Question about Brother HL 5250DN Laser Printer
Toner smudges along the extreme right side of the paper
I just barely finished installing my Brother HL-2140 printer and everything works great except for toner smudges all along the extreme right side of any paper I print. They occur in a regular pattern and look almost identical. My techie brother says they'll go away with usage, but I wanted your opinion. Thanks.
-Scott Ashton
  • scottmortona Jan 05, 2009
    Thanks a ton. I'll try that. How many times should I print pages before requesting a replacement toner? And how do I go about requesting a replacement toner?
  • 31 Answers
If the smudges are gradually fading then it's likely just excess toner hitting the fuse drum. Try a few cleaning cycles/test prints and see if that makes it go away. If not, see if you can get a replacement toner.
Posted on Jan 05, 2009
HL 2140. How do you remove jammed paper from inside printer
You can remove the jammed paper by removing the drum and toner inside the printer.
First Open the front cover, just pull down the cover right above the brother logo. You will see the handle for the drum and toner. Hold the handle and pull it towards you, just use a little force on it. Then remove the jammed paper inside. Just to be sure you can remove the toner from the drum by holding down the green tab on the side of the drum unit. then pull the toner out. Check if there's a small piece of paper inside the drum unit. Put the toner back to the drum make sure it clicks into place. Reinstall the drum and toner back to the printer. It should also click into place. Then close the cover.
Hope this helps. Rate if it works. Thanks
May 05, 2011 | Brother HL 2140 Laser Printer
I simply have the error light on my brother 2140 printer. I have pulled out the drum and toner. I have cleaned the corona wire. I don't have a paper jam.
  1. Open the front like you are going to pull out the toner.
  2. With the door open push and hold the button the on the left side that the blue button normally pushes when closed.
  3. Release after 30 seconds. this will reset the drum.
Hope this helps. Happy Printing :)
Dec 30, 2010 | Brother HL 2140 Laser Printer
Brother HL 2040 prints extremely light and seems to smudge? Just changed out the tone cartridge and no change.
I'm not sure if the drum is going out or not. How many toners have you used? The drum is rated at 12,000 pages and the toner is supposed to yeild 2500 pages, so 4 or 5 toners ought to finish the drum. Did you clean the area around the drum? I don't think you're supposed to touch it, but I've never had to touch my 7240 in 4 years, except to change the toner.
The good news is the toner will fit in more than one Brother machine and the printers are inexpensive. It almost makes buying a new machine more economical than a drum :-}
The HL printer is Manufacturer Discontinued, the new ones use a 360 series drum and toner, and the MFC's (7220 etc.) are about $200 vs. $116 for the drum. Hmmm.
Might be time to upgrade.
Carl
Jan 08, 2010 | Brother HL-2040 Laser Printer
Brother HL-2140 Error light is flashing
Try to unplug the power from the print, wait 1 minute then plug back in.
This may remove the error.
Sep 26, 2009 | Brother HL 2140 Laser Printer
Hl-2140 noises
For a possible fix to the Brother HL-2140 squeal/squeak/noise problem open the printer at the other side from the paper tray and toner cartridge door. You should see a little black roller rod along with some white wheels.
The noise may be coming from the contact between the wheels/rollers which pull paper toward the output tray on top after it has been printed.
Check and clean/wipe the wheels and black rod, especially in the center area. Hopefully the noise will now be reduced/eliminated.
Cheers, Stephen
Sep 14, 2009 | Brother HL 2140 Laser Printer
Pale smudges regularly spaced down left margin, 1.5 inches apart
Hi:
Since you have already replace the toner cartridge then the most likely culprit is the fuser assy. You can test this by trying to print something and stop it by opening the cover just as the paper is trying to pass under the toner cart. Remove the toner cart carefully and look at the unfused print on the paper. Do you see the faint smudges? If not, then the problem lies with the fuser assy. This is the unit that gets hot and fuses the toner to the paper. If this is the case you will need to have a tech replace it for you.
Good Luck
Andrew
Jun 27, 2009 | Brother HL 5250DN Laser Printer
Smudges along the right side of the paper
Hi Scottmortona,
Welcome to FixYa!
I encountered this while printing my lecture notes for my students. This seems either a drum issue or the toner.
  1. Take out the toner.
  2. Ensure that the toner is evenly spread out by holding it horizontally, and tilt forward and backward.
  3. We need to ensure the toner is even.
  4. Take out the drum unit.
  5. Check are there any toner powder stuck on the sides of the drum?
  6. If so, use a soft brush and slowly brush off the toner stuck there.
  7. At the top of the drum, there is a blue notch. Slide this a few times to do a wire cleaning.
  8. Place the toner into the drum
  9. Place drum into printer now.
  10. Try printing a few pages.
Let us know if you have any problems.
Thank you for rating us.
Jan 05, 2009 | Brother HL 5250DN Laser Printer
Blank paper
Make sure you are letting it warm up long enough.
Brother HL-2140 Support
Jun 16, 2008 | Brother HL 2140 Laser Printer
Brother HL 5250DN Laser Printer Logo
1,539 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
