I have a RCA RC140-A clock radio. The time sets automatically, but is now 11 minutes fast. I cannot figure out how to reset the clock to the correct time. Would appreciate your help; thank you! Carie rowemc62@Gmail.com
SOURCE: HELP SETTING CLOCK
Turn the CD Player off and press and hold the function button.
Time should be your first option, just keep pressing function to go through the options if its not and use the arrows to change the time.
Posted on Feb 12, 2008
SOURCE: complicated GE clock radio/CD player
To set the time:
Hit the SET Wake/Time Button closest to the CD player until the clock face appears in the bottom left hand of the display.
Use the TRACK Rev Search Fwd Arrows to adjust the time.
Rev will decrease by minutes and Fwd will increase by minutes.
Hope this helps.
Posted on Mar 09, 2008
SOURCE: RCA RP5420 clock radio
Bob, My auto-set worked fine. I'd suggest setting the time manually (by sliding the top-rear slider all the way to the right and using the '<<rev' and 'fwd>>' buttons) if you are still having problems.
Posted on Mar 28, 2008
SOURCE: car radio - setting the clock
1. click on S (select) and choose clock and hold it (?) 2. click on bar v|<< >>|> to select H or M or Seconds 3. adjust it turning the volume button 4. repeat steps 2 and 3 for minutes 5. repeat steps 2 and 3 for seconds
Posted on Sep 09, 2009
SOURCE: RCA RP5420B 2Band AM/FM Clock Radio
At the top of the clock, there is four positions for the slider. The first is shown as a key, which I assume is the automatic time setting mode. The second is Wake 1, the third is Wake 2 and all the way to the right is a manual time setting mode. If you slide it all the way to the right, you can set the time, then either keep it in that mode or return it back to automatic mode. Either way, you now have the correct time displayed.
Posted on Jan 12, 2010
Set time on RCA dual clock radio with fashion wrap? RCR 8622
I love the form of your question, as I wanted to wing the sucker myself, but got online before I actually pulled an Office Space on it. I found nothing, but I DID actually figure it out. Not super intuitive though. To set the time: Hold down the memory key in the middle until the number flashes. Use the arrow up/down on the right to set hour. Press Memory key again, repeat with arrow keys to set minutes. Hit memory key again. Alarm: Press/hold the Alarm button until the Alarm 1 or 2 flashes and press the side you want, 1 or 2, to set. Arrow time up/down, then do minutes, press alarm 1 again, select alarm or tuner, press alarm 1 again. Now I need to see if it will work in the morning. I know the flipping time is set though! Good luck. If you wing it, please post photos! :D
Dec 11, 2014 | RCA Audio Players & Recorders
I need owners manual to program RCA RC140-A alarm clock
Hello
Send your Emai Address to me. I've the user manual for your RCA RC 140. I actually do not remember, from which site did I downloaded it. I can't send it to you by this window, as it does not allow me to upload PDF fiels by it. If you send your Email ID, I'll send a copy of it to you by return mail. OK.
Nov 27, 2011 | RCA Radio Alarm Clock
Sony clock radio with auto time set is always 4 minutes fast.
This is easily fixed. Set the time manually the 1st time. Make sure you use the CORRECT time, which is four minutes less than what the clock said when you first plugged it in. Once you reset the timing, it will remember the four minute difference and always show the correct time.
Sep 11, 2010 | Sony Dual-Alarm AM/FM Clock Radio with...
I don't know to set the time and alarm. Cd player isn't working but somtimes it does then not again!!! It's weird!!
You do not have to set the clock time
as a built-in automatic time set system
is equipped in this clock powered by 3V
(2 x “AA” batteries (included)). All you
have to do is to plug this clock for
power and current time will be shown
automatically.
Before plugging in for power, follow
the steps below to select time zone.
Setting Time Zone
You may slide the time zone selector at
the bottom of the clock to Pacific,
Mountain, Central or Eastern.
Refer to Figure 1 for U.S. Time Zone
details.
Refer to Figure 2 for Canadian Time
Zone details.
http://www.retrevo.com/search/v2/jsp/mytrevo/myTrevo.jsp?page=man
Jun 15, 2010 | RCA RP3740 Clock Radio
The auto time set on my Sony Dream Machine is five minutes fast and I don't know how to get it to sync properly. I've tried unplugging and plugging it in again, but it always comes back with the incorrect...
