Question about Little Giant Electrical Supplies
Little Giant pump (554405 how do I wire the over flow switch
mydogisk
  • 50 Answers
SOURCE: little giant rs-5 remote switch for submersible
there is a breather tube that has to be above the water level, you can check the diaphragm by plugging in the switch and pump the **** on the tube, if the pump doesn't come on, the diaphragm is busted or maybe there is something in the tube
Posted on Apr 13, 2009
SOURCE: how do i wire the leveler switch to the heater
plsma steel cut torch
Posted on Sep 13, 2009
al_kupchella
  • 843 Answers
SOURCE: my little giant water pump model 4mdsc has three
Sounds like you may have a 220V pump. So you need to confirm that this is a 110V pump and not a 220V pump. There should be a label or more info on line with any other info on the label. If you can confirm that this is a 110V pump, then put a standard plug on the cord - the green is ground and the other two can be wired to either blade of the plug. If you do have a 220V pump and you connect it to 110V anyway, the pump will perform poorly and will probably overheat and fail.
Posted on Jun 28, 2010
heatman101
  • 43501 Answers
SOURCE: My Little Giant pump (554405) is connected to our
There could be gunk in the bottom....then the float does not work right and the pump will not pump either...
remove the pipes and/or hoses and then the screws that hold down the top....clean the inside really well and reassemble... that may work,,,, but it may already be burnt up...
if cleaning does not work the replace the pump...you should be able to buy a new one at a HVAC supply house or some place like HD or Lowes...they will be in the 50.00 or less range...
Posted on Jan 11, 2011
Testimonial: "Thanks for the suggestion. I cleaned out the basin, removed gunk and it seems to be fine now. Thanks again."
  • 4336 Answers
SOURCE: How do I wire the safety overflow switch to my
The overflow switch needs to be wired in a manner that interrupts the HOT (black?) side of the wires going to the water inlet valve or it's circuit.
Posted on Feb 28, 2011
Little giant pool pump cover will not work
auto switch is defective? a simple easy replacement can be sourced from any pool supply co
Jan 18, 2014 | Little Giant Pool Cover Pump Water Wizard...
My new Little Giant 8-CBA Pump is hooked up underwater and plugged in. Not a sound. Electricity is working. And it's the same pump we have had for the last 7 years.
You say it's new? On some pumps they will secure the float switch when shipping. Be sure you followed directions and removed anything that may interfere with the switch.
Apr 21, 2011 | Little Giant 8 Cba, 4/10 Hp, 45 Gpm...
How do I wire the safety overflow switch to my furnace humidifier thermostat? I have a Little giant VCMA-20ULT and a Aprilaire 700.
Feb 28, 2011 | Little Giant VCMA-20ULT 80 GPH - Automatic...
My Little Giant pump (554405) is connected to our furnace/cac collecting condensation. It's been working fine for about 5 years. Now it keeps turning on for about 2 seconds and stopping only to repeat...
Jan 11, 2011 | Little Giant VCMA-15ULST, 1/50 HP, 65 GPH...
My little giant water pump model 4mdsc has three
Jun 25, 2010 | Little Giant SPS25 Water Removal System...
My old pump has the brown and blue wires connected
first do not change the factory wiring, what voltage is the pump wired for, what voltage is supplied to the pump.
then we figure out the rest
also what do the instructions say about the pump
NO stands for normally open contact-which means during operation is open which means off.
will be glad to help 865-888-1220
Mar 02, 2017 | Little Giant 115V 60Hz Condensate Removal...
Sump pump
The big cylindrical thing at the end of the wire hanging is the switch. I believe it is a mercury switch. Try hitting this a little and see if it stops. Sometimes they get stuck. If this doesn't help, then replace that piece. Hope this helps.
Jul 06, 2009 | Little Giant Submersible Sump Pump, 1/4 Hp
Electrical Supplies Logo
48 people viewed this question
Top Little Giant Electrical Supplies Experts
 Kenneth
Kenneth
Mike
ken skalski
Are you a Little Giant Electrical Supply Expert? Answer questions, earn points and help others
