Question about Toshiba 32A33 32" TV
Demo mode wont shut off
My uncle's tv is about 4 years old. on power up , everything is working fine. about 5-7 minutes later after tv warms up, starts to cycle through demo mode on screen. I managed to turn if off through menu and even take batteries out of remote, yet demo mode still re-appeared. I saw other problems on this page mention remote sensor in the TV and microprossor. anyone see this problem b4. Should I try the remote sensor assembly on the TV first. Don't want to start throwing parts at it until I can either rule out or prove something is at fault. Anyone know if I can just disconnect the remote sensor inside to see if my screen demo goes away ?whithout causing harm to other components inside ? many thanks in advance, mike
  • 1 more comment
  • Anonymous Dec 06, 2008
    HOW DO YOU GET TO DEMO MODE IF YOU CAN'T CONTROL THE TELEVISSION...THERE MUST BE A BUTTON OR SEQUENCE OF BUTTONS TO PRESS AND HOLD TO SHUT THIS FEATURE OFF...MY T.V. IS STILL CYCLING BETWEEN T.V. INPUT 1,2,3, IN EVERY LANGUAGE...
  • cwest2930 Dec 09, 2008
    I have the same problem with my toshiba. The remote has quit unable to use universal remote on tv. I'm lost.
  • bizzyfee May 11, 2010
    How can you just turn the demo mode off when you can't get any of the buttons on the remote to respond, or the buttons on the TV to respond? I am having the same problem.
Go to the demo mode and press off. I just did this after 2 frustrating days of demo mode. It went off instantly when I did this
Posted on Jan 12, 2008
Ok , let us know if the " hold menu button in for 20 seconds " works. I'll pass this on to my uncle also .
Posted on Jun 10, 2007
Some friends of ours has this problem also. I've been trying to find a solution over the internet for a few hours now. I came across one page that said to hold the menu button on the front of the tv in for 20 seconds and that should fix it. guess we'll see.
I have this same problem, just started 2 days ago. Changed batteries in remote and everything - driving me nuts- now i cannot change channel or adjust volume! I powered off TV, took batteries out of remote, turned back on and now still stuck. I think we bought junk!
Posted on Jun 07, 2007
TV keeps shutting off. It will stay on a few minutes when cold but then will shut off. When we turn it on again after its warm it shuts off and won't stay on. Could something in menu bar have been changed...
It looks like a power supply SMPS problem.
You have to replace the optical isolator in the SMPS feed back circuit. It is a 4 pin IC
Mostly this may be the problem. Take the help of the service personnel.
Sep 24, 2010 | RCA TruFlat 27F520T 27" TV
Bad picture until tv warms up
well its a problem fo an ic causing the issue that needs to be replaced
May 30, 2008 | Toshiba 57HX81 57" Rear Projection...
No Heat but everything else works
Magnetron and diode most likely. Need more info.
Nov 02, 2009 | GE XL1800 1100 Watts Microwave Oven
TV wont turn on, makes buzzing noise and shuts off
I have two RCA HD52W59 TV's. I have had one for 3 years and one 4 years. The one I have had for 4 years is giving me the problem. Last week the tv turned off while watching it. It wouldnt come right back on. 10 minutes later we tried and it worked fine. the other night the kids were watching and it turned off and smelled like something burning. I tried turning it right back on and got no power at all. I tried to turn it on two days later and it made a buzzing noise and the green light went out. Never did get a picture, no powering up on the screen. Any ideas? Don't want to spend alot of money. Really loved the TV hope it isnt junk now. Better yet I hope the same thing doesnt happen to the other one I have.
Jan 22, 2009 | RCA HD52W59 HDTV Projection Television
Samasung RS2577Sl
It might be that your fridge went into something called 'demo mode' that shuts the compressor down so as not to waste electricity on the showroom floor. The freezer and fridge sides both start to warm up, but the temperatures shown on the outside of the door never change, so you don't know you have a problem until you open the fridge or freezer and find you have a melted mess. My Samsung is 7 years old and we run into this problem frequently when our power is on and off, like just recently with hurricane Ike. Per the Samsung website, the cure for 'demo mode' is to unplug the fridge for 1 minute then plug it back in. They also suggested pressing Power Freeze and Freezer Temp together for 8 seconds until you hear a chime to cancel demo mode. Good luck. I really dislike this machine.
Jun 29, 2008 | Samsung RS2578BB Side by Side Refrigerator
JVC HD-52G786 shuts off
Do you have your TV plugged directly into the wall? You cannot plug into a power strip, it needs its own direct power source. Also, I have heard that there can be electrical problems inside. I have this same model, I love it, picture and sound. I just replaced the bulb for the first time last night. It was a little premature to replace it now but I know what caused it. I bought a new bulb and it works like a gem. If you ever need to change the bulb do it yourself. It takes maybe 2 minutes. The bulb looks like the Flux Copassitor and all you do is remove the door in the back on the side. Unscrew the the 2 screws that hold the bulb in and just pull out. When you put the new one in make sure you do NOT touch the glass on the new lamp. Just slid it in and screw the 2 screws back in and make sure the door is closed and tight. My uncle had a service guy do his and he got raked for 5-$600, The bulb costs about $200. Should last about 5-6 years at a rate of 5-6 hours of TV on time. Hope this helped. If not, sorry, but at least you know how to change the bulb. Good Luck!!!
Apr 07, 2008 | JVC HD-52G786 52" Rear Projection HDTV
Tv has an advertisement that wont go off
Press the up and down volume buttons on the TV at the same time. This will turn off demo mode.
Aug 29, 2007 | Philips Magnavox 27MS343S 27" TV
Starting system cold, no sound for 2-3 minutes
Its not worth having it looked at. $100.00 for a new 400.00 unit? My unit is doing the same thing. Turn it on and 2 to 5 minutes later it may come on. Change to video 3 4 5 etc it stop again. Only works with a cold start. Something in the unit has failed and is heat related. My original Kenwood 20/20 recevier still works. Must be 40 years old. New products just last 5 to ten years max if your lucky.
Dec 17, 2006 | Kenwood VR-6070 Receiver
Toshiba 32A33 32" TV Logo
1,042 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
