Question about HP Computers & Internet
My hp l1706 monitor is flashing different colors and I can't see my desk top burn in off menu & plus key
viziks
  • 220 Answers
SOURCE: Bank screen now.
Problem normally is dry solder of power transistors and inverter transformer.Resolder should solve Intermittent or Display switch-off problems.
Samir
Posted on Apr 05, 2008
SOURCE: how i can to open the cover of lcd hp L1706
1.- remove 14 screw on back
2.- remove front cover con un desarmador plano pequeño, como si pucharas hacia afuera y luego al frente por toda la orilla.
3.- quitar la base es solo con un simple apreton y click y listo, sale la parte de abajo y luego aprietas la parte de arriba y estiras. y ahi vas a ver unas tuercas te puedes ayudar con una llave española o perica pequeña.
y listo.
Posted on Jul 22, 2009
SOURCE: my hannspree monitor recently started flashing colors
i have 3 hannspree monitors 2 were sent back for repair i replacement was faulty when i got it back the other one changes flashing colours never again i tried turning the brightness to full which helped for a time
Posted on Apr 12, 2010
  • 9 Answers
SOURCE: HP L1706 monitor - will not power on - green light
I had the same problem and replaced 2 bulged capacitors, screen is working fine again! (1000µF 10V)
Posted on Aug 18, 2010
Azega
  • 31 Answers
SOURCE: L1706 monitor power light flashes
A flashing power light often means the monitor isn't getting a signal. When you turn the monitor off and back on, do you see the brand logo for a few seconds? Try plugging it into a different computer to see if it comes on.
If plugging it into another computer doesn't work, it may be a bad power circuit in the monitor. A common problem with monitors is the capacitors going bad. If you're handy with a soldering iron, you can try replacing them yourself. Look here for pictures and instructions: Fix an LCD Monitor
Posted on Oct 18, 2010
WHAT IS PRISE OF HP L1706 DISPLAY UNIT PART??
Check this price on E-bay. That's how I always do it.
If you go through HP, you will probably be paying over US$100
Oct 22, 2011 | HP L1706 17" LCD Monitor
Monitor is flashing in diffrent colors
This looks like main board panel display problem, but first! hook a spare monitor to the computer to rule it out, if okay! check the video cord to see if it can be detached from both ends and sub an other cable if possible. If everything checks out the HP Monitor is the problem, when the video is processed to the main board "attached to the back of the LCD screen" it is distributed to the display panel. This is not a cost effective to repair, replacement of the monitor is cheaper in the long run.
Jan 30, 2011 | HP L1706 17" LCD Monitor
L1706 monitor power light flashes green/amber
Oct 18, 2010 | HP L1706 17" LCD Monitor
HP L1706 monitor - will not power on - green light keeps on flashing
Jun 04, 2010 | HP L1706 17" LCD Monitor
How to check the backlight life of my hp l1706
Claimed life for the lamp is 50,000 Hours, but in real life, no way to tell. You can look here what is failed in the backlight lamps, it can be from worn out (blacken ends is one sign of bad lamps, same as home fluorescent lamp), poor soldering works on the lamps. see pictures here: http://s807.photobucket.com/home/budm/allalbums
What is the problem with your monitor anyway?
Mar 30, 2010 | HP L1706 17" LCD Monitor
My monitor won't sink in with my labtop it goes to
Whaen you right click on the Desk Top and select Properties. Then go to Settings. There you can configure two monitors. Easy enough. Now point to remember is that both the monitors, the LCD of the laptop and your ViewSonic should have the same resolution. If different, then there will be a conflict.
Aug 06, 2009 | Electronics - Others
HP L1706 monitor with thin white/blue horizontral line
It is the problem of monitor pcb in vertical section.check vertical ic for dry soldring. Resolder the ic if problem still on then change ic or check components related ith it. check continuity of vertical deflection coil.
Hope this be of initial help/idea. Pls post back as requested, how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FIXYA.
Mar 13, 2008 | HP L1706 17" LCD Monitor
HP L1706 monitor
your monitor is getting ready to kick the bucket.
Oct 31, 2007 | HP L1706 17" LCD Monitor
Computers & Internet Logo
60 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