Have you tried to manually reset the time? I had the same problem. It got the the point where it was almost 20 minutes fast - I finally looked up the manual on-line and found instructions to manually reset it. It seemed to work just fine. I'm not sure if I have the same model as you do, but I'm sure the procedure is similar. I suggest you search the net for your manual.
Mar 05, 2010 | Sony Dual-Alarm AM/FM Clock Radio with...
Clock is 5-10 behind. How do I reset?
u will have to set the time zone you r in. If u don't know how to do that download the clocks manual from :
http://www.devicemanuals.com/guide/Radio/RCA-manuals.html
Aug 30, 2009 | RCA RP5440 Clock Radio
Need operating instructions for RCA clock radio Mod. 5430
The instruction manual will not help you, because it doesn't address this problem head on.  You're having this problem because the time changed, and the clock has an automatic setting.    As long as the batteries are in the clock and it's plugged up, it automatically computes the time. I just discovered the solution.  Unplug the clock, take out the batteries and WAIT about an hour.  Plug it back up, and the time will flash, allowing you to change the time.  You do this with the button on the top back which says wake up 1 and wake up 2.  Push that button all the way to the right to the setting that looks like a little clock, then press the forward button on the top of the clock to set the correct time.  Then put your batteries in and you're good to go!  (til the time changes again:)  Good luck!
Oct 27, 2008 | RCA RP5430 Clock Radio
Daylight Savings Times Changed
Directions for Resetting the Daylight Savings Time (DST) Start & End Dates on the Emerson Research Smartset Dual Alarm Clock Radio (cks5055s):
  • This should work for all Smartsets, but I cannot make the guarantee (and no, I don't have any other directions, sorry)!
  • Adjusting the DST Start Date on an Emerson Research Smartset:
    1. Depress & hold the MONTH/DATE and the ALARM1 buttons (at the same time). After 3 seconds the display will show the DST 'start' month, week, and date. It should be alternately showing "4 F" (April and first week week) and "4. 1".
    2. While still holding the MONT/DATE and the ALARM1 buttons, press the DOWN (or "-") button 3 times, until the display is showing "3" (March) and the week as "F2". It should alternately flash "3 F2" and "3. 11".
    3. After this is set, the clock should "automatically" reset itself
  • Adjusting the DST End Date on an Emerson Research Smartset:
    1. Depress & hold the MONTH/DATE and the ALARM2 buttons (at the same time). After 3 seconds the display will show the DST 'end' month, week, and date. It should be alternately showing "10 L" (October and last week week) and "10. 28".
    2. While still holding the MONT/DATE and the ALARM1 buttons, press the UP (or "+") button 1 time, until the display is showing "11" (November) and the week as "F". It should alternately flash "11 F" and "11. 4".
One thing to note, if you ever have to change the lithium backup battery for the Smartset clocks, it will revert back to it's factory defaults and you'll have to go through his all over again.
Oct 29, 2007 | Emerson Smartset Clock Radio
How do you set the wake up? So the radio turns on automatically? each morning
I did not find my manual, but this worked for me. Set the clock to be a 24 hour clock by pressing and holding the Memory/Clock Adj button. The display will show 24h or 12h. Use the fast forward button to change from 12h to 24h. Press the Memory/Clock Adj button again and use the fast or reverse forward buttons to change the time to read, for example, 13:00 instead of 1:00 if the time is 1pm. Press the Memory/Clock Adj button again to set the minutes.When you are done setting the time, press and hold the Timer/Sleep button. Either a time or "0:00" will appear in the display with the word "TIMER" flashing above it. Quickly press and hold the Memory/Clock Adj button until the first digit in the time starts flashing. Set the hour that you wish the alarm to sound using the fast or reverse forward buttons, just like you do for setting the time. Press the Memory/Clock Adj button again to set the minutes, and one more time to finish. The word "TIMER" will stop flashing and go solid, and the display will return to the time of day. When the alarm sounds, you can hit Snooze which will give you 5 more minutes, or you can turn the Clock Radio off. Pressing the Timer/Sleep button again will turn off the timer (alarm) and pressing and holding it again after that will turn it back on.
May 28, 2007 | Teac LT-1 Clock Radio
46 people viewed this question
 Grubhead
Grubhead
