Question about Craftsman Garden
I was given the leaf blower (358.797770) but the fuel lines were gone - rotted away. What a mess. Do you have a diagram showing fuel line routing?
#1 Taper
  • 1040 Answers
SOURCE: wont start, not getting fuel, checked lines,carb and used starter fluid, runs but won't continue to run
You may need to do a more detailed cleaning on the carburetor. I like to use a Den Tek Brush, (used for cleaning teeth), to get into the small ports. They work great for this job. You may also need to check the small screen in carb. It gets blocked with debris.If you need further assistance, please contact me.
Jim
Posted on May 25, 2009
#1 Taper
  • 1040 Answers
SOURCE: Fuel lines
The main fuel line goes to the bottom of the tank. The other, sometimes larger line goes to the primer bulb. This line goes just inside the tank, not more than 1"(inch).
#1 Taper
  • 1040 Answers
SOURCE: where does the fuel line with filter go on the carb?
The longest, and sometimes smaller in diameter of the two fuel lines, goes from the carburetor to the bottom of the tank. Leave enough slack in this line so that the filter that attaches to the end will rest comfortably at the bottom of the tank.
The other fuel line goes from the primer bulb to just inside the tank, (about an inch). make sure that you get the right size fuel lines. The plastic coupling goes on the end of this line, inside the tank. This keeps the line from pulling out of the tank.
(HINT): When feeding the lines through the tank holes, cut the lines at an angle. They will feed much easier into the holes. You can than cut them off square, once you know that you have enough to work with.
If you need further assistance, just let me know.
Jim
Posted on Jun 20, 2009
  • 3600 Answers
SOURCE: Weedeater XT 85T trimmer fuel lines rotted
it's in the fuel tank it goes from the carburator into the fuel tank and replace the fuel filter while you have the tank off.
Posted on Jun 21, 2009
SOURCE: Need diagram for fuel lines on craftsman chainsaw
There is two sizes of line. I see the large one goes to the large port on the primer button and then to the fuel tank. The small one goes from the primer button to the carb. The problem is there are two hose connections on the carb. I believe one is a vent, but I am not sure what one it is. I have a 36cc 2-cycle model 358.352161
Posted on Jun 22, 2009
Where can I get a fuel line routing diagram?
Just go from the fuel tank straight to the carb and the primer. The pipes are a set length so you don't have to worry about threading it all around the blower.. just take the most direct route from the tank to the carb..!
Apr 21, 2016 | Husqvarna 28cc Hand Held Blower HVH 125B
Carburetor diagrams
I know of no diagram available for this. But if you have both lines out and visible you can just put them on the carb, fill the tank and prime it and see if fuel moves. If it does your done....if not....flip the lines and try again!
Jul 16, 2014 | Poulan Mvm200vs, Ppb430vs Vs2000bv Blower...
Need to know how gas lines go on a RGB3100 they rotted off need to see a diagram
I don't have a diagram, but I can explain to you the fuel line routing.
The small diameter line out of fuel tank (has filter in-tank on end) connects directly to the side of the carburetor that has the fuel pump....that is the cover without the hole in it. Other larger diameter fuel line out of tank connects to the longer nipple on the external purge/primer bulb. The bulb "pulls" fresh fuel from the fuel tank to the carb and then out of the carb to itself, where it then "pushes" any air/old fuel back into the fuel tank. The remaining larger diameter fuel line in this setup goes from the metering chamber (has cover with writing on it and a vent-hole) side of the carburetor to the smaller nipple on the purge/primer bulb. Again, on the primer bulb, the longer nipple has a line going directly from it to the tank. This is the return line. The shorter nipple on the bub has a line from it going to the metering chamber side of the carb. If the purge/primer bulb is on top of the carb...small line from carb body to small hole in tank with filter. Larger diameter line goes from the bulb on the fuel pump side of the carb to the larger hole in the fuel tank where sometimes the line is held in place with a nylon nipple connector that keeps the line from pulling out of the tank. Otherwise, the line should enter the tank for about 1/2" or so.
Jun 12, 2011 | Ryobi Garden
I'd like to have a little diagram of the correct possition of the gas hoses coming from the gas tank to the primer and carburator for a Sears Craftsman 26 cc blower 150mph 340cfm
unfortunatly there arent any diagrams, my best advise would be to install the fuel lines leaving excess to trim off as you route them betwixt and between. remember that the fuel lines complete a circuit and that the primer bulb does not pressure up the carb, all it does is circulate fuel through the system and makes a loop
hope this helps and good luck
Nov 20, 2009 | Craftsman Garden
Fuel lines rotted, unsure of routing new ones
Bottom of the tank one is an overflow, 2 in the top are connected to the bulb
. The bulb pumps gas from the gas tank to the bowl of the carb then back to the fueltank in a loop to prime things up, prime too much and the overflow comes out the bottom tube.
Sep 23, 2009 | McCulloch 26cc Gas Blower Mcb3208
Craftsman leaf blower will start but has no blowing power
Clean the carburetor and replace the fuel lines - The lines on mine were totally rotted - The larger hose crumbled in my hand - The fuel filter had long since fallen off....
Sep 03, 2009 | Craftsman Garden
Fuel line connection
Fuel filter to bottom of carb. The suction port of primer to the top of carb outlet line to other port to tank.
To tell which port is outlet put your finger on one port and push bulb if the bulb collapses and doesn't return then that is the inlet (suction) side.
Good luck
Aug 25, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Jun 21, 2009 | Garden
Garden Logo
315 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
