Question about Dual XD7600 CD Player
Dual xd7600 wiring diagram
I need output wire diagram
  • 6 Answers
SOURCE: Dual XD7600 Head Unit Problems
Sounds like the flexible connector that connects to the drop-down front panel is bad, broken pattern lead.
Posted on Aug 28, 2007
etirbynnor
  • 655 Answers
SOURCE: I need a wiring diagram so i can connect it to my 1997 ford taurus
Hello elkhartsmost,
You can view the wiring diagram here.
http://www.retrevo.com/search/v2/jsp/mytrevo/myTrevo.jsp?page=man
It's a secured PDF file which you can look without saving a copy to your computer. If you wish to save a copy, you have to pay.
Hope this helps.
Posted on Apr 22, 2009
  • 13 Answers
SOURCE: need to order output wire harness for dual xdm6220 stereo
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&ssPageName=STRK:MESELX:IT&item=250436705625
Posted on Jun 22, 2009
drsinister69
  • 2317 Answers
SOURCE: need a wiring diagram for this radio
Here is a link to the stereo's owner's manual which will tell you how to hook it up:
http://a248.e.akamai.net/pix.crutchfield.com/Manuals/070/070XD7500.PDF
Posted on May 18, 2010
  • 12 Answers
SOURCE: trying to install an XDM6350
Here is the User Guide for the XDM6350:
http://www.dualav.com/support/manuals/xdm6350.pdf
Go to the "Installation" section and there is a wiring diagram there.
Posted on Jul 28, 2011
Do you know were I can get a wiring harness for DDA 650W VALOR car stereo
no wiring diagrams found
only this
Features:
6.5" Double Din Size Fully Motorized IN-Dash Monitor w/DVD;
2 DIN;
16:9 Wide Screen;
Compatible with DVD/VCD/CD/MP-3/CD-R/CD-RW;
"True All-In-One" (no separate brain);
Built-in DVD;
AM/FM radio tuner;
Wireless remote;
3 video inputs;
1 aux input;
2 video outputs;
Front and rear audio outputs;
Subwoofer output with adjustable crossover;
Center channel output;
Reverse signal input for camera;
Dual zone playback function;
AC-3, Dolby Prologic II;
Dolby digital surround (5.1CH) audio output;
PAL/NTSC compatible;
DVD/CD changer interface;
5 x 45 watts;
Oct 23, 2016 | Cars & Trucks
I need the total wiring diagram for camera [8pin rj11]
8 pin RJ45 (8P8C) male connector
at the camera output
LG LVC-CY100NM Color Security Camera with 8-pin RJ45 (and other cameras for the LSP-M1017M Dual Quad Observation Systems by LG)
Pin
Number Pin
Name Description 8 SPK Speaker (Hot) 7 VID Video Out 6 GRN Ground 5 SPK- Speaker (cold) 4 AO Audio Out/Alarm Out 3 VDC 12VDC 2 N/C RS-485- 1 N/C RS-485+ Note: Pin numbers are labled backwards in the manual (corrected above).
The camera is adaptable for use in any composite video application with the use of a balun.
on the output. I had noise-less video and clean audio across a 350 foot run of cat 5e.
Jan 29, 2013 | LG LVCCy100NM Color Security Camera with...
It wont turn on the power button just lights up red
you may have the constant and ignition power wires hooked up to the wrong wires.
Jan 31, 2011 | Dual XD7600 CD Player
Just installed Dual XDMA6330 has no power no lights no sound
the red wire needs to go to a switced power source. unless both the red and yellow wires are getting power, the deck will not turn on.
Mar 12, 2010 | Dual XD7600 CD Player
Need wiring diagram for a ge triclad motor
Not all motors are dual voltage, the motor must state on th ename plate that it is dual voltage and can operate on 115
Oct 23, 2009 | Air Tools & Compressors
I just bought a Dual XDM6820 and installed it myself into my 2000 Toyota Rav4. The unit worked great for two days. Then I went on a road trip and the unit blew a fuse. I replaced the stereo fuse and the...
If the cd's come in and out fine then it has something to do with key wire (red) . I try and always use and a adaptor harness when installing aftermarket decks. Make sure your wires are well inulated and not pinched when deck is "in its place".
Jul 21, 2009 | Dual XD7600 CD Player
Need wiring schematic for output wiring.
Black is ground, yellow is constant power, red is switched power (only has juice when vehicle is on) dual grey, dual white, dual etc, are speakers, and blue is remote accessories like and amp or eq
May 17, 2009 | Clarion ARX6470
Unsureness of wiring configurations.
Mamola,
Get an amp with at least 200 Watts RMS. The RMS value is what is important about driving Subs. This could be proclaimed to be a 1000 Watt amp. REad the RMS value.
Wiring. It is better to series your Speakers to give them and your amp more reliability,
Get a Mono or Bridgeable amp. If it si bridgeable, BRidge the output as described in the manual you get. Some Amps have a diagram right on the output..
AMP+ to Sub1 +
Sub1 - to Sub2 +
Sub2 - to Amp -
Get a 4 Guage wring kit. Run your power wiring down the Drivers side, and Audio signal wiring down the Passenger side, keep the two separate.
Nov 26, 2007 | Kenwood 12" 4-Ohm Single-Voice-Coil...
Subwoofer wiring diagram
parallel wiring. hook all 4 positives together and run to the positive output from the amp, hook all 4 negatives together and run to the negative output from the amp.
hope this helps,
trin
Nov 19, 2007 | Car Audio & Video
Aug 07, 2007 | Dual XD7600 CD Player
Dual XD7600 CD Player Logo
Top Dual Car Audio & Video Experts
xxxxxx xxx
Jeff Turcotte
Jeff Turcotte
Are you a Dual Car Audio and Video Expert? Answer questions, earn points and help others
