Question about Teledyne Laars Laars Lite 2 Pool Heater 250,000 Btu / Natural Gas
Whats the gas pressure on a laars penant
I need to know the gas manafold pressure for a laars penant. its not a pool heater
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Teledyne Laars Master
  • 1,448 Answers
Look on ib\nside of front cover it will tell you
Posted on Nov 06, 2014
  • 3 Answers
SOURCE: Hello
http://www.parts4heating.com/Pool-Heaters-Teledyne-Laars-parts-s/38.htm
Posted on May 23, 2009
shuggie73
SOURCE: Laars lite II Pool and spa Heater LG model
Bad pilot generator? Flow issue?
Posted on May 25, 2009
  • 139 Answers
SOURCE: starting a teledyne laars heater
check for proper millivolt reading( 400-600).it could be 20 different problems and/or components
Posted on Jun 21, 2009
  • 139 Answers
SOURCE: laars lite 2 pool heater burners will not ignite
millivolt readings are independent of pump and filter.just make sure heater is in off position for accurate read
  • 9 Answers
SOURCE: Laars Teledyne Pool heater flames on for 2 seconds, shuts off
You have no flame rectification.....LLD series heaters check for a signal through the flame to ground; if the module does not detect this signal, it go through two more trials for ignition and then lock out the module. There should be a flame rod and it may need cleaning. I use steel wool.
Posted on Jun 28, 2009
Pilot and heater works for about 2 min and shuts off heater and pilot
check gas pressure if too small a line that will happen or too low gas pressure
Aug 08, 2011 | Teledyne Laars Laars Lite 2 Pool Heater...
Heater brownish color
make sure it is a propane heater not a natural gas heater might have to turn down gas pressure if not a propane it should have a P in model if not need propane model unsafe
Jul 24, 2011 | Teledyne Laars Laars Lite 2 Pool Heater...
My pilot light is lit but the heater won't turn on.
GET A NEW PRESSURE SWITCH.. CALL AND ASK FOR A PRESSURE SWITCH FOR SAY A HAYWARD POOL HEATER .. LOOKS LIKE THIS ..EBAY Pressure Switch Hayward generic pool heaters also H100
May 20, 2010 | Teledyne Laars Laars Lite 2 Pool Heater...
Teledyne Laars LD250 Propane Pool heater cycles on and back off
Do you replace the thermopile or check the milivolts?
Check the Pressure gas
You need replace all of them terminals and check again the milivolts at the gas valve
Apr 01, 2010 | Teledyne Laars Laars Lite 2 Pool Heater...
Laars LX400P pool heater Hi Limit Switch light is on? ???Fix?
This indicator normally means that your water temperature in the pool heater exceeds the internal limit. The corrosion should not be causing this problem. Since the high temperatures can be dangerous, you will probably have to contact a pool professional to service the machine.
May 31, 2009 | Teledyne Laars Laars Lx Pool Heater /...
Where is the pressure switch located so i can replace it. lost my manual
open the lower front door, then up on underside of panel are two screws/hex head. Unscrew these two screws and the upper panel will slide down, may need a gentle nudge. Near the middle left your will recognize your pressure switch.....
May 11, 2009 | Jandy Laars LX Pool Heater / 400,000 BTU /...
Teledyne Laars Laars Lite 2 Pool Heater 250,000 Btu / Natural Gas  Logo
48 people viewed this question
Top Teledyne Laars Pool & Spa Experts
Paul Carew
Jay Finke
Jay Finke
Bill Jordan
Are you a Teledyne Laars Pool and Spa Expert? Answer questions, earn points and help others
