Question about Electrical Supplies
Wiring diagram for Pass & Seymour Switch - Electrical Supplies
gotgeek2
  • 565 Answers
SOURCE: I have two pass & seymour 15A 660-wg switches
Yes. The incoming hot wire should connect to the sensor switch with a wirenut. Put another wire under that wirenut and jump it over to the fan switch.
Posted on Aug 30, 2010
  • 56 Answers
SOURCE: Where can I purchase keys for Pass & Seymour
Grainger
Posted on Sep 30, 2010
SOURCE: pass and seymour ws 3000 Hooking up to basement I
You're right, green goes to ground.
Black wire connects to Hot wire from breaker box
Red goes to Load (fan, light, motor)
Ok which wire on the switch goes to the Load?
And which goes to Hot from breaker box?
You can test or you can simply hook up the device. If it doesn't work, swap the two wires.
It just won't work until the 2 wires are correct.
Posted on Oct 24, 2010
SOURCE: I am using a Pass & Seymour illuminated three
I answer questions for free
I work with timers and electrical devices.
If I understand correctly you replaced a 3-way switch.
The new switch has 3 screws (plus green ground screw)
You put the Hot wire on the dark screw correctly.
You attached the two travelers to the brass-colored screws.
The two travelers are red and white.
You connected the ground wire to the green screw.
The ground wire is not supposed to be connected to with the white wire, and I doubt it is because that would trip the breaker.
The lights are working correctly.
If you followed the formula above to the letter, then the lighted switch should light up.
My best guess at this point is that the lighted switch is defective.
The Pass and Seymour webpage does not have manuals to look at like Leviton and Lutron products.
As a result I can't pour over a manual and put a magnifying glass on the wiring and wording to see if there is something we've missed.
But it's just not that complicated ... the light switch should light up.
At this point, I suggest you re-read the instructions (just in case?) and then swap the switch for another one ... or get different brand.
Posted on Nov 04, 2010
SOURCE: How to install Pass & Seymour 5410CC10 sp2
The cord that runs to your light contains two wires.
The cord switch interrupts one wire.
The second wire runs uninterrupted between wall plug and light.
The photo below is not the same switch as yours, but it shows how one wire is interrupted and the other wire is uninterrupted.
Which wire do you want to interrupt?
Look at the wall plug.
Is the plug polarized, where one blade of the plug is wider?
If the plug is polarized, then one blade is wide and the other is narrower.
Each blade of the plug feeds one of the two wires going to lamp.
Locate the narrower blade, and the wire that comes from that side of plug.
The narrow-blade wire is the wire you want to interrupt when installing the cord switch.
If the plug is not polarized, then choose one wire.
Posted on Nov 09, 2010
How to troubleshoot the installation of a Pass & Seymour three way switch
Standard 3way switch. You have two matching colored screws. they are the travelers. The odd colored screw is either power in or switch leg out depending on which end of the line you are on.
Jun 03, 2014 | Pass & Seymour Trademaster TM873WCC10...
Wire diagram tm873
Standard 3way switch. There are two crews the same color, those are for the travelers. The odd colored screw is for the power in or switch leg out depending on which end of the line it is located.
Aug 20, 2013 | Pass & Seymour Trademaster 3-Way 15 Amp...
How to wire a pass & seymore 692 switch
Wiring diagram located at
https://www.legrand.us/passandseymour/light-switches/combination/led-lights/692ig.aspx
Jan 29, 2013 | Pass & Seymour #692LAGCC6 15A Almond SP...
I am using a Pass & Seymour illuminated three way light switch. I wired my white and ground wire on one side and the hot wire black to the black painted screw and the red wire below to the brass...
Nov 04, 2010 | Pass & Seymour Trademaster 3-Way 15 Amp...
Is there a wiring guide for the Pass and Seymour LSDC163PWV? Which colors are for the Fan control and which for the Light?
Go to the website below for diagram. Under specifications.
https://www.legrand.us/passandseymour/fan-controls/de-hummer/ls-series/lsdc163pwv.aspx
Jul 03, 2010 | Pass & Seymour Pass and Seymour Decorator...
Don't know how to fit the wire into the inside of the switch
Since there are only 2 wires, it doesn't matter which wire goes where. Either way it will work.
Apr 26, 2010 | Pass & Seymour #5410WBPCC5 White In Line...
I bought a Dual fan and light control SLSDC16WCC6, no instructions in the box. The unit has red, black, yellow, and green wires. The electrical box for the wall switch has three wires, orange black and...
Would suggest you contact the Pass and Seymour Div. of Legrand (France) and ask for the pdf file with the instructions. Your unit has a wireless function and must be work properly.
Sep 02, 2017 | Pass & Seymour CS320LACC 3-WAY COMMERCIAL...
Electrical Supplies Logo
569 people viewed this question
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
