Question about Singer 7436 - INGENUITY
My thread take up lever looks like it is bent
I heard a clanking noise and I thought it might be my sewing needle was dull.
So I replace it and was doing ok but it started making a noise again and it looks like the thread take lever is bent
Any advise?
  • talk2ginny
    talk2ginny May 11, 2010
    Hi, and welcome to FixYa.I don't own the Singer 7436, but I found a photo of the machine, and when you thread your machine, you need to raise the take up lever high enough so you can bring your sewing thread around it. When your take up lever is raised as high as it will go, very gently press your finger on the lever and see if will move back and forth (do not force it back and forth, just try to determine whether it is loose). Also, look at the lever dead-on center to see if it might be bent or slightly leaning to one side.
    I checked the Singer web site and found no help there, although they do have a customer service line you can call. I found two reviews on another different web site, one very positive and one very negative. If it is not too late to exchange your machine for a new one, that is what I would do - if it does break down after the return window has passed, you might have difficulty finding a repair shop that does warranty work for Singer.
    FYI - Singer is now part of the Viking/Pfaff group. If there is a Viking or Pfaff dealer in your area, call them right away to ask if they carry Singers and/or perform warranty work on your machine. If so, take the machine to the repair shop (you'll probably need to provide a dated proof of purchase or a receipt) and have it looked over - it should not cost you anything and might save you heartache and money in the future. FYI - if you do take off the covers - don't tell the dealer - "unauthorized" consumer repairs can void your warranty.
    If you have a minute to rate my answer, you will help me to learn more about the needs of those of you who write in for help. If you would like some additional pointers about pinpointing mysterious noises, please feel free to comment.
  • 27 Answers
Sounds like a bunch of thread caught up in the take up lever ,check that first open the side cover and look
Posted on Jan 13, 2009
Wont pickup bobbin thread when sewing.
Make sure you are using a brand new needle. Bent/damaged/dull needles frequently will fail to pick up the thread.
If it continues to skip stitches, it most likely has a needle/hook timing issue--the needle arrives at the bobbin at the wrong time to intercept the bobbin thread.
There are web sites and videos available that discuss sewing machine timing, or you can take it for service.
Sep 10, 2016 | Sewing Machines
Needle not picking up bobbin thread and it makes funny loud noise
Sometimes both symptoms are a result of a bent, dull, or damaged needle. Try installing a brand new needle.
If it is still not picking up the bobbin thread and making a noise, take it for service. It most likely has a needle/hook timing issue and the noise could be the needle making contact with the needleplate or in the bobbin area. Continued use could cause the needle to break and flying pieces of needle, in most cases, are not a good thing.
Jun 18, 2016 | Brother Sewing Machines
Why does thread keep breaking today?
Install a new needle. Needles should be changed frequently. A bent, dull, or damaged needle can cause a lot of havoc. A new needle is the most economical fix available.
Remove the thread. RAISE the presser foot, then rethread from the beginning. Make sure it is threaded correctly. Usually, thread breakage indicates mis-threading or the thread has jumped out of the take-up lever or another thread guide. Make sure that the thread is not hanging up on the thread spool or around the spool pin. Also check that the tension has not been set too tight.
Feb 06, 2016 | Sewing Machines
Sewing machine clunking and missing stitches
the best advice is having the machine serviced, but here are some other suggestions
Jan 29, 2014 | Sewing Machines
I have a janome 11000. it jammed while embroidering a project. The underneath was rats nest and my needle bent and gouged up my bobbin case...Replaced the case and now the machine makes a clicking noise...
sometimes when a needle gets bent, it can cause the sewing machine to need a adjustment by a technican.
sometimes a jam can be caused by the thread coming off the thread take up lever
or the bobbin is turned the wrong way in the bobbin case
or the bobbin was not thread correctly
Sep 12, 2013 | Sewing Machines
Thread on bobbin does not attach to needle when needle is turned down.
Depends what was causing the noise. It could merely have been the build-up of lint and thread. However, something else could be the cause.
First: Install a brand new needle. A bent, damaged, old needle will frequently cause noise because it is striking something it should not. A dull needle will also make a thunking sound as it tries to penetrate the fabric. The needle should be changed about every 8 hours of sewing...a very inexpensive fix!
Also, be sure to following the oiling instructions (if any) in your manual. Use only fresh good quality sewing machine oil and apply only 1-2 drops in each spot as instructed.
If the top thread still fails to pick up the bobbin thread, it is likely the machine has been knocked out of time. Take it for service.
May 02, 2017 | Janome Sewist 525S Mechanical Sewing...
10000 janome jamming fly wheel won't turn
I would replace the needle anyway. It's hard to tell if one is bent or not.
Remove your feed dog/needle plate and the bobbin cover. Take out your bobbin and bobbin carrier.
Get out a magnifying glass and really examine. Look for thread ends in between moving parts.
Also check the thread pathways. Especially where the take up lever is hidden. I've heard of some ladies finding threads snarled up in that area which caused problems like this.
Good luck. If all else fails take it in for repair.
Nov 04, 2012 | Janome Sewing Machines
Top needle thread keps breaking
top needle thread breaking is probably caused by a dull or bent needle or a needle that is not the right type for the machine
Apr 12, 2010 | Janome MyLock 634D Mechanical Sewing...
Machine sews for a couple of inches then jams up, thread bunches up on back side
1. try rethreading the needle from the spool down (make sure the thread goes through the take up lever. Often the thread comes out of the eye, especially if it is filament or stiff)
2. take out bobbin and make sure you put it back in the right way. Rethread it.
3. change the needle ( it may be dull or bent)
Feb 17, 2010 | Husqvarna Viking 1
Thread's bunch-up lower fabric
Make sure your bobbin is in proper and secure, it should click when you put it in. Also try putting a new needle in. Clanking noises are sometimes a bent needle.
Jul 16, 2009 | Singer 3116 Simple
Singer 7436 - INGENUITY Logo
480 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
