Question about Opella Plumbing
Opella black strainer basket will not hold water in the sink
It is difficult to get strainer basket to hold wager. Exactly how do you put the basket in the holder?
  • 11 Answers
SOURCE: peeling paint coming off of oil rubbed bronze basket strainer
Bronze is more expensive than standard mass production is worth, i supposed if you want them made out of any mat. you can call kohler and pay for it, i've been to their plant and they do some pretty awsome custom work.
Rubbed oil is just a color and somtimes "you get what you pay for" if you buy a cheap basket strainer they usually do exactly what you're saying.
You can buy more expensive strainers that have a better finish, I know Kohler and Moen have lifetime warranty finish on many of their higher end products.
Posted on Jun 06, 2009
  • 21 Answers
SOURCE: How do I know which Garvin Basket Strainer to
I would suggest you replace the entire basket strainer. I can honestly say that in 30 years I have never seen two that were alike.
Posted on Nov 27, 2009
  • 122 Answers
SOURCE: Trying to find basket strainer for Kohler vast
all of kohlers baskets fit their sinks, even older model sinks.
do you have a special strainer, or sink?
have you contacted Kohler direct? or one of their distributors. a wholesale plumbing supply house (NOT lowes or home depot) in your area will be able to help you also
Posted on Aug 15, 2010
SOURCE: Moen basket strainers for Corian
I'm not sure what your question is, or if you are posting information.
Plumber's putty is purchased at local home center, hardware, plumbing outlet.
Container is smaller than coffee cup, and 3 times heavier.
Material is gray and thick and slightly oily and not sticky on the fingers.
Clean sink opening.
Apply fairly thick amount of putty completely around sink opening. About 3/16" thick.
Putty should extend wide enough so sink basket sits entirely on top of putty.
Push sink basket down into putty.
Tighten sink basket very firm from below.
Wipe away excess putty inside sink bowl with finger, and then a paper towel or damp sponge.
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on any do-it-yourself project.
Fixya is always less expensive than a service call.
Posted on Jan 15, 2011
  • 1267 Answers
SOURCE: we are installing a new
If you have a garbage disposal, use standard strainers, but depending what may go down if not, such as hair, fiberous material that will get stuck in grease, then use the basket strainers.
Posted on Jan 22, 2011
How much plumbers putty do I bead around when installing a repacement?
I recommend between 1/4 to 1/2 inch bead of plumbers putty. Slightly flatten the bead on the strainer pushing a little past the outer edge then press it firmly into sink and remove any excess from below sink before installing rubber ring and lock nut tighten firmly but do not over tighten adust drain to center in hole retighten slightly if necessary and remove any excess putty from around drain. Hope this helps.
Bob
May 23, 2014 | Opella Strainer Waste Assembly OPELLA...
Leak at new strainer waste fitting
Did you put the rubber gasket and cardboard sleeve on the bottom of the sink(next to the nut and did you use plumbers putty on the top part of the sink under the top section of the basket. Hint if you put some soap on the gasket under the sink between it and the nut it will be easier to tighten also you must secure the top part of the basket as you turn the nut if not the plumbers putty will not seal. If you do not have the strainer basket holding tool wrench you can substitute with a pare of needle nose pliers. Large channel locks or pliers can work to turn the large nut on bottom. If you can recruit a helper to hold the top part of the strainer basket with the needle nose pliers it make the job of tightening the large nut easier. When a large amount of the plumbers putty has squeezed out and the strainer is flush with the sink you should have a tight seal.
Feb 24, 2012 | Blanco Plumbing
I have an opella disposer flange assembly in my sink that needs to be replaced. How do I get it out? It looks like it may be a snapin unit. Thanks George
They don't list the 90190.20 any longer this is what is avalible http://www.opella.com/en/901882/
And this is the only place I could find the buy this item although I am sure there must be more.
Non of these places give install instruction but they should come with the new parts.
http://www.vintagetub.com/asp/product_detail.asp?item_no=OP90188.06&utm_id=IDK1L#FULLPRODUCT
Mar 14, 2011 | Opella Disposer Waste Assembly OPELLA...
What is the difference between standard strainer and strainer for food erator? I bought a replacement sink wiht standard strainer, which does not seems to fit garbage disposal
If you need new sink strainer basket for disposal side of sink, you have to buy new disposal.
Each garbage disposal comes with its own strainer basket so that disposal can connect and seal.
First, the disposal strainer basket is installed, and then disposal lifts up and attaches from below.
A rubber gasket comes with new disposal.
Rubber gasket fits between disposal and strainer basket so that disposal seals correctly.
Photo below shows how disposal connects to strainer basket using steel connector ring under the sink.
I wrote tips for installing a disposal from days when I worked apartment maintenance.
http://www.fixya.com/support/r7929008-replace_garbage_disposal
Feb 16, 2011 | Franke 900 Black Basket Strainer 900
Difference between black basket strainer 900 and regular strainer.also i want white. are there different sizes or universal.
Unless you have a special purpose sink all basket strainers are standard size. You should be able to use strainer from any manufacturer that has the color that you want. If you are doing this yourself make sure you use rubber gasket and fiber friction ring. These go on the underside of sink in between sink bottom and retaing nut. I would recommend you use a small amount of pure silicone caulking in between flange of strainer and sink surface. Be ready to wipe off excess caulking as soon as you get retaing nut snug as it starts to cure in about ten mins. I use paper towels and wipe till its clean. Hope this helps. Thanks
Nov 16, 2010 | Franke 900 Black Basket Strainer 900
Basket, silcone, sink, white gasket, black rubber, drain pipe? Is this correct?
basket
silicone (or plumbers putty)
sink
black rubber
white gasket
strainer nut
vinyl tailpiece washer
tailpiece (drain)
tailpiece nut
Nov 03, 2010 | Kindred 1135 Standard 3 1/2 inch Basket...
Is the cucina strainers conpabable with a kohler porcelain sink ?
I'm not exactly familar with this specific strainer but can tell you that they are very standardized in size (sink penetrations and strainers that is)...I've done 20 or more personally.
Aug 04, 2009 | Cucina DECORATIVE BASKET STRAINER -...
Peeling paint coming off of oil rubbed bronze basket strainer
Mar 03, 2009 | Mountain Plumbing Mountain Basket Strainer...
I need a new franke sink basket strainer for my franke sink model PRX11021 - stainless steel. What is the model number that will fit this sink and can I order it online or go to a local store?
You should purchase a complete basket strainer assembly. Home Depot or Lowes have some very nice ones. They are a standard size.
Tell them it's for your kitchen sink.
Jan 28, 2009 | Plumbing
Plumbing Logo
95 people viewed this question
Top Opella Plumbing Experts
Andrew Bugbee
Tom Chichester
Gil Shultz
Are you an Opella Plumbing Expert? Answer questions, earn points and help others
