When Ii tried to open my Windows Vista on my Toshiba laptop which is only 15 months old- the screen was blank except for the following message- "The User Profile Service service failed the logon- user profile cannot be loaded" - below that mwessage was a box with OK in it- when I clicked on Ok I was logged off the computer. I cannot reach anything on the computer- or open anything. I need help!
  • 2 more comments
  • dixee55 Jan 07, 2009
    THANKS FOR OFFERING THE ADVICE- IT DIDN'T SEEM TO WORK HOWEVER.
  • Kim La Apr 14, 2009
    When i try to log on unto my profile i keep getting this message...."The User Profile Service service failed the logon- user profile cannot be loaded" HELPPPPPPPPPPPPPPP
  • Anonymous Mar 13, 2014
    cannot log on
    can not log on.
    Master:
    Sergeant:
  • 482 Answers
Take out the battery and unplug the power cord, plug back in and replace the battery, and start it up.
Posted on Jan 05, 2009
When I turn my Toshiba A45-S151 laptop on, I first get the screen that shows the Toshiba logo and has the four icons under the logo. Usually the next screen is black, has a cursor in the top left corner,...
That blinking cursor is the way in which the BIOS is telling you that Windows is not loading because its most critical, core files have been corrupted beyond repair. The only thing you can do is to reinstall using the recovery cd or your own Windows install disk.
Oct 18, 2010 | Toshiba Satellite A45-S151 Notebook
The Toshiba Satellite Laptop ater shutdown and
Get it with windows 7, Vista has too many problems
Mar 15, 2010 | Toshiba Satellite Pro L300 Notebook
Blank Display, using exernal monitor, can see display info w/flashlight, display flashes light at startup
You could have a defective screen - a defective inverter or a CCFL lamp.
To determine if you have a LCD screen or video card problem, read this and follow the instructions.
Defective CCFL backlight, it may have the following symptom:
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display.
  • Picture flickering on and off.
All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
May 03, 2009 | Toshiba Satellite A135-S4407 Notebook
Black screen w/blinking cursor
So.. you can select safe mode? Or you turn it on and it is resuming into the blank screen?
If the latter. Unplug the power, pull the battery out for 20 seconds or so. Then put it all back together and try booting up.
Apr 19, 2009 | Toshiba Satellite A100-S8111TD Notebook
BIOS Update Problem
If your laptop is only 3 months old it should be covered by warranty with Toshiba, the best course of action would be to consult them regards this issue.
Mar 22, 2009 | Toshiba Satellite Pro L300D-EZ1006V...
Computer turns on but screen wont
First,If you are running windows vista,This can be due to an update that has your video driver and windows video driver running at the same time.
Hardware would be the invertor board is bad.
Ttry to start with F8 and choose start in vga mode,If this allows you to start normally,go to the device manager and update the video drivers
Feb 22, 2009 | Toshiba Satellite P205-S6337 Notebook
Toshiba Satellite A300 blank Screen with cursor Vista won't load
Compatability Issue with Vista.
Likely to be a Hard Drive Issue.
Dec 09, 2008 | Acer Aspire 3690-2196 Notebook
URGENT CALL: Critical Error that keeps cutting out AOL
GO Here and download the Hotfix at the top of the page.. (click on the Hotfix Icon, and follow directions..
http://support.microsoft.com/kb/937063#
it is for vista home basic as well......
then lemme know again
Jun 11, 2008 | Toshiba Satellite A135-S4527 Notebook
Display driver r300
Solution #2 (April 15th 2008) fixed it for me. Very easy to do and my Fujitsu Amilo whatever plays everything fine on full screen again. Thank you for your help.
Jul 27, 2007 | Toshiba Satellite A135-S2276 Notebook
Computers & Internet Logo
154 people viewed this question
David Payne
David Payne
