Question about Maytag SDE3606A Electric Dryer
Dryer Not Tumbling
My Maytag SDE3606AYW is not tumbling so I have gone about trying to get to the motor and belt to see what the problem is. However I am having problems. I have gotten the small bottom panel off on front of the machine but I can't get the top off. I've unscrewed the two screws from the back and can lift the top off but it is still attached at the front of the machine. How do I get it fully off? Is this the proper way to get to the motor and belt?
Thanks.
If you are talking about the front of the machine, above the SERVICE ACCESS PANEL, then after you remove the screws at the bottom of the FRONT PANEL, pull the panel toward the front and the top of it will pop out. It is in place with small GUIDE SCREWS and a couple of removeable clips.
If your barrel is not tumbling you probably have a broken BELT and it needs to be replaced. Easier to do this from the back I think. It goes all the way around the barrel of the dryer, so you have to put it on the barrel then attach to the IDLER PULLEY and SERVICE BOLT.
Posted on Oct 16, 2009
Not tumbleing but heats up in every position even after replacing temp switch.
Posted on Jun 23, 2009
Why does my Neptune moder number mce8000ayw dryer not tumble?
If the motor runs, but the drum doesn't rotate, check the belt, part # 341241. It's probably broken and off of the drum.
May 14, 2014 | Maytag Neptune MDE5500AY Electric Dryer
Not tumbling
check the pully on the motor and check the tention of the drive mechanism. It's usually a belt around the drum.
Jan 24, 2014 | LG DLE5977 Electric Dryer
Where is the belt located?? This maytag legacy elec dryer is 4 yrs old. over the last few mths it has made louder sqeaky noises but now all of a sudden it stopped tumbling!! It still heats up like it's...
it is inside the dryer, you will need to disassemble the dryer here is a website that may help:
http://www.partselect.com/dryer+dryer-wont-tumble+repair.htm
diagram of belt routing:
http://www.applianceaid.com/images/belt-config.JPG
Good Luck Tim
Feb 09, 2011 | Maytag MDE308DAYW Electric Dryer
What would make a dryer stop tumbling? It is about ten years old now. It turns on alright but just won't spin anymore. Its a MayTag so shouldn't it work forever! LOL
Probably just a broken belt. Unplug the dryer and open it up (PIX BELOW) clean out the dryer and inspect the wheels idler and blower cage.The belt is probably gone after 10 years. Here are some repair pix
Aug 28, 2009 | Dryers
My COSTCO Whirlpool dryer SEDS 800 JQ0 heats but won't tumble.
There is usually a friction drive belt inside the unit that turns the drum. Check for a broaken belt or a defective drive motor. Usually it is just the belt.
Jun 20, 2009 | Maytag 7.0 Cu. Ft. Electric Dryer
Maytag dryer won't rotate after blower wheel replacement
Check the drive belt and belt tensioner. From the way you describe it, the belt is loose and with a load in the drum, it will not rotate due to belt slipping.
Jun 03, 2009 | Maytag Neptune MDE5500AY Electric Dryer
It is heating up but not tumbling correctly
Drive belt for the drum is probably broken and needs to be replaced.
May 27, 2009 | Dryers
Dryer will not tumble
HI your right on the money , it is the belt. replace thanks.
Oct 11, 2008 | Maytag PYE4557A Dryer
Maytag elc dryer
Your drive belt is old and has glazed. It will likely break soon. Replace it. Make sure the belt contact area is clean and free of any kind of dirt or grease.
Dec 05, 2007 | Maytag Atlantis MDE7400AY Electric Dryer
Maytag SDE3606A Electric Dryer Logo
377 people viewed this question
Top Maytag Dryers Experts
Mike Cairns
Mike Cairns
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
