Can not find channell to play play stationon.
Unable to play play station on tv. all cables are connected correctly coming from game to tv
  • medicff301 Jan 05, 2009
    Where is the TV/Video button located
  • 716 Answers
Are They The Jacks? If So You Need To Hit The Tv/Video Button.
Posted on Jan 05, 2009
  • Michael Fisher
    Michael Fisher Jan 05, 2009
    Either On The Tv Or The Remote. Sorry I Cant Give U The exact Position As I Dont Own It. If You Need I Can Look It Up Just Tell Me The Model Of The Tv And Remote And Ill Find Out.
After connecting my ps2 to my Technika 26" tv/dvd combo using a red, green, blue AV component cable, I still cannot find how to tune in a channel to be able to play.
With the composite cable you so not need to retune a channel! You just need to select the correct AV channel from your remote......turn on the ps2 with a game playing and select AV on remote and keep pressing it till you get the Composite channel playing your ps2 game!
Oct 19, 2014 | Televison & Video
Can't get the play station to work with the tv. The av is plugged in correctly and the ps is turned on. Don't know which channel to go to, and when EXT we tried all different inputs and it still doesn't...
Which generation playstation are you referring to The PS2 or PS3. The PS2 would be connected with a composite cable by default i.e red white and yellow cable. Connect the cable to the corresponding input on the TV, match color codes. Switch to correct input by using your remote controller. Press the AV button and a list of inputs come's up.Select av1 or av2 and check if you get a picture. If you use a ps3 then same as before press AV button on remote and select appropriate option on screen HDMI,Component or Composite.
HDMI looks like this
Component
And Composite
Jan 16, 2011 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Tv and ps3 plugged in and on. av channel shows an empty screen
Follow these steps to resolve your problem:
1. Turn off the PS3 so it only shows a red light. You can hold the power button on the front until it goes into standby. To be sure, flick the power switch on the back of the Play Station 3 off and then back on.
2. Make sure your Play Station 3 is connected to your regular TV (not HDTV) with the standard video cables.
3. Press and hold the power button until the screen "flickers" and then immediately release. This should reset the video settings.
4. Wait a few seconds, and the Play Station 3 (PS3) logo should appear.
If this does not resolve the problem, follow these steps:
3. Press and hold the power button on the front until the Play Station 3 beeps and then turns off again. This should reset the video for you and you can turn it back on after this.
Jun 10, 2010 | Sony Playstation 3 (PS3) Console
How do you connect a Nintendo 64 game station with 3 cables (Red,White and Yellow) to a Dynex Television. We tried the input options on the back of the TV. On the menu we selected both Channel 3 and...
connect the AV cable to the red white and yellow input outlets on the tv and press input on your remote you have to be on video 1, 2, or 3 to play the nintendo 64
Dec 26, 2009 | Dynex DX-L22-10A 22 in. LCD TV
How do i get to the aux channel on a Sansui TVM131AD
if your tv doesn't have an AV button either buy a all in 1 remote or a RF cable compatable with your game console and tune the tv manually as you would tune tv stations
May 15, 2009 | Televison & Video
Super nintendo will not play Tetris
Clean the game with q tips with alcohol on them, then, tune the tv to channel 3 with a remote.
Mar 17, 2009 | Nintendo Super NES Console
Cant find channel for playstation 2
I have got a Finlux plasma television and i cant find my instructions. I have just been given a play station 2 and i have put it all correct in my television but its not coming up on my screen. I dont know what channel to put it on, please can you help me!?
Feb 16, 2009 | Sony PlayStation 2 (PS2) Console
PHILLIPS HTD 7001 IPOD DOCKING STATION
I also have the same problem but now I think it's the type of I-Pod you use. Do you use the I-Pod 80 Gb video or the newer 160 Gb I-Pod with the cover flow etc. ? The documention of the HTD7001 says it's only support some I-Pods. I would know sure if I would have a type of Video I Pod wich is supported by the documentation
May 31, 2008 | Bose 3 2 1 Series I DVD Home Entertainment...
Akai VSG285 video - I can't tune any TV stations thru to the VCR?
This sounds like a hookup or programming problem.
The typical hookup is cable/satellite box output to VCR antenna/RF input, then VCR antenna/RF output to television input. Since you are able to watch pre-recorded tapes, the latter is already correct. There are other ways to connect, using the audio/video outputs of VCR to audio/video inputs of the TV. Older or low end TV sets may not have these connections.
If by chance you are using an outdoor antenna (not cable or satellite) then the antenna connects to VCR antenna/RF input and VCR output as above. You will also need to program the VCR into the stations- most late VCRs will scan for active channels, and program themselves to those channels.
I'm not sure of the capabilities of newer cable & sat boxes, but generally, you had to tune that box to the channel you wanted to record. The VCR is set to channel 3 or 4 depending on the output of the cable box.
Lastly, most VCRs of the last 10+ years require the remote to setup advanced functions, such as timed record, date & channel setup functions. The buttons on the VCR itself only do very basic functions, Stop/Play/Rewind/F-forward/Eject etc.
If you don't have the orig. remote, some universal remotes may be able to do advanced programming functions.
Apr 09, 2008 | Televison & Video
Remote not working correctly
It all depends on what and how the cable box is connected . Do you have an outside or inside antenna connected? If you have a cable box , why would you want to go to another station on your tv? Does the cable box have an rf output that connects to the tv through he antenna input on the back of the set? If so the tv should stay on a station to recive the stations thru the cable box. Didnt the cable tech explain how to use the system?? If you dont understand how to use the cable you should, for sure call the companey, and see if they can explain how they hooked up your sysytem as theres many many ways to do this. If you have the owners manual what im about to explain is in there too. On the tv remote theres a button called menu, press it once. Use the up and down arrows to scroon down and highlight the setup . press the ok or enter buttonpress the right language,then search for channels. When this is over then exit out of the menu, and try switching channels. If you still dont have any channels you gonna have to find out whats connected to your rf input as channels wont come in if theres not the right source connected. GOOD LUCK
Jun 18, 2006 | RCA G27303HP 27" TV
Televison & Video Logo
44 people viewed this question
Top Televison & Video Experts
