Question about Cuisinart DLC-8S Pro Custom Food Processor
Replace the spindle on Cuisinart DLC-7 Food Processor
How do Ireplace the spindle on Cuisinart DLC-7 Food Processor
You need to pull the old one off, probably with vise grips and a lot of effort, and then order a new one. The new one is a tiny bit larger, so you'll probably need to order new blades, too. The new one slips right on, so there's no issue that would be the reverse of removing the old one. I read somewhere else that you have to pound hard to get the new one on, but that guy must have been speaking about the older model spindles. I was perplexed that the new one slipped right on so I pounded it to be sure and ended up breaking the tip of the new spindle and cracking the housing of the whole processor.
Posted on Jan 17, 2012
  • Cynthia Bentley Oct 25, 2012
    Where Can I get a new one
Did you contact Cuisinart? I just sent my DLC-7 to Cuisinart for repair. The start switch does not latch and works as a pulse switch.
Posted on Jan 07, 2009
Is the Cuisinart DLC 7 Super Pro Manual available to download?
Manuals can be found here:
Food Processors Product Manuals Cuisinart com
You'll have to look around at the options and pick one that looks like the one you have.
If you have an older one, the handle for the bowl generally goes in front, and check the base to see if the button that gets pushed down when the top is in locked position is in the front or the back... and try to match that. The DLC-10s has it in the front (7 cup machine), but many of the larger machines have it in the back. The feed tube matches up with the button when you put the lid on. If you put the lid on with the feed tube 180 degrees off, you can break the lid/bowl getting them apart again.
Getting this right is the most important thing... otherwise they just kind of work. The link for the 7-cup Pro Classic Food Processor (DLC-10s) has really good technique information with color photos. It's worth grabbing regardless of the machine you have.
http://www.cuisinart.com/share/pdf/manuals/dlc-10s.pdf
Other manuals have other recipes... so you might want to download more than one manual.
Jul 03, 2014 | Cuisinart DLC-5 Food Processor
Is an instruction manual for Cuisinart DLC-7 Super Pro Food Processor available to download?
You can go to: Food Processors Product Manuals Cuisinart com
Find one that is at least close, if they don't have your exact one. The manuals for each shape-size are pretty much the same... so find the one with the closest picture and size.
The chrome (DFP-7BC) is probably very close... (I'm guessing yours is the same only in white??)
Jul 03, 2014 | Cuisinart Food Processors
I want to open the base of the processor, but can't find screws
Remove the 4 rectangular rubber pads on the bottom.
Later you will need some Rubber Adhesive Glue to place them back.
This will give you access to the 4 Phillips screws.
I presently own a Cuisinart Food Processor Model# DLC-7.
I hope this helps you.
Dec 29, 2009 | Cuisinart DLC-5 Food Processor
Cuisinart Processor workbowl lid fitting
Cuisinart DCL-7 replacement work bowl lid is cuisinart dlc-017bgtx work bowl lid fitting with large feed tube.
Jun 05, 2009 | Cuisinart DLC-8S Pro Custom Food Processor
I have a very old cuisinart food processor
Unfortunately the CHM models no longer have replacement parts. If the workbowl parts says something like DLC-7 or DLC-10, then you can call Cuisinart and get replacement parts. CHM models would require finding somthing on eBay.
Aug 24, 2008 | Cuisinart DLC-10S Pro Classic Food...
Plastic bowl of Cuisinart DLC-7P will no longer lock in place
Buy replacement plastic bowl of Cuisinart DLC-7P is Cuisinart DLC-005AGTX-1 work bowl 14 cup.
Jul 15, 2008 | Cuisinart DLC-5 Food Processor
Need manual for food processor
Found it at:
http://safemanuals.com/user-guide-instructions-owner-manual/CUISINART/DLC-10S-_E
Apr 08, 2008 | Cuisinart DLC-10S Pro Classic Food...
Cuisinart DLC-8S Pro Custom Food Processor Logo
1,573 people viewed this question
Top Cuisinart Food Processors Experts
Henry  Thomas
Henry Thomas
Colin Stickland
Colin Stickland
downhille
Are you a Cuisinart Food Processor Expert? Answer questions, earn points and help others
