I have a 32" Panasonic lcd viena tv that was working just fine at my sisters and when we brought it over to my house and set it up the tv is completely dark but the sound works
  • 56 Answers
SOURCE: remote control code for 32 inch lcd EMERSON TV
http://www.hifi-remote.com/ofa/codes-tv.shtml#tv t
Posted on Feb 02, 2009
dsacco86
  • 1077 Answers
SOURCE: Element 32'' LCD TV, has picture but no sound
The S-video cable doesn't have hookups for audio, only video. It's better than the video coaxial cable. But, you still need to hook up the right and left audio coaxial cables.
Posted on Feb 09, 2009
falter
  • 245 Answers
SOURCE: Hitachi 32'' lcd tv picture runs slow sometime and goes dark
go in touch wit HITACHI costumer help and service and tell them ur problem u have.....how old is ur TV?
hope u get a answer from hitachi....and good luck
Posted on Mar 12, 2009
  • 14 Answers
SOURCE: connect home theatre to 32" lcd to ps3
Depending on the year of your model of VIZIO your digital optical output may be tied to the DTV input only. Meaning the only time you will have audio coming out of the digital optical output is when your using the tuner and your on a digital channel. If your television is newer and the digital optical output is in white on the back of the television than it is tied to HDMI and the DTV Tuner and you will pass audio through the digital optical output when using HDMI or the Digital Tuner.
Now to get connect the HT: Normally you would run a digital optical cable from the source device to the home theatre system. Meaning if it was a PS3 you would run a optical cable from the Digital Out on the back of the PS3 to the Digital In on the Home Theatre receiver. If it was a DVD player than you would run the optical cable from the DVD player to the HT receiver. If you have a newer VIZIO and the optical output is in white and not black than you can run HDMI from the PS3 to the VIZIO and then run a optical cable from the VIZIO to the Home theater receiver.
You will have to adjust the audio setting in the PS3 to run audio out of the HDMI port if it is set to run audio out of the Digital Out or AV out. Also, if your going to run audio from the PS3 to the HT receiver through the Digital Out then you need to change the audio setting in the PS3 to Digital Out.
1. Select (Sound Settings) under (Settings) in the home menu.
2. Select [Audio Output Settings].
3. Select the input connector on the audio device.
Channel numbers and audio formats that are supported vary depending on the connector in use. AV is 2 ch. only, Digital Out is 2 ch. & 5.1 ch, and HDMI is upto 7.1.
Posted on Apr 05, 2009
pabloloco
  • 2335 Answers
SOURCE: hdmi to panasonic tv no desktop display only
I can help with getting your desktop onto your TV, but sound from your computer through HDMI can be much trickier.
If you only see a background picture on your TV, then your desktop has been either "extended" or "stretched" onto it. It is essentially a second independent monitor and you can drag applications over to it to see them.
To view your desktop and start menu on your TV, you need to run ati catalyst and "clone" your TV with your computers monitor. Do this by right clicking the picture of the second monitor in the catalyst display manager and choosing "clone". Now your tv and your monitor act as one.
Although i tried 3 different ati cards with hdmi outs that claimed to pump audio through hdmi, none of them worked for my HP PC. You will need a grey widget adaptor between your computer and the hdmi cable. In the end though, there's a conflict between my sound card and ATI's HDMI audio that cannot be resolved. So I run a digital SPDIF signal instead through an rca cable and get 5.1 dolby at my amp that way. Good luck.
Posted on Sep 20, 2009
My VCR won't interface properly with my TV. Any time I try to play a tape, all I get is a blue screen. I've tried using it with an older TV, and the tapes play fine. Any help is appreciated.
Make sure that the tv set's rf frequency is set to the same rf as the vcr. If both are identical then something is definitely wrong with the tv set since the vcr works fine with another set.
Jun 13, 2016 | Viore 32" LED LCD HDTV
Panasonic th32lru30
To make it a factory reset, you have to enter its service mode option. If you wish to get details about how to enter service mode, and adjust parameters there, check this link. http://electronicshelponline.blogspot.com/ It has details.
Jul 04, 2013 | Panasonic TH32LRU30 32 LCD TV
Panasonic 32" LCD TV showing almost Black pictures
If a 4 year old 32 inch set likely cheaper to replace than repair it assuming parts are even still available.
Aug 25, 2012 | Panasonic Viera TX-32LX77 LCD TV
I moved my TV from my old house to my new house. Before it worked just fine at my old house, brought it to my new house and it just doesn't turn on! Tried different outlets, wires, etc.
Check the power at the plug point. Check the plug of the TV. If there is no life, then you will need to open the TV panel and check for a blown fuse, a circuit break while transporting, a loose connector within the set or a possible damaged SMPS>
check this link below for some tips on the power supply:
http://www.fixya.com/support/r5826301-working_switch_mode_power_supplies
Feb 21, 2011 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
Remote won't turn on set.
Panasonic is te best in TV or DVD.I have 10 years a Panasonic TV.Please dissasambly and clean the remote control rubber pad and change the battery every 8 mounth,and all is OK.
Sep 01, 2009 | Panasonic Viera TX-32LX70 32 in. LCD TV
Picture will not come on but sound will.
My Panasonic TC-26LX60 Lcd tv powers on and there is sound but no picture (video)
Aug 26, 2009 | Panasonic TC-26LX60 26 in. LCD Television
LCD TV Sound Problem
look if the cable it corect
can u click in the menu /reglage son/shoose on or active for all
Jan 21, 2009 | Panasonic Viera TX-32LX70 32 in. LCD TV
I have sound but no video at all
A defective backlight.  I've had the issue several times now with my sharp 32" lcd tv and in the process of trying to get a replacement tv.
Oct 27, 2007 | Olevia LT42HVi 42 in. LCD Television
Televison & Video Logo
18 people viewed this question
Top Televison & Video Experts
Electro Med Services...
