Question about Whirlpool LGQ9858P Gas Dryer
Dryer not turning on when pushing button.
Just did a load, now when I push the button, I hear a click but motor does not turn on. There is power since light comes on. Is there a reset button or maybe a bad sensor? Worked 10 mins ago when a load finished.
  • corvettece Jan 05, 2009
    Dryer 4 years old. No temp problems, went through full cycle. Opened back, no loose wires. When I press the start button, I hear it engage. When I move dial to off, it disengages... same if I unplug unit. Trip seems to be working fine. Is there a way to bypass on button to see if it's faulty? Has 3 wires, 2 blue and one pink/black. Both blues run to a white tab near the exhaust, unsure where pink/black run, goes to a nest and must reconnect to another wire.
  • Default KITT
    Default KITT May 11, 2010
    The dryer bay shook a connection loose.
  • 56 Answers
The power relay is probly gone have a appliance tec take a look at it . it's about a 25.00 fix.
Posted on Jan 05, 2009
  • 716 Answers
Try Unplugging It For A Minute Maybe You Had To Much In It And The Motor May Have Gotten To Hot And Tripped Itself. If This Doesn't Help You'll Need To Take It Apart And Look Around For A loose Connection Or A Trip Switch. Maybe Even The Belt Broke If Its An Older Model.
www.Myspace.com/CrossRoadsToNowhere2007
On my whirlpool duet dryer the power turns on to my dryer but when u pushes the start button u just hear a click and nothing else happens..
the dryer belt may be broken, when you push the button you hear the motor running. you can either try and fix it your self or call a authorized dealer or service center, look in your area using the internet, yelp, call information, yellow pages, white pages, look on the machine for service calls, call sears, home depot, lowels, applicance service center, dial 0 ask for whirlpool costomer service, or service and repair shops.
Apr 22, 2015 | Whirlpool Dryers
Why will my dryer not start, but makes a clicking sound?
If the motor runs and the drum doesn't turn the belt may be worn or broken...or you may have a faulty idler
Regards,
Dennis
Aug 15, 2014 | GE Dryers
My Estate dryer won't turn on. I push the on
See if the lever on the door switch clicks. You cannot hear a click or the lever is missing that could be the problem. On the backsides of the dryer is a dust cover. Remove it and look for reasons why the duct fuse might melt and kill power to the door switch.
See the lever there? That must be in for the door circuit to activate the motor.
Manual and more HERE
Sep 08, 2011 | Estate EED4400WQ Dryer
I have a power but dryer wont start after i push start button. i can hear the click sound after i push the start botton but doesnt start.
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 20, 2011 | Samsung DV419AGW Dryer
My lady kenmore dryer will not turn on at all. I can hear the timer going but when i push the button nothing happens. I can also hear the button click when i push it.
heatman101
Apr 21, 2011 | Dryers
Won't start just clicks when i push the start button. When I push the start button I do hear a faint click in the selection ( color, white.etc.) button
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The
Dryer Repair - The
heatman101
Mar 05, 2011 | Kenmore Dryers
My Dryer is a Maytag MGD5570, just under 4 years old. The dryer has power (light is on), but when I push the Start Button, nothing happens. I checked the Thermal Fuse with a continuity tester and it is not...
Dryer Repair - The
Dryer Repair - The
heatman101
Feb 03, 2011 | Maytag Dryers
Maytag Gas Dryer has power (light is on), but when I push the Start Button, nothing happens. The Dryer is a Maytag MGD5570, just under 4 years old. I checked the Thermal Fuse with a continuity tester and...
I had the same problem. Here's a quick test you need to do. It will take two individuals (unless you're extremely talented) Open the dryer door and push in the door switch... and hold it in. Have the other person push on (and hold) the start button on the console. At that same time everyone is pushing the switches take a free hand and reach into the dryer and try to spin it. Sometimes just a little push (assistance) is all it takes and..... bingo the dryer starts up! If that's the case... your motor is on its way out or it's gone. Usually due to the bearings on the motor being badly worn.
Feb 03, 2011 | Maytag Neptune MDG5500AW Gas Dryer
My dryer is getting electrical power. But when I turn the power knob onto ON, nothing happens.
it may be the door switch, but if you hear a click when you push the start button then the motor reset button tripped. You should be able to set the dryer on its front side and see the motor reset buttons as there are two one trips one resets, push the reset in it should click and then plug it in and see if that helped. Hope this helps if not feel free to ask more info as I am more then willing to help Tim
Oct 16, 2010 | Hotpoint NWSR483EBWW Electric Dryer
Whirlpool LGQ9858P Gas Dryer Logo
125 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
