Question about Emerson Pool & Spa
Looking for an EMERSON T55MWCCE-1208 2.5 HP ELECTRIC MOTOR and pump that goes on a fiberglass Imperial spa.
The shaft is corroded and frozen. Does the pump unscrew from the shaft, and if so, which direction?
    Top Expert:
  • Emerson Master
  • 6,949 Answers
If shaft corroded then motor bearing are soon to go and if motor was overheating just replace whole unit less hassle
Posted on Oct 11, 2017
  • 8404 Answers
SOURCE: Great Lakes Spa pump. Any way to diagnose outside
If I understand your question, your spa pump will not spin up.
I believe your start capacitor has failed. Remove the back from the motor, you will see the black capacitor on the left hand side. There are several wires coming out of the capacitor. Somewhere on the body is a number. Get a preplacement from a FixYa.com advertiser, your community pool supply company or at www.repairclinic.com
Be careful as you service this electric storage device. Also, make sure you wire the new one exactly like the old one.
I believe this minor service operation will get your pump rolling again.
Thank you for posting at FixYa.com
Please vote
a
Posted on Nov 10, 2009
SOURCE: High speed spa pump shuts off
The motor may have a thermal cutoff if the motor draws too much current. Do you have a sufficient large gauge circuit supplying the motore? If not the actual voltage at the motor may drop, causing it to draw more current to make up for the loss of voltage, thereby tripping the motor's protective breaker. I assume the motor will start again after serveral minutes of cooling down.
Curtis
Posted on Apr 19, 2009
  • 93 Answers
SOURCE: I have an A.O.Smith Century Pool & Spa motor
THIS IS LIKELY CAUSED BY SOMETHING IN IMPELLER TURN OFF POWER SEE IF YOU CAN SEE ANTHING IN IT YOU HAVE TO TURN HANDEL VALVES OFF PUSH DOWN IF YOU HAVE TO OPEN PIPE IN FRONT OF PUMP I
Posted on Jun 20, 2009
  • 8404 Answers
SOURCE: my emerson spa circulation pump 1563, model
Is this pump for a 'in ground' body of water or for a fiberglass spa?
Someone MUST make something similar.
If yours is in ground you have many options based upon your filter media and the size of the suction and discharge lines.
If you can give me more information, I can more than lilely answer your question.
Let me know ... I want to help
a
Posted on Oct 10, 2009
big-dog420
  • 124 Answers
SOURCE: water works spa pump- need to remove wet end...
Most of these are reverse threaded. There should be a place on the shaft that is flat on 2 sides a 1/2" or 9/16" wrench will fit into the slots. If not look at the back for a place to use a hex key. Hold the wrench/ hex key stationary with the Impeller facing you turn clockwise.
I know this sounds backwards but it should work.
Hope this helps
Please leave feed back
Posted on Dec 01, 2009
My Emerson motor model k63cxese 4792. It is making a loud noise. I was told the capacitor might be bad. Does anyone know how to replace the capacitor? Thank you
Capacitors don't make noise. The purpose of a capacitor, is to provide a jumpstart to assist the motor to begin spinning. What makes a pool motor noisy, is bad bearings. At one point or another is possible that your mechanical pump shaft seal had failed, and allow the water to enter the electric motor, and wash away the lubrication in the front bearing.
either replace the bearings or the motor.
Dec 05, 2013 | Emerson THREADED SHAFT UP RATED - 1.00 HP...
How many orings
Emerson does not make the pump, they only make the motor. You need to find out the manufacturer and model of your pumps volute,(wet end or "plastic part")..., before I can help.
oskopoolnspa.com
Nov 30, 2013 | Emerson Pool & Spa
I'm trying to find a seal kit for a Emerson spa pump Model #T55MWCCE-1208
The seals are specific to the Jacuzzi pump housing not to the Emerson motor. Most Jacuzzi pumps use the PS-200 or PS-201 seal (some have it listed as AS-20X) here is a Pump Seal Cross Reference.
Jul 25, 2012 | Emerson Pool & Spa
I have emerson 1081 (model # K63CXETN-4820) pool motor. I am looking for impeller for this motor. Can you plz point me to where can I get the impeller?
that motor will fit all sorts of pumps, YOU NEED TO KNOW WHAT KIND OF PUMP you have,, hayward,jacuzzi.. the motor pictured is a round flange.. look on ebay to see if you can find that looks just like yours ! than ask the question..
May 12, 2011 | Emerson THREADED SHAFT UP RATED - 1.00 HP...
Where can i order the impeller (center dish cover) for a emerson 1081 3/4 hp pump
The impellers for the motor depends on the actual brand of pump that the motor is actually bolted up to. Impellers are available anywhere and once you can let us know what the actual model of the pump (should be a Hayward, Jandy, or it may be an off brand) we can not only provide you with the part number, but also a location where to purchase. What is probably happening is that you are searching for the impeller for an emerson, instead of looking for the imepller for the appropriate pump.
Feb 07, 2011 | Emerson THREADED SHAFT UP RATED - 1.00 HP...
Where can I find parts for the old emerson electric motor in my spa? it is an emerson c55cxfby-3475 and I am looking for replacement springs that are for what appears to be a centrifical or heat control...
You're most likely looking at the starting circuit centrifugal switch. It is probably not cost effective to try and repair that motor. Depending on HP and frame, you should be able to buy a new motor for 100.00-200.00. Instead of buying from a pool company, buy from a motor shop or from a place like www.grainger.com Main information to have if replacing with different mfg will be HP, RPM, Voltge, and important frame number.
Jul 24, 2010 | Emerson Pool & Spa
How do I get old motor off pump to install my new motor?
The front of the wet end must be removed to access the impeller. Then remove the rear electrical covering to expose the rear end of the motor shaft. Look closely at the shaft. It has two flat sides. A 12mm open face wrench will fit onto the shaft. Lock the shaft in place with the wrench and unscrew the impeller. The rear housing behind the impeller pops off to reveal four 9/16 bolts. Remove them and the motor is free. Reverse the process with the new motor.
Apr 22, 2010 | Emerson THREADED SHAFT UP RATED - 1.00 HP...
Emerson EB228 pump motor fails to start.
There is no fuse. If the pump is several years old, it is likely frozen. You might try removing the back of the pump cover and inserting a screwdriver into the shaft to turn it by hand. Disconnect electric first. If the shaft turns, it's an electrical problem. If the shaft does not or is hard to turn, rust has frozen the shaft in place and the pump will not run. Buy a new motor.
Apr 19, 2010 | Emerson THREADED SHAFT UP RATED - 1.00 HP...
Pool & Spa Logo
1,498 people viewed this question
Top Emerson Pool & Spa Experts
Jay Finke
Jay Finke
Mike
Ian Kime
Ian Kime
Are you an Emerson Pool and Spa Expert? Answer questions, earn points and help others
