Question about Philips 60PW9363 60" Rear Projection Television
Red bow at top left and botton left of screen
My philip 60pw936317f has a red bow on the left side of the set. Tried to fix with convergence alignment menu option but it won't align on the bad side. I opened the back of the set and there is a box with six knobs where you can adjust the projectors. I started adjusting these when I felt some wiring next to the box arc very lightly to my arm and all three projectors went off. Now when I turn on my tv the picture shows for 3 seconds and then fades to blue then off.
    Champion:
  • 205 Answers
Lost of high voltage on the vertical amp was caused the bowing. That was a simple tweak. I'm sorry to tell you that the high voltage adjustments are rather precise and have major interaction with each other. The HV circuit is also used to power low voltage circuits to gain efficiency. If one or more are not within spec, the process to recovery will require bench alignment of the various stages. Seek professional help or consider replacing. Good luck
Posted on Jul 07, 2009
Changed ICs Chips but still got bad convergence
After the IC replacement, convergence adjustments should be done. If you wish to get some details; visit the site linked here. Pull up older posts.
http://electronicshelponline.blogspot.com/ Details of this adjustments are given.
May 01, 2017 | Philips 60PP9202 60" Rear Projection...
Philips projection HDTV 51PP9200D/37. Convergence problem
This is a very common failure on Projection TV sets.
Screen looks 3D
Colors don't line up
One or more colors can't be adjusted when using the convergence menu.
Screen is bowed or warped.
You can see some example photos and find a solution here...
http://www.fixya.com/support/r2861627-updated_convergence_problems_amp
Sep 13, 2009 | Philips 51PP9200D Television
Screen is bowed on top and bottom.
Projection sets have two very common problems outlined below.
The first common problem is convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. The TV can also shut down when the convergence starts to fail.
Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith, RCA and others.
You can more info and a DIY convergenece repair kit with instructions from TV Repair Kits using the link at the end of this article.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped or bowed
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya
http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jul 13, 2009 | Samsung PCL5415R TV
Red curves on bottom and top of picture
You have a convergence problem. Here are some of the most common symptoms.
Screen looks 3D
One or more colors can't be adjusted when when using the convergence menu.
Screen is bowed in but stationary.
Solution:
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kit for your exact model. The kit inlcludes a photo instruction guide, original Sanyo STK chips, convergence resistors, etc. Everything you need to fix it yourself. Its an easy fix.
Jan 18, 2009 | Philips 43PP9202 43" Rear Projection...
PHILLIPS MAGNAVOX 60 BIG SCREEN 9P6040C101
can you post a picture of your screen or send it to my email slinteriors@yahoo.com as it sounds like its just the convergence Ics and the 6.8 ohm resistors, but a pic would help me do a accurate diagfnosis.
Jun 28, 2008 | Philips 55PP9363 55" Rear Projection...
Red bow on top and bottom of 61dx01b
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projeciton sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix
69189a5.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you are handy and can follow directions. You can get complete repair kits from TvRepairKits.com or click here. They have put together DIY repair kits that include the OEM parts and step by step photo instructions for each repair. If you are not handy or can't follow directions we would suggest calling a shop.
May 21, 2008 | Samsung PCL5415RB 54" Rear Projection...
Convergence amp ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
http://www.hdtvoice.com/voice/showthread.php?t=28929
Or send to ptscorp.com
http://www.hdtvoice.com/voice/index.php?s=
good luck
please mark the post with a fixya
Feb 20, 2008 | Hitachi 61SDX01B 61" Rear Projection...
Magnavox Projection Picture Problem
Sounds like you may need the convergence amps changed and also resistors in that area and maybe fuses.
Jan 02, 2008 | Philips 9P5034C 50" Rear Projection...
Philips 32PW9536 Screen distorted to the right hand side
  • Screen looks 3D
Jun 03, 2007 | Philips 32PW9523CG 32" TV
Open Questions:
Philips 60PW9363 60" Rear Projection Television Logo
71 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
