SOURCE: Westinghouse DPF-0802 does not display all photos on my SD card
You need to download them onto the frame
SOURCE: westinghouse dpf 1411 wont turn on power block
I would recommend contacting Westinghouse customer service team at 1800-701-0680 for further assistance in getting this frame replaced.
SOURCE: I put my memory card
The memory card's pictures could be too large to download, that's my guess: Here's what a reviewer said about the internal memory capabilities:
Other Thoughts: Make sure when you transfer your photos to size them down so they will not take up much room and the slide show will run faster with smaller sized photos, I used 640x480 pictures and they looked really good. When hooking up a USB cable to the unit, I could not get access to the internal memory, it showed three drives but they were all mapped to the memory card reader slots. This made transferring the pictures to the internal memory slow and cumbersom as I had to do it one picture at a time. Solution, buy a small SD or Compact Flash memory card and use it instead.
The internal memory is just 8 mb, so that wouldn't even support one of a modern digital camera's pictures.
Good luck, and hope this helps.
