Question about Amana Refrigerators
How do you defrost the freezer of an amana arb2205cc? The door was left ajar causing it to frost up.
HVACRH20
  • 237 Answers
SOURCE: Freezer left open and now won't work
Try to unplug the unit from the wall and let it sit for a few minutes then plug back in. May reset the door alarm lock out. Also, moisture in the air can be drawn in and freeze up the whole thing. That means turning it off with doors open for about 36 hours... Moisture is a killer in a freezer, freezes and blocks up every air circulation vent, etc.
Posted on Nov 09, 2006
  • 1462 Answers
SOURCE: Freezer was left ajar & now Refrigerator does not work properly
you have ice build up on the evaporator. two ways to cure. first switch off for 24 hours and leave with doors open. second switch off. remove back panel inside freezer and melt ice off with a hair dryer
Posted on Jul 09, 2007
bobicehouse
  • 1524 Answers
SOURCE: Ice Maker stopped working
You need to defrost the freezer. By the door being ajar, there was excessive ice build up on the coil that was not removed during a system defrost resulting in a blocked coil. This caused the temperature to rise in the freezer above twelve degrees that is why the ice maker stopped.
Posted on May 19, 2009
Sea Breeze
  • 4654 Answers
SOURCE: Is there a way to disable the frost-free feature on amana freezer
Unplug your refrigerator and open the rear panel in the back of freezer. Disconnect one whire on one end of the defrost heater. Tape the wire up and you'll be good to go no defrost. Sea Breeze
Posted on Aug 19, 2009
  • 7 Answers
SOURCE: Samsung refrigerator - frost on outside of freezer drawers
try checking the freezer door seal.
if slight gap anywhere around the door seal drawer fronts will frost up.
warm seal up with hair dryer and ease seal out with your hands..
problem often happens with door reversal.
Posted on Oct 09, 2009
Amana bottom freezer unit warms, then resets after being left unplugged
If the door does not shut correctly, humidity enters the unit and condenses inside. The defrost function is not designed to work properly under such a condition.
Ice (frost) builds up around the cooling coils, and actually insulates them, so you don't get good cooling. When you unplug the unit, the frost melts, runs into the bottom tray beneath the unit (can't see it).
When you turn it back on it cools like it should until the frost builds up again. You need a good gasket and a door that is adjusted properly. You also need the unit level at least side to side, but front to back also is preferable.
The unit has front leveling feet, and the back usually adjusts itself with self-leveling feet. The adjustments for the door are metal bars inside it, behind the inside storage panel.
The hinges are also adjustable. Sometimes the door sags from heavy things stored inside it. You must loosen the hinges a bit, lift the door and hold it while you tighten the hinges.
Sometimes the unit can be unsalvagable, because it's been situated incorrectly for so long that it's permanently bent out of square.
OR, the defroster clock might be bad.
Jan 20, 2014 | Refrigerators
We left for the weekend and our freezer door was left ajar. Upon returning, we reset the temp., but the freezer never got below 17 and then it shut off again. Is it a complete loss?
It is possible that an excessive amount of moisture was introduced into the freezer compartment while the door was ajar. If there is excess frosting on the walls or around the door seal, defrost the unit and see if it cools better.
Jan 20, 2013 | Refrigerators
Frost every thing
I assume you mean frost in the freezer only, not in the refrigerator compartment.
There are a lot of mechanical problems that might cause frost to build up. The unit has a defrost timer to defrost the freezer and it might be broken.however, more likely, the freezer door was left ajar letting a small amount of outside air in, which condensed and froze.
Check to see that freezer door is fully closing and is not being block in any way. Recheck after 6-8 hours and see if frost is gone. If it is still there, repost your question along with make and model of your unit. J
Thanks for using FixYa - a 4 THUMBS rating and POSITIVE TESTIMONIAL is appreciated for answering your FREE question.
Feb 10, 2011 | LG Refrigerators
Amana French Door fridge not cooling
you have a problem here
you need to get the secondary defrost kit installed
it is not the jazz board
unless he is not programming it right aftwer install
but check your back wall for frost
if you have frost you have an airflow issue
whats happening is the door is being left ajar even a 1/16 gap is an issue
when hot air enters the unit fromn the gap it condenses on the diverter behind the freezer wall
after a few weeks it builds up enought o cause problems
there is a kit you can get that will divert electrical heat to the diverter and keep it warm enough to defrost it there by never having the issue again
Oct 07, 2009 | Amana Easy Reach AFD2535DE Bottom Freezer...
Door left ajar overnight,bottom emitter in freezer still cold&frosted,a motor running,is it fan or compressor,i.e.,which needs replacing,P.S.model3SRD21VW-how old is it!,worth replacing?
This could be several things, compressor, mother control board, defrost heater and defrost thermostat. I will help you find and fix your problem with the refrigerator if you like. Feel free to let me know, Sea Breeze
Jul 30, 2009 | Amana Refrigerators
Self defrosting deep freeze not defrosting
The excess frost in those areas is probably caused by leaky door gasket seals. They should be tight enough to hold a dollar bill securely all the way around. A defrost problem would start on the coils behind the back cover inside the freezer and would also appear on the back wall before it did on the door edges.
Jul 13, 2009 | Amana 19.6 cu. ft. / 555 liter Upright...
May 19, 2009 | Sub-Zero 561 / F
Amana abb222zde bottom freezer not defrosting
unplug the freezer. let it defrost for a day then plug it back in. You will be fixed up then.
Jan 29, 2009 | Amana ABB222ZDE Bottom Freezer...
Freezer only freezing to 20 degrez
If the door was left ajar for any extended period frost has built up on the cooling coils. A complete defrost of the freezer should take care of the problem. Normally a frost free system will clear the ice from the cooling coil when the defrost time cycle happens. However frost may have built up in areas where the heaters can not readily remove it in a normal defrost cycle and shutting the unit down with the door open for about 24 hours should clear it out.
Nov 27, 2008 | Freezers
Motor runs, some ice at top level, but temp is at 50-60 degrees.
Defrost the freezer. Door being ajar allows moisture to build on the freezer coil and stops air circulation. In frost free units this condition should clear itself after about 8-12 hours max. Locating and advancing the timer by rotating the clutch head screw clockwise slowly until you hear one click. This will start the automatic defrost manually.
May 19, 2008 | Sanyo SR-4912M
Refrigerators Logo
32 people viewed this question
Top Amana Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
