Question about Drills
Remove chuck from a dewalt dw953
How do I DO IT
  • David Ford
    David Ford May 11, 2010
    What is the exact model number? I don't see the DW953 being a drill press. If it is a cordless drill it is totally different. Let me know and I will help
The screw might be a TORX but use the same procedure with a torx driver.
Posted on Jul 29, 2010
    Scholar:
  • 58 Answers
I work in a large shop and I do most of the tool repair.  We do use DeWalt cordless guns so I have done this before.   I change these as often as they break at work.  About every 4 months the teeth fall out of a chuck and I replace the chuck with a new one.       To remove this chuck you should  use a heavy duty metric allen key and a good vise. The trick is to remove the small metric reverse thread screw. It is between 3 and 5mm.  Place the "L" of the allen key firmly in the vise with the long end pointing straight up.  Open the chuck all the way. Using a fully charged battery, place the gun in low (1st gear) and put the direction of the gun in FWD (as if you were driving a screw in), set the clutch to the drill setting (maximum torque) and drive that screw out of the chuck.  If the battery is not strong enough to drive the reverse thread screw out you will have to help it out.  Rotate the rear of the chuck clockwise and hopefully the screw will come out.  If that is not enough torque, I find the use of a small strap clamp helpful to turn the chuck against the reverse screw. Hope this helps.  Best Results!  Michael Mittelsdorf
Posted on Jan 13, 2009
How do i close the chuck on a dewalt dcd950
The DCD950 was DeWalt's worst chuck design. This chuck has no chuck screw, they loaded the spindle with locktite and put them on. Consequently, the chucks are nearly impossible to remove. DeWalt made a tool for this purpose, but it costs almost $90 - the only alternative was to replace the gearcase assy but they just made it obsolete, no longer available.
There is a conversion kit but the problem remains, you still need to be able to remove the old chuck.
We have used a metal cutting saw to cut the chuck off - about the only thing that works Conversion Kit N422782 for DeWALT Power Tool eReplacement Parts
Sep 25, 2014 | Dewalt Dcd950 Hammer Drill Uses Dc9096 Or...
How do I get the chuck off of my DeWalt DW 117 1/2" VSR Drill Serial #1229?
Open the chuck jaws and look down inside the chuck. You will see a screw head that is holding the chuck to the drill. Once you remove the screw, the chuck should pull off easily.
Jul 31, 2014 | Dewalt Drills
Problem with the Dewalt 3/8"VSR
My solution when the other mentioned ideas didn't work was this: I removed the 7 Torx #20 screws ( a common screw driver will work as well) and removed the housing half to expose the shaft. The chuck shaft bearings and gear lifts out as one assembly. Directly behind the chuck there is a half inch section of shaft exposed. I mounted a vise grip on the shaft (won't hurt it) and clamped the affair in a bench vise. With a 5/16" allen wrench mounted in the chuck and using a mallet I spun the chuck off with a solid smack counter clockwise . Very simple and easy .
Aug 29, 2011 | Dewalt 3/8"VSR 6AMP CORDED KY DEWALT DRILL...
How do you remove the chuck from a dewalt 12 volt dw953 drill
Open the chuck wide open. In the center is a retaining screw, they usually have left hand threads. Remove the screw. Take an allen wrench 1/4" to 3/8" in size and fasten the short side tightly in the chuck. The chucks are usually right hand thread, so take a small hammer and strike the allen wrench to turn the chuck to the left to loosen it.
Apr 12, 2011 | Garden
How to remove the chuck?
open the chuck fully and it shoudl have a screw inside. Unscrew it, but be carefull, these screws are usually reversed - to uncsrew, rotate it clockwise. Once done, put allen key into chuck (short side in), fasten the chuck to hold allen key well and hit the key with hammer - counterclockwise direction. You might want to verify this procedure with someone else as I have no experience with Dewalt, but this way it works for Makita, Metabo, Narex, ... then why not for Dewalt? Juraj
Jun 06, 2010 | Dewalt DC727KA 3/8" 12v Cordless...
How do i remove the chuck from dewalt dc925 cordless drill, dosnt have a screw inside the chuck, read somewhere that i need a special tool but no instruction or picture of the tool. please help., thank you
The dc925 and the current model dcd950 along with several other models of Dewalt 's line of cordless hammer drills DO NOT have a screw inside removal requires a CHUCK REMOVAL FIXTURE part #
233804-40 also you can't use a generic replacement chuck. As of 2/2/2010 the prices on the Dewaltservicenet web site are $72.74 for
the tool and $69.70 for the chuck, part # 330075-90.
Oct 17, 2009 | Dewalt Heavy Duty Xrp 1/2" 18V Cordless...
Remove chuck and replace on DeWalt DW959
the chuck is retained by a screw in the center of the chuck.open chuck jaws wide.use a vise or pipe wrench to hold chuck.
Oct 15, 2009 | Dewalt Drills
How do you remove a key chuck from a dewalt drill
first shift the drill to the drill only position and the gear selector to the low position, remove the chuck retaining screw LH thread, find a bent handle allen wrench about the chuck capacity and lock in the jaws of the chuck, put the chuck on a block of wood at about a 30 degree angle to hit the long portion counter clockwise and strike it with a hammer, it might take a couple hits but it will come off. I misread the header last time.
Oct 01, 2009 | Dewalt Drills
Keyless chuck question
this 2 chuck are 3/8 jaw opening,double sleeve u can hold the chuck will opening it at the sametime.the sinlge sleeve u have to runs the drill while running slow rev/for to remove the bit etc.
i prefer metal sleeve.
Aug 18, 2008 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
Drills Logo
1,457 people viewed this question
Top Drills Experts
Are you a Drill Expert? Answer questions, earn points and help others
