SOURCE: getting close front cover error when i start
i am a toshiba engineer, you have no 24volt supply from the psu. check the fuse on the psu. highly unlikely to be the door switch.
SOURCE: Toshiba e-studio 230 call for service
Call a Service tech
Have him reset yor Counter AFTER he over checks your copier and inspects the Drum,.Transer Unit, and Fuser Unit chances are the previous tech may not have reset the counter
but call for Service to verify those parts are good first ok. I would not want a counter reset to occur if a fuser unit is bad or something. At that low copies it maybe time for corona's to be replaced.
http://www.copierspluswwllc.com
SOURCE: We have a toshiba e studio 255 and it is showing
THE DUPLEX COVER SENSOR NEED TO BE CLEAN OR THE THE STUD ON THE DUPLEX COVER IS BROKEN
SOURCE: My Toshiba e-studio 45 displays
Hello
I encountered the same problem a few years back, I found the power supply to be faulty.
You can try checking all the fuses on the power supply.
Sorry that is all i have at the moment.
I will see if i can download the pcboard repair manual.
Please let me know where i can email it to.
Regards
SOURCE: my machine toshiba e studio
hai friend it is a small problem ,. the problem is Sensor is not working. U have to do one thing
open right cover., and clean the roller dust., and rearrange all the doors in the printer,. then close tightly the main door., and put a support for not opening ., try it it will work.,
