Question about Mitsubishi VS-50609 50" Rear Projection Television
Trouble with my Mitsubishi VS 50609
My Mitsubishi VS 50609 will randomly shut off while watching it. It could only be on for and hour or it can be on for several hours, it makes no difference. There is no pattern to it and you can not turn it back on until it's ready to turn back on. It just makes no sense to me. Can anyone help with this problem? Any ideas?
  • duckI Nov 10, 2007
    When turned on it stays on for about 10 seconds. Then it shuts off, it stays off for about a minute. Then it comes on and off for a short while befor it finally stays on.
    I have removed the back and found that if I tap on the module that contains the input conections, I can make it come on or off. I do this with the plastic end of a screw driver and the taps are very light.
    Problem Solver:
  • 10 Answers
Make sure you have no colent leking on the bord these set many I worked on had colent leaks that cused it to shut down. does the set come back on when it's cool? could be a bad soder joint. allso there could be bad caps. deos it come back on if you unpluge the set for 5 sec and plug back in that resets the set.
Posted on May 21, 2007
How to get the buttons to work agin on front of tv.
You may have accidentally set it to the demo mode.
The user's guide might help:
Mitsubishi VS 45609 VS 50609 User Guide
Sep 06, 2014 | Mitsubishi VS-50609 50" Rear Projection...
Is it a difficult to replace the convergence amplifier modules on a Mitsubishi VS 50609 TV?
Your convergence has failed. This is a very common problem on most projection tv sets. You can read about it here on fixya using this link
http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Feb 20, 2013 | Mitsubishi VS-50609 50" Rear Projection...
Mitsubishi VS-50609 - Red convergence is way off, suddenly
You have a bad ground on a convergence IC. You will have to carefully pull this board out and resolder the pins. If this does not solve the problem you will have to replace the ICs. I have saved a few of these TVs with just a resolder job. Thanks for asking!
Jul 11, 2010 | Mitsubishi VS-50609 50" Rear Projection...
Mitsubishi vs-50609 green timer light comes on no
Unplug the tv and leave it unplugged for a couple hours. Plug tv back in press reset button. TV led may flash for a day but should come on. I did this last night to mine and it came on at 11am today.
Mar 29, 2010 | Mitsubishi VS-50609 50" Rear Projection...
My power button does not stay on (the green lamp)when turned on from the remote or the unit. I checked the fuses on the main circut board and the have contineuity. help model vs-50609 mitsubishi rear...
Could be h.v. splitter.pull the lead coming from the flyback that enters into the h.v.splittter. Put lead in a quart jar and turn the set on and see if you hear a hissing sound, if you don't see a blue arch also. If set stays on then h.v.splitter is bad.
Jul 07, 2009 | Mitsubishi VS-50609 50" Rear Projection...
Have sound but no picture
Sounds like what happened to my hitachi. Power voltage regulator on the main pwr board.
Jan 24, 2009 | Mitsubishi VS-50609 50" Rear Projection...
VS-50609 no picture no sound
Seems to be the power button is stuck on the tv itself
Jun 24, 2008 | Mitsubishi VS-50609 50" Rear Projection...
Mitsubishi vs-50609 wont stay powered on
Hello nicolastran,
I gave this advice to someone with this same problem so here it is again:
It sounds like your shutdown circuit is being activated. This is due to excess current being drawn. This usually happens in the High Voltage section of the TV or one of the deflection stages. Due to the nature of this problem I would suggest that you take it to a local TV repair shop or have a TV repair person come out and take a look at the issue. The HV section is dangerous and should be dealt with by a qualified TV repair technician.
Thank you,
I hope this helps
Shuttle83
Mitsubishi vs-50609
Hello elarka,
I believe that you are having HV voltage problems either with the SMPS or the HV Power supply. The shut down circuit is activating. This might be due to a component in the HV or SMPS section. I would suggest having a TV tech look at the set.
I hope this helps
Thank you,
Shuttle83
Sep 27, 2007 | Mitsubishi VS-50609 50" Rear Projection...
Mitsubishi VS-50609 50" Rear Projection Television Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
