Question about Bissell 9500 ProHeat 2X CleanShot Upright Deep Cleaner, Red Berends Vacuum
Automix knob and piston problem.
We have a Bissell model 8905. We took it apart to clean it and the automix piston came out. We cannot figure out which position to put it back into it's housing so that the knob will catch it.
  • ronaldcorey Jan 16, 2009
    I have the same problem.
  • Bissell Master
  • 43,501 Answers
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
45we
Posted on Sep 30, 2010
My bissell proheat pro tech 7920 does not use any shampoo although I have cleaned the bottle and valve
It may be the valve in the base of the machine, not the valve in the bottle. Flush well with clean water. Sometimes the jets get a little clogged up - especially if you don't use bissell solution - or if they get dirt in them. I cleaned them and mine worked again.
Feb 27, 2010 | Bissell 7920 ProHeat Pro-Tech Upright...
Reassambly bissell 8910
I am in the same situation with my 8910 if you get an answer will you let me know my email is codeman750@msn.com
Aug 09, 2009 | Bissell 8910 ProHeat Clear View Upright...
How to put automix piston back in place of a Bissell Power Steame
Called the Bissell Power Steamer customer service number and the CSR explained how to turn the water control knob counterclockwise 260 degrees until the automix piston grabbed hold. Worked like a charm. Thank you Bissell company.
Jun 18, 2009 | Bissell 1697-7 Powersteamer Pro Deluxe...
The solution in my smart mix will not mix with water and the button just keeps going round and clicks and will not stop on either water or solution.
The smart mix knob is connected to a piston that slides up and down into the automix assembly. This piston has come off of the smartmix knob and left the unit on water only setting. Sometimes the smart mix knob breaks on the bottom side letting loose the piston.
This can be a difficult repair. You have to unscrew the flow indicator window and remove the fan and screen(pay attention to how they come out, most people want to put the pointed end of the white screen down. It goes up.) Place a piece of 2X4, a book, something underneath the machine, between the rear wheels. This will lift the wheels into the air, and keep everything in place when you remove the hood. Take the 6 screws out that hold the hood and lens. As you remove the hood try to do it slowly and pay special attention to any hoses that might try to pull off with it. If you don't get those hoses back into the right place, the machine will not work. The piston will probably be stuck into the automix assembly when you get the hood off. It is a three inch black cylinder with an O ring on it. If you hold the hood upside down and place the cornered side of the piston into the corner of the housing between the knob and the solution chamber, you should be able to hook the winding on the knob with the piston and then turn the knob to screw the piston down into the windings. It won't lock into place, but hold it there well enough to put the machine back together correctly.
If you feel like you're forcing something when putting the hood back on, you probably are, so stop and check to make sure all the hoses are where they are supposed to be.
Good Luck
Nov 25, 2008 | Bissell 7901-1 ProHeat Scotchgard Upright...
Bissell 7901 proheat solution wont mix
Good Luck
MOD 1699-f reassemble cleaner fluid mix switch
This is one of the most difficult machines to work on, but I can help you to reassemble the the "Automix Assembly." There is a black piston with an O ring on it that has to be put in place before the hood is put back on. This part will actually set inside the windings on the smart mix knob, before the hood is placed on the machine, and as you place it on the machine, the piston will have to slide down in the hole on the automix. Getting the piston into the windings can be a little tricky. You might have to play with it a bit and it doesn't lock into place. It just sits in there loosely, just enought to hold it in place while you put the unit back together. It's hard to describe how to place the piston in the windings of the knob, but I'll give it a try. Hold the hood upside down and place the squared corner of the piston into the squared corner of the hood between the knob and where the solution tank would sit on the opposite side. Now you can turn the know and screw the piston down into positon and the hood is ready to install.
Hit: put a book or peice of 2X4 under the unit between the rear wheels to lift the wheels off the work surface and help line everything up. If the hood doesn't feel like it is seating into place correctly, something is wrong. Very important on this machine: if even one hose is slightly out of place it with not pump. If it doesn't pump alway check the attachments to see if they pump. It they don't, then you might have a clogged heater.
Good Luck
Nov 20, 2008 | Bissell 1699 ProHeat Clear View Upright...
Bissell 1699Y re-assembly problem
heatman101
trwy
Oct 19, 2008 | Bissell 1699 ProHeat Clear View Upright...
Bissell 1699-1 reassmble
I FIGURED IT OUT!!!!YAY.
the piston comes out easily with a pair of plyers.hold the cover on your lap upside down, smart mix knob closest to you,there is a slot for the piston to fit in to, turn the knob slightly (about 1/2") you will see that you can lift the knob slightly out of the way then you can slide the piston into place. leave the knob at that position to hold the piston and slowly put the cover back in place. if the piston goes in,just before you put the cover all the way down turn the knob back to water only.if everything is in place, PUT THE SCREWS IN!!!! hope this helps.
Jul 26, 2008 | Bissell 1699 ProHeat Clear View Upright...
MY BISSELL DOES NOT WORK
When you put the top back on, did the piston line up and go into the hole? The piston mounts on the smart mix knob from the bottom, just before the top is on, put the smart mix knob in the water only setting, then push the top down. You could also have pinched a line if any of them aren't in the right place.
Mar 17, 2008 | Vacuums
No water out bottom..
Pump may be bad, also the cap for the flow indictor may be leaking air. Does the automix vale knob turn easily? If it turns real hard, then piston that the knob works may be jammed. Ckeck the seals on the bottom of both tanks to make sure they are on the tank and not sitting in the holes.
Oct 04, 2007 | Bissell 1698 PowerSteamer ProHeat Upright...
Bissell 9500 ProHeat 2X CleanShot Upright Deep Cleaner, Red Berends Vacuum Logo
240 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
