Question about Sunbeam Coffee Makers & Espresso Machines
Why doesn't the group handle of my new sunbeam EM7000 coffee machine attach properly and the water level warning light comes on eve though there is 1 litre of water still in tank?
Thought I was "updating" from the EM6101 but maybe this wasn't such a good idea
4 Suggested Answers
SOURCE: No water is being pumped at all
I got through to the tech support at Breville and they helped me fix this problem. What they had me do was:
1)Fill the water tank all the way up
2)Turn the power on and wait until the heating light turns off.
3)without coffee in the head turn the machine to espresso mode and let it pump for a minute.
4)after a minute turn to standby for a couple seconds then turn it to steam mode for a minute.
5) after this minute is up turn it back to standby for a couple of seconds and then back to espresso mode.
6) the technician said to do this seven times, but mine started working after three or so. The tech said the fixes about 80 to 90 percent of machines with this problem.
Good Luck!
Posted on Dec 26, 2007
cardenderek
  • 783 Answers
SOURCE: Gaggia Syncrony Digital red water light #27,
sounds like the computer is burning out.
Please accept this solution if you have no further questions! Thank You!
Premium FixYa support
Posted on Jul 29, 2011
  • 115 Answers
SOURCE: i got problem with my expresso coffee machine, its
Hi, It the group solenoid behind the leaking group. Try giving it a good back flush or remove the solenoid, pull it apart and try cleaning it. If you have a Boema machine, just replace the solenoid. Dazza
Posted on Sep 23, 2011
Pressure valve
Generally, this is not a problem with the machine but with how you're loading the coffee! Sounds typical of one of these problems:-
Not enough coffee in the basket
Coffee should be filled and tamped to about 3mm below the rim.
Coffee grind not fine enough (too coarse)
Do you grind your own coffee or buy ready-ground? If buying ready-ground, make sure it is for espresso (fine) and not for filter or plunger.
If you have your own grinder, (like the Sunbeam Conical Grinder), then make sure the coffee hopper on top is securely connected to the grinder. I'd been using mine for years on the the finest grind (1) not realising the hopper wan't on right. Only discovered it when I took it apart to clean. Now my grinder is on 9-10 to grind for espresso.
Coffee not tampered down hard enough
You do need to provide a reasonable degree of pressure to tamp he coffee down just right.
Group head not turned tight enough
Push the group handle as far to the right as it will go, then ease it back just a fraction to have the right pressure.
Jun 22, 2014 | Sunbeam Cafe EM6910
No water coming through
Depending on if this is HW or Group water... But if you did not clean teh shower screen and group first; you have loosened scale and it is caught in the HW change over valve.
Mar 20, 2014 | Sunbeam Cafe EM6910
Low water warning light flashing when water level is not low
The water level sensor is based on a floating magnet. The magnet breaks out of it's holder in the water tank. Remove the water tank via the door on the back of the machine, tip the water out (and the magnet will probably come out too). Put the magnet back in the housing down near the water valve, and wedge the black lid on with a bit of plastic. Refill and enjoy coffee.
... or put some black tape over the red light.
Feb 13, 2014 | Sunbeam Coffee Makers & Espresso Machines
Ours does not finish cycle either!!! The machine runs through the cycle up until the point where water should enter the "brew group". The coffee doesn't come out. What shall we try?
I just fix that problem by opening the water flow meter by some coffee grinds, also had a little coffe grind jamming a check valve that is at last of the water pump flow, now is running pretty well
Dec 20, 2012 | Saeco Easy Espresso Machine
Sunbeam cafe series EM 6910 coffee machine little red light keeps flashing
That's the low water warning, triggered by a black float with a magnet inside, in the water container.
The magnet inside the float in the water tank loses its magnetism with age.
Buy a replacement on eBay for a few bucks.
You cannot repair it, but the machine will continue to work fine without it - you just won't get a signal when your water is about to run out.
