Question about Oregon Scientific DS6310 Digital Camera
How to open the camera battery compartment!??
    Scholar:
  • 117 Answers
What brand and model?
Posted on Jan 05, 2009
  • Miles Jan 05, 2009
    the battery compartment is located on the bottom of the camera.
How do you open the battery compartment Bell & Howell Splash Wp7 Waterproof Camera
Slide the battery cover on the bottom of the camera to open the battery compartment. Use fresh 2xAAA bateries
Jun 12, 2014 | Bell & Howell Splash Wp7 Waterproof Camera
Open battery compartment
Spray WD-40 around the compartment door and try to let it trickle inside the compartment. That should break the acid corrosion buildup that holds the door from opening.
Oct 19, 2013 | Nikon F601 35mm SLR Camera
Battery compartment won't open?
Push the cover toward the back of the camera and then toward the end, just as the arrow indicates, then the end of the cover nearest the end of the camera will swing open. Follow the illustration in the "Insert the Batteries" section of the manual (page 12 in my copy).
Feb 19, 2012 | Nikon COOLPIX L18 Digital Camera
I just received this dv002 camera and can't get the battery compartment open. I'm afraid if I force it open, it will break.
You do not need to open up the battery compartment, as it is a built-in rechargeable battery. Use the cable included to recharge the camera.
Jun 18, 2011 | Cameras
My digicam won't start
There could be a couple of reasons why your camera would not start.
Before considering it to be defective, verify that the camera has batteries inside and that these batteries are charged. To do this:
  1. Locate and open the battery compartment.
  2. Identify the type of batteries needed and purchase new ones OR
  3. Recharge the batteries with the recharger provided.
  4. Place the new/charged batteries inside, closing the battery compartment.
  5. Try to turn on the camera.
If the camera still doesn't work after verifying that the batteries are in order, remove the memory card and any other accessories that the camera may have and try turning it on again.
If still the camera won't turn on, one last step can be performed if and only if your camera uses standard batteries (AA or AAA). If this step is performed incorrectly, you could short circuit the batteries, which would discharge them. This procedure will not damage the camera if performed correctly. Please pay attention and do exactly as explained:
  2. Remove the batteries.
  3. Place the batteries back inside in the opposite direction than the one indicated. If the position indicated is for the positive end first, place the battery with the negative end first. Do this process for all the batteries.
  4. Close the battery compartment.
  5. Attempt to turn on the camera. It will not turn on, but this step is necessary nonetheless.
  6. Open the battery compartment.
  7. Remove the batteries.
  8. Place the batteries in the correct position according to the indication.
  9. Close the battery compartment.
  10. Attempt to turn on the camera.
If the camera still does not work, it is likely that it is defective. At this point you should take the camera to an authorized service center.
Mar 30, 2011 | Cameras
Cant get battery compartment open
Sorry just got this message okay here is a sequence for opening, closing and removing the battery.
I'm also supplying some diagrams. The battery compartment is a push type towards the outer edge of the camera body then it swings up and open.
Battery cover picture
Loading the battery
Removing the battery there is a little catch on the one corner that needs to be released.
Have fun with your camera
Dec 27, 2010 | Fuji FinePix F480 Digital Camera
Just replaced batteries camera is brand new and wont turn on
Remove the backup battery. You will see a rectangular insert inside cover of battery compartment, closest to the hinges, pull out using fingernail. Close battery compartment with batteries inserted, turn on. Turn off open battery compartment replace backup battery. Reset date and time.
Jul 18, 2010 | Canon PowerShot A490 Digital Camera
How to open battery door to recplace battery?
On the bottom of the camera you'll find a plastic tripod mount and the battery compartment. The door covering the battery compartment is fairly sturdy, and it has a locking mechanism. As you can see, the Coolpix 4600 and 5600 use two AA batteries.
Apr 04, 2010 | Nikon Coolpix 4600 Digital Camera
How do I open the compartments on the camera
Which compartments?
The lid on the battery compartment next to the tripod mount flips down.
To open the film compartment, turn the camera upside down, then turn the film chamber release clockwise.
You can download a manual from http://www.butkus.org/chinon/minolta.htm
Feb 08, 2010 | Minolta Vectis 300L APS Point and Shoot...
Cannot open the battery compartment to change batteries
I give up...battery compartment so bad I'm returning the camera.
Jan 11, 2009 | Canon PowerShot A400 Digital Camera
Oregon Scientific DS6310 Digital Camera Logo
335 people viewed this question
Top Oregon Scientific Cameras Experts
Fabrice Wolters
Greg Cann
Greg Cann
Are you an Oregon Scientific Camera Expert? Answer questions, earn points and help others
