Question about Elna Sewing Machines
What walking foot will fit the Elna Stella Air Electronic sewing machine (it is approx 30 years old)?
2 Suggested Answers
Tally Girl
  • 1125 Answers
SOURCE: What make of walking foot
You need a low shank style walking foot. Even back in the 80's when your SU air electronic was new, the walking foot sold by Elna was an after market one, and not made by Tavaro. Same with the ruffler attachment, it was after market and actually fitted quite a few makes of machine.
I would just ask the dealer/shop if they will refund your money if you find it doesn't work just in case.
There is a low shank one on sewingpartsonline.com
http://www.sewingpartsonline.com/walking-foot-low-shank-p60444.aspx and they list the SU as compatible with it.
Take off the foot holder on your mache, and you need to fit the little open ended arm over the needle bar and the foot bracket onto the foot with your machine's regular thumb screw. The up and down movement of the needle bar operates the walking foot.
Posted on Jun 25, 2011
Tip
How to change lightbulb in Air Electronic SU TSP Jubilee 500 and Carinas
If you own an Elna Air Electronic and blow a lightbulb then here is the instructions to change it. The lightbulb will be a bayonet fitting 15w but maybe remove old one first to make sure you get the right length bulb at the shop.
Firstly unplug the machine. Take your mini screwdriver that came in your kit and look at the top of the machine above the needle. There is a little hole there, put the screwdriver into the hole and push down on it, this lowers the bulb holder in the head of the machine down below the casing on a slant towards the back of the sewing bed, its spring loaded so you may need a second pair of hands to do it the first time.
Hold the screwdriver down, and grasp the bulb, push it up and twist anticlockwise to undo the bayonet fitting. Push down and repeat the process to insert the new bulb, turning clockwise to insert it into the bayonet fitting. Release the screwdriver and the bulb holder will retract back into position.
If you have a Stella air electronic then it is very similar except for the location where you need to push. On the Stella look at the rear of the machine head above the bobbin cover and you will see a little slide mounted right at the end of the rear casing. Same thing but for these, put the screwdriver across the top of the slide horizontally, then push down on it to lower the bulb mounting.
That's it! Happy sewing.
on Oct 19, 2011 | Elna Sewing Machines
Have inherited my mom's elna Stella tsp air electronic. The foot control became harder to press, then stopped working. Elna want ZAR858 for a new part! Can I repair it?
Im confused, Stella TSP air electronic has a round black and white air foot with a black air line to the side of the machine like this.
or the earlier Lotus TSP has a electric foot and cable which is made of older style plastics, these are harder to find now but Sewingpartsonline.com carry an aftermarket one like this
No, not cheap parts but beautiful machines that with TLC work so well.
Mar 23, 2013 | Elna Sewing Machines
Elna stella air electronic
you could try www.Scribed.com or www.diplodocs.com for this one free, otherwise pretty sure it can be purchased at www.sewingpartsonline.com or relics which is www.sewing-machine-manuals.com.
Should be a blue or brown cover I think from memory.
May 04, 2012 | Elna Sewing Machines
What make of walking foot would fit my Elna su air electronic sewing machine, thankyou
Jun 25, 2011 | Elna 2007 Mechanical Sewing Machine
HI, I have an old Elna Stella, bought in Australia in 1983. The shank that holds the presser foot onto the column keeps slipping forward. This causes the needle to strike the presser foot at the back edge...
Are all your sewing feet in one piece that screw on? I'm struggling understanding what your foot is actually doing Lindy; is it because the nut loosens up quickly? or is it possible that the foot you are using is not an Elna foot?
Elna later changed to "Low Shank" clip on feet with the Air Electronic range and these should be interchangeable with your Stella. I found a good website for this, www.sewingpartsonline.com and he has the "Pressure Foot Shank" which is the later swissmade shank for the swiss made Elnas. I couldn't see a replacement screw to hold on the feet though but a sewing machine dealer might be able to track one down. Or try Ebay, still some swiss Elna stuff out there.
good luck
Carolyn
Feb 05, 2011 | Elna 2007 Mechanical Sewing Machine
Elna walking foot
If your SU is an Air Electronic model i.e. 80's model, Elna didn't make a walking foot to fit. However, if you've got a walking foot that is the same height from sole plate to the screw fitting as a standard Elna foot then you could give it a try. The walking foot connects to the presser bar with a screw but the needle bar also needs to hook into a secondary lever on the side of the walking foot to make the foot actually move. Probably sounds very confusing . Check the movement of the foot manually by hand turning the fly wheel to see how it works before you actually use with the motor to minimise any problems if the foot doesn't fit.
Also you'll probably only be able to do straight stitch with this foot due to the clearance around the needle plate.
Oct 27, 2008 | Elna 2007 Mechanical Sewing Machine
Sewing Machines Logo
60 people viewed this question
Top Elna Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Derek Massey
Are you an Elna Sewing Machine Expert? Answer questions, earn points and help others