Nov 17, 2012 | Sunbeam Cafe EM6910
Fracino little gem coffe machine manual
visacrem intternational limited
FRACINO COFFEE MACHINES
THE LITTLE GEM
INSTALLATION INSTRUCTIONS
.REMOVE PLASTIC BUNG & FILL TOP TANK WITH COLD WATER TO TOP (N.B WATER SHOULD BE SOFTENED)
.PLUG MACHINE IN & SWITCH ON AT MAINS
.TURN MACHINE ON (ON/OFF SWITCH ON SILER PANEL JUST UNDER FRONT RED PANEL- NEXT TO GROUP)
.RED NEON AND AMBER NEON LIGHTS WILL ILLUMINATE AND THE MACHINE WILL START TO FILL
.OPEN STEAM VALVE (TURN RIGHT HAND BLACK HANDLE ANTI CLOCKWISE)
.WHEN WATER LEVEL REACHES THE YELLOW LINE ON THE SIGHT GLASS THE LIGHT WILL GO OFF AND
THE MACHINE WILL CUT OUT
REFIL THE TANK AND THEN TURN THE ON/OFF SWITCH OFF AND WAIT 5 SECONDS TURN THE ON/OFF
SWITCH BACK ON THE MACHINE WILL CONTINUE TO FILL
.WHEN THE WATER LEVEL REACHES THE TOP RED LINE ON THE SIGHT GLASS THE RED LIGHT WILL
GO OUT THE AMBER LIGHT WILL REMAIN ON UNTIL THE WATER REACHES THE CORRECT LEVEL AND THEN
GO OUT
.THE MACHINE WILL NOW START TO HEAT THE WATER WAIT FOR STEAM TO COME OUT OF THE STEAM TUBE
(BETWEEN 5-10 MINS APPROX) AND CLOSE THE STEAM VALVE (TURN RIGHT HAND BLACK HANDLE CLOKWISE)
.WAIT FOR THE PRESSURE TO COME UP TO 1-2KG/CM3 (PRESSURE GAUGE ON FRONT OF MACHINE BETWEEN
THE TWO BLACK HANDLES)
.THE MACHINE IS NOE READY TO USE
.PUT EMPTY FILTER HOLDER INTO THE GROUP AND FLUSH WITH WATER BY TURNING ON RED SWITCH NEXT
TO PRESSURE GAUGE AND LETTING WATER RUN THROUGH THIS PROCESS WILL TAKE SOME TIME AND USE
APPROXIMATELY HALF PINT OF WATER THE GROUP AND FILTER HOLDER SHOULD BE HOT - CHECK BY
TOUCH IF THEY ARE NOT HOT LET WATER CONTINUE TO FLUSH THROUGH UNTIL THEY ARE AND THEN
TURN RED SWITCH OFF
.MAKE A TEST CUP OF COFFEE THIS FIRST CUP WILL PROBABLY BE COLD BUT AS YOU MAKE MORE CUPS
OF COFFEE THEY WILL GET HOTTER IF POSSIBLE LEAVE THE MACHINE TO STAND FOR APPROX 30 MINS
BEFORE MAKING COFFEE THIS WILL ENABLE IT TO WARM UP AND PRODUCE COFFEE AT THE CORRECT
TEMPRATURE.
HOPE THIS IS WHAT YOU WERE LOOKING FOR ITS WHAT THEY GAVE ME WHEN I GO MINE FROM THEM.
IF NOT HERES A LINK TO THE PARTS MANUAL AND CATALOG
http://www.fracino.com/technical/parts.html
http://www.fracino.com/machines/hand-fill-coffee-machines/little-gem.html
http://www.vendingexpress.co.uk/uploads/pdf/product-fracino-little-gem-automatic_4e7a1df44be5d.pdf
Jan 20, 2012 | Coffee Makers & Espresso Machines
Hi i have bodum grandos espresso, i need a new group head and water tank where can i find in Sydney?
Hi I have the same machine that has been taken apart and so it's now a pile of spare parts. When you say new group head, do you mean the collar of the group head, or do you need a new group handle and basket ? I live in Sydney if you want to get in touch.
Mar 25, 2011 | Bodum GRANOS (3020-16US) Espresso Machine
My titanium is no longer extracting properly, getting weak bitter coffee water instead. The upper filter in the brewing group is now loose, instead of screwing in you can now pull it out with the plastic...
There shouldn't be a way for that metal filter disc at the top of the brew chamber to come out without unscrewing the plastic thumbscrew on top. If you are saying the disc will slide out, or fall out, while that plastic thumbscrew is still tightened onto the threaded, metal shaft on the disc - then your brew group must be broken or you aren't putting it together correctly. That disc should push up into place with the threaded shaft poking up though the small hole - then the plastic thumbscrew should twist onto the threaded shaft and tighten down to pull the disc tightly up in place. If that doesn't happen, then the filter won't be held in place tightly so the water can leak around the filter and of course the coffee would be watery and weak.
Mar 21, 2011 | Gaggia Titanium Espresso Machine
Have a Gaggia Cyncrony Compact Coffe Machine that doesn't brew!
Has the machine been de-scaled recently? I would run a descaling solution through the machine first to eliminate that.
Jan 15, 2010 | Gaggia Syncrony Compact Coffee...
My e61 group head on my Diadema UNICO Splendor exhaust port probs
There might be one of 2 things going on,
1- the exhaust tube is blocked.
2- one of the three gaskets in the group is on backwards.
Jul 24, 2009 | Coffee Makers & Espresso Machines
Coffee Makers & Espresso Machines Logo
Top Sunbeam Coffee Makers & Espresso Machines Experts
ray gallant
Gil Shultz
Are you a Sunbeam Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
