Question about Canon PIXMA iP1600 Printer
I can't replace my printer cartridges
I got them out, boutght new ones, can't get them to slide or click in
When you insert the cartridge, the back end must be higher than the front. Push up on the front to snap it in.
Posted on Jan 08, 2009
Please let me know the direction of cartridges
You can follow the steps below to replace your ink cartridges.  Feel free to click on the link at the bottom to pull up a document that gives you information including pictures on how to replace the ink cartridges.
To take out the old ink cartridges:
When replacing the tri-color print cartridge, remove the print cartridge from the slot on the left.When replacing the black or photo print cartridge, remove the print cartridge from the slot on the right.Pull the print cartridge toward you and out of its slot.
To install new ink cartridges:Remove the new print cartridge from its packaging.Remove the plastic tape by using the pink pull tab.Slide the new print cartridge forward into the empty slot. Then gently push the upper part of the print cartridge forward until it clicks into the socket.When installing the tri-color print cartridge, slide it into the left slot.When installing a black print cartridge, slide it into the right slot.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00620122&cc=us&lc=en&dlc=en&product=1138373&tmp_track_link=ot_search
Apr 19, 2011 | HP Officejet 4355 All-In-One InkJet...
How to change the ink cartridge
Checking the ink levels
  1. Open the HP Director .
  2. Click Settings , point to Print Settings , and then click Printer Toolbox .
  3. After the Printer Toolbox opens, click the Estimated Ink Level tab.
  4. For information on obtaining replacement cartridges, click Print Cartridge Ordering Information .
Replacing the print cartridges
  1. Make sure the HP all-in-one is on. WARNING: If the HP all-in-one is off when the print-carriage access door is lifted to access the print cartridges, the HP all-in-one will not release the cartridges for changing. Damage may occur to the HP all-in-one if the print cartridges are not docked safely on the right side when you try to remove them.
  2. Open the print-carriage access door by lifting from the front center of the device, until the door locks into place. The print carriage is on the far right side of the HP all-in-one. c00228292.jpg 1 - Print carriage access door 2 - Print carriage
  3. When the print carriage is idle and silent, press down on the end of each cartridge to snap it out of the carriage. If replacing the tri-color print cartridge, remove the print cartridge from the slot on the left. If replacing the black or photo cartridge, remove the print cartridge from the slot on the right. c00228293.jpg 1 - Print cartridge slot for the tri-color print cartridge 2 - Print cartridge slot for the black and photo print
  4. Gently pull the print cartridge toward you, out of its slot.
  5. If removing the black print cartridge to install the photo or gray photo print cartridge, store the black print cartridge in the print cartridge protector.
  6. Remove the new print cartridge from its packaging and, being careful to touch only the black plastic, gently remove the plastic tape by using the pink pull tab. CAUTION: Do not touch the copper-colored contacts or ink nozzles. Touching these parts can result in clogs, ink failure, and bad electrical connections. c00228294.jpg 1 - Copper-colored contacts 2 - Plastic tape with pink pull tab (must be removed before installing) 3 - Ink nozzles under tape c00228295.jpg
  7. Slide the new print cartridge forward into the empty slot. Push the print cartridge forward until it clicks into place. If the print cartridge you are installing has a white triangle on its label, slide the print cartridge into the slot on the left. The label for the slot is green with a solid white triangle on it. If the print cartridge you are installing has a white square or a white pentagon on its label, slide the print cartridge into the slot on the right. The label for the slot is black with a solid white square and a solid white pentagon on it. c00228296.jpg
Jan 21, 2011 | HP OfficeJet 6210 All-In-One InkJet...
I bought a new ink cartridge, but cannot find my manual. How do you change the cartridge???
Changing an HP Ink Cartridge
  • 1
    Open the lid of the printer. Depending on the model, there will be two cartridges on the right, one for black and one for color.
  • 2
    Find the cartridge that is running low on ink. The black cartridge will be in black, the color cartridge will have a patch of color (usually green) on it.
  • 3
    Pull down on the black clamp that is holding the cartridge in place and slide out the used cartridge.
  • 4
    Open the package of the new ink cartridge. Remove the protective tape and slide the new cartridge into the printer.
  • 5
    Snap the black protective case back into place and close the lid.
  • techbelkin
    Nov 11, 2010 | HP Officejet 5610 All-In-One InkJet...
    How to install a new ink cartridge in Lexmark 2350 printer/scanner
    Perhaps the Lexmark X2350 User's Guide will be able to help you. Just click on this link to download: http://bit.ly/bNOTdZ. Scroll to Replacing the print cartridge, Page 52, for the instructions on how to install your new ink cartridge.
    Sometimes the ink cartridge carrier won't position automatically to the middle even when the printer is on and the cover is open. Just unplug the printer from the power source. With the cover open, hold the solid white strip and gently slide the carrier to the middle of the printer. Load the cartridges. Close the cover. Plug the printer back to power source.
    Sep 15, 2010 | Lexmark X2350 All-In-One InkJet Printer
    Need to install new ink
    Lift the entire top including the scanner portion until it clicks to stay open by itself (like some vehicle hoods). You should see the print head containing all the ink. It will slide back and forth for a moment, this is normal. Wait until it comes to a stop. Notice any blinking lights below the ink cartridges. If the light is solid, there is enough ink. If the light is blinking you'll need to replace that cartridge for the best print quality. Remove the ink by carefully but forcefully pushing on the tab with one finger and holding the back of the cartridge with other. It should simply slide out. Note the EXACT #'s on the ink cartridges. Right down all the information and the type of printer you have and take it to your local best buy or equivalent store, they will give you the replacement cartridges you need. Unwrap the package and carefully remove the orange tab on the bottom by twisting in the direction shown. (You may want to wear rubber gloves because the ink stains fingers badly.) Carefully but forcefully slide the new cartridge in place of the old and push down until you hear a click. The light under the cartridge should now be solid. Once all carts have been replaced close the lid of the printer and give it a moment to situate. Run a print head alignment to manually align all nozzles for best printing quality. Simply click the head align software button and follow the instructions, quite easy. You should be all set and ready to print!
    Jun 24, 2010 | Canon PIXMA MP620 All-In-One InkJet...
    I need to replace the ink cartridges and can't find my book. I got the old ones out, but I cant get the new ones in.
    You should slide the cartridge into the slot (black on the right) and then push on the upper part of the cartridge until you hear a click. The labels should be on top and on the side nearest you.
    I hope this helps.
    Apr 04, 2010 | HP Officejet 5610 All-In-One InkJet...
    I just want to change the black ink cartridge - how do i do it
    I needed to know that to get to the ink cartridges the MP240 had to be switched ON before lifting up the whole scanner bed from the front.The ink cartridges will then slide to the middle and can be clicked out and a new ones clicked back in.
    Aug 07, 2009 | Canon PIXMA MP240 All-In-One InkJet...
    Canon pixma mp210
    Go to this link. Type "replace ink" in the Search window and click Search. Click on the "How do I replace the ink cartridge(s)" link, and you will get detailed instructions. Make sure that the unit is turned on and that the carrier moves all the way to the left. After you slide a new cartridge into position, you must lift up on the end of the cartridge closest to you.
    May 27, 2008 | Canon PIXMA MP210 Photo All-In-One Printer
    Slide bar for cartridges
    Hi, click printer icon ,select printer setting .,cleck maintenance ,navigate below select replace ink cartridge , printer set in middle , unplug power cord to access repair or reload ,
    Jan 19, 2008 | HP DeskJet F380 All-In-One Printer
    Canon PIXMA iP1600 Printer Logo
    23 people viewed this question
    old marine
    old marine
