlet?..
there is an issue with the amperage load on the timer..most dryers require a 40 to 50 amp connection to work properly.. using a timer thats not as heavy rated will catch fire from overheating!!!!!dont want to burn the house down...
Jan 23, 2013 | Dryers
Our window AC unit stopped suddenly. Completely dead. The outlet has power. It's a 220V unit. LG window AC LW2510ER Any advise what it could be? Does it shut down when it's 100F outside? Thanks...
No - the outside temperature will not shut the AC down.
You say the outlet has power? Does it have the needed 220 volts? Most of the time 220 volts is on one switch, (that operates both 110 volt legs of power at the same time). - but sometimes each leg is on a separate breaker and if "one leg" trips you will still have power at the outlet (110 volts) but you won't have the needed 220 volts. While this is not likely - it is possible - so I would want to test the outlet with a voltage tester and determine the voltage. You might try checking in your breaker box and seeing if another breaker (110volt) is tripped. The same thing applies if you are dealing with fuses instead of breakers - determine the voltage at the outlet - and if you don't have 220 and only have 110 then look for a blown fuse or as I said above - a breaker tripped.
If you do have 220 at the outlet and nothing is running - I would be looking for an inline fuse of some sort within in the unit. Many of the newer units have them and they are usually easy to spot and all you have to do is to unscrew the fuse holder and replace the blown fuse. Be sure to have the power off when handling fuses.
Note: Be aware that while breakers/fuses can trip and blow without a serious problem going on - they (blown fuses/tripped breakers) are usually a sign of something significantly wrong with the unit.
Good Luck!
Jul 03, 2011 | LG Heating & Cooling
Electrical issue...220 dryer outlet problem
ok start at the pannel is there a double breaker there
usually a 30 amp two pole breaker this is how a pannel works first breaker pulls 120 off of one side of pannel second breaker pulls off 120 off the other side of pannel if you look the buss bars you will see that they interchange from one side of the pannel to the other so at the breaker you are checking make sure you have 120 v on output of one half of breaker and 120 on second half of breaker when you use a volt meter put one side to gng the other side to wire comming out of breaker you should have 120 on both sides if not you have a bad or tripped breaker
Apr 24, 2010 | Hammering
Dryer will not start door is closed
Carefully check your 220 outlet. You can check a 220 buy a volt meter. Make sure your volt meter is set over 220 range and put the red lead into the slot and black lead into the L shape. It could be you are not getting 220 power out of your outlet. We all know on a 220 outlet both legs have 110 on each side. A dryer takes 110 for the motor, and takes 110 for elements.
Dec 03, 2009 | Estate TEDX640JQ Electric Dryer
I would like to know if I can power my hottub right to an existing 220 line the tub runs 220 volts 36 amps and I have a 40 amp fuse already installed in the house plug
Check your local codes, you probably will need a ground fault current interrupting breaker(GFCI). Do not skip the codes, if anything goes wrong, your insurance company will not cover. Putting a special box GFCI protected will give you extra protected outlets for outside use.
May 05, 2009 | Electrical Supplies
Electric range burners and oven element just stopped working. Burner indicator light came on and oven temp setting displays correctly. Clock went into set mode automatically, though. Burner came back on...
check the power behind the stove, the outlet for 220 volts, i just fix one with the same problem, it was getting 110 volts but not the 220 volts. so there was nothing wrong with the stove but with the power source.when the stove indicator lights work and the clock, it means that only 110 volts are coming to the stove.
Dec 10, 2008 | GE JBP24 QuickClean Electric Kitchen Range
Wiring a stove
If there is no 220 outlet in the location where you're planning to put the stove then you need to run wiring to the new location. There are two seperate phases of 110 volts coming to your home. The voltage between each of these phases and the neutral wire is 110 volts. When your house was wired only 1 of the 110 volt signals was run to your 110 volt outlets. In order to create a 220 volt outlet you need both of the 110 volt signals run to the outlet.
If you have a straight shot between your breaker box and the location where you need the 220 volt outlet then this is not too big a deal. If you have finished ceilings and walls inbetween then this will be much more difficult.
If you're not comfortable with electrical wiring this would be a good time to call a licensed electrician.
Nov 18, 2007 | Ovens
Refrigerators Logo
27 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
