Question about Flotec Pool & Spa
Flowtec Wiring Diagram 115 volts to 240 volts
    Top Expert:
  • Flotec Master
  • 4,292 Answers
See wiring diagram on motor side
Posted on Sep 20, 2017
  • 19 Answers
SOURCE: I am concerned the wiring diagram provided for a
Those terminals on a ductless split are reserved for the communication wires from the out door to indoor unit. L L N should be line 1, line 2, and neutral (ground) there should be a 1 2 3 N terminal block in the indoor unit also, those terminals would most likely be for the communication between the two units.
Posted on May 18, 2009
SOURCE: Free wiring diagram for 1978 Mercury Outboard 115 HP boat motor
I have a maintainance manual for this engine (I have the same one) with pages of wiring diagrams. What specific system/area are you interested in, I could scan in the page(s) and email them to you.
Mark
Posted on Sep 20, 2009
john224
  • 1378 Answers
SOURCE: pool heater thermostat lights up but water do not
There should be a large, easy to read diagram under the cover once you remove it from the heater. Is the one under your missing or unreadable? Hayward doesn't publish one on their tech website or residential documents page so I have an email into our tech support contact asking for one in case yours is missing. If you find it under the cover please add a comment to that effect. FIXYA website has not been letting me post pictures lately so getting you the info may be a little difficult.
Posted on Dec 29, 2009
  • 149 Answers
SOURCE: I just need a wiring diagram---with a thermostat--
grainger has them- home depot. wire is easy wire one side straight to 1 wire on in coming power the other side use your thermostat to break curcit ie wire into stat out of stat to voltage
Posted on Jan 16, 2010
MOTORWIZJ
  • 1338 Answers
SOURCE: i'd like to know how to change a 115/230 volt pool...
IF YOU SEE ON THE LABEL ON THE MOTOR HOW TO CHANGE FROM HI - LO VOLTS . THATS ALL YA GOT TO DO ..THE WIRES HOOK UP NORMALY
Posted on May 29, 2010
I need to wire a SP2607x10
look on motor should be a diagram pump is wired from factory for 240 volts if wiring 120 volts you have to chenge the brown and white wire see diagram then black goes to F1 white goes to F2 where white wire is
Jul 08, 2014 | Hayward SUPERPUMP 2.0 HP, 115/230V
Wiring diagram RUUD UAPA-036JAZ
the condensor gets 240 volts a-c and 24 volts a-c to control contactor. pretty straight forward on this 3 ton unit. the 240 volts comes off breaker box and the 24 volts comes off thermostat and common of transformer.
Jun 10, 2014 | Ruud Heating & Cooling
How do you switch from 240 volts to 115 volts on magnum force pump
Is the motor a Dual voltage capable motor?
If so, the diagram for voltage change should be on the label.
It is also on the inside of the back cover were the wiring comes into the motor.
Most likely it is an AO Smith Motor that Jacuzzi used for their pump. The newer motors today are really easy to switch between voltages. There are 3 male spades on the back of the motor and a wiring plug with 2 female connections. You should easily see a diagram/bold arrow, for which 2 connections/spades are for 240 and which 2 for 120. Just lift and move the plug to one side or the other. 1 spade will not be used.
Take a look at the picture:
May 23, 2014 | Jacuzzi Pool & Spa
Wiring schematic for MTB217 cooper b line
I would suggest taking a closer look at the motor name plate. I am not familiar with a 120/240 three phase service. When I checked the web it shows: Voltage 115/230 (that is single phase), Max Amps 115 Volts = 19.2 Max Amps 230 Volts = 9.6 , Single Speed, Square Flange, RPM = 3450, Threaded Shaft, Frame = 48Y Used on the following models: Sta-Rite Max-E-Glas, Max-E-Glas II, Dura-Glas, Dura-Glas II, Dyna-Glas, Dyna-Max Pentair Whisperflow, Pinnacle and Anthony AR2 Series. You should also show what voltage you are connected to.
Mar 14, 2014 | A.O. Smith SQ1102 Pool Pump Motor
I have a Dayton Pahse 1, 3/4 HP motor that shows 115/230 volts on the label. I just had an outlet coverted to 240. I plugged it in and the motor barely moves and sounds like it is stuck or not enough...
there should be a diagram on the label for 110 or 220v-are you sure the last garage you ran it in was 220-it should only run at one of those levels without re-wiring the motor-cheers Denny
Oct 29, 2013 | Dayton Permanent Split Capacitor Motor Fan
What happen with a wrong connection on a single phase 2hp sp motor
I'm not sure which motor you have - the heading shows a 1HP type - yet you talk about a 2HP type. Anyway, the label on the motor should have a wiring diagram. You must have a label on the motor to know how to wire. It may have two diagrams - one designated as "high voltage" and the other "low voltage". Check the label for voltage.. it likely says "120/240 volts". The 120 uses the low volts diagram and the 240 uses the high volt diagram. If the motor has terminals L1 and L2, these will most likely be the point of connection for power - regardless if it 120 or 240, unless the label states otherwise. Unless the neutral connection is specified on the label, it does not matter which L1 or L2 you connect it to.
The other terminals will be required to be connected properly. Motors use these connections or jumpers to set options such as voltage, direction of rotation, speed(s), etc. An incorrect setting here can cause unexpected results as far as speed and rotation, or catastrophic results if you supply this motor with 240 volts but set the jumper for 120 volts.
Here's a link to their catalog with telephone numbers for you to review.
Apr 26, 2012 | A O Smith Motors A O Smith 1hp 115/230v Ur...
Electrical diagram for contactor (240 v/1 phase/24 v coil)
How to connect motor 1 phase with mcb , contactor , timer ,switch selector on off on , and lamp indicator
Feb 17, 2012 | Omega Trane Furnace Draft Inducer Blower...
I want to run this compressor "RITIN RT2012" 2HP 12L (1.5kW) compressor. It's a 110V AC drive unit and I have 240V. Can I run it or do I need to convert the Power supply.
You can't just run it on the 240 Volt supply. Check the motor nameplate. If it says it is rated for 110/220 or 115/230, or 120/240 Volts, then it is capable of running at 240V. This will require a wiring change, and you may need a larger size power cord.
The electrical diagram should be on the motor name plate or under the cover to the electrical terminals on the motor.
May 25, 2011 | Air Tools & Compressors
I need a wiring diagram for a farm duty 6k714k
It is generally located on the nameplate of the motor or inside the wiring housing where the outside power is brought in. These motors are usually convertible from 115 to 230 volt by merely switching a couple of wiring connections inside the wiring housing. If you can do so, 230 volt operation is much preferred due to the high speed start-up available and you can use wiring 1/2 the size required for 115 volt operation. Good luck!
Jun 05, 2010 | Dayton Audio Dayton 6K138 CapacitorStart
Pool & Spa Logo
136 people viewed this question
Top Flotec Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Flotec Pool and Spa Expert? Answer questions, earn points and help others
