Question about HP DeskJet F380 All-In-One Printer
Running Vista and Hp F380 loaded disk but need to scan and can't
What do I need to load to have the whole printer system working. I need to scan and I can't
  • 30 Answers
Try to install the driver when the usb cable is DISCONNECTED from the pc. Please download the latest driver from
HP
http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?os=2093&softwareitem=mp-47767-1&lc=en&cc=cz&dlc=cs&product=1128296&lang=cs
and
follow the driver instructions. It will say when you need to connect it to PC. Dont install Windows default drivers ...
Posted on Jan 05, 2009
HP DeskJet F380 All-In-One Printer scanner does not work with vis
Same problem with Xp and same printer, Cannot add printer in control panel , printers. Can only be installed with original software, Try also uninstalling all printer software plug in and when vista pick up new hardware install software from disk and not auto
Aug 13, 2009 | HP DeskJet F380 All-In-One Printer
I know is an old machine but that's what I have
If you do not have the OEM disk, go to HP and put in the model number. When you get to the page, select "support".
You will be offered an opportunity to download software for your computer. Since it is an older machine, and "if" you have "Vista" you might NOT be able to get it to work..HP does not support older equipment with newer computer operating systems. If that is case - try selling it on Ebay and buy one that is compatible with your computer.
If it is compatible, when you download the drivers, make sure you download the whole file - not just the drivers. Download the operating instructions and follow them for installation, and operations.
I have done this several times and it works every time.
Good luck.
Mar 27, 2009 | HP DeskJet F380 All-In-One Printer
Scanning with HP F380 series
i had that same problem with mine a few weeks ago and my disc did not support it because i have vista so i went on line and down loaded a programme, so if you type in software download for deskjet just follow the programme you want and you should be able to scan
Mar 04, 2009 | HP DeskJet F380 All-In-One Printer
I can print and copy, but not scan with HD F380 using Vista. Help
Ensure any program that came with the scanner is installed on the computer and running (open the program).
Jan 29, 2009 | HP DeskJet F380 All-In-One Printer
Problems with HP deskjet f380. Will not print... scans and copies
the system for vista and xp is near to similar. so just click the following links 1 by 1 and go through the instructions as you r missing any minor step to be followed in loading your printer How to load a printer on a pc step by step instructions
http://freepctech.com/pc/xp/xp00168.shtml
http://kb.iu.edu/data/aksl.html
Installing a printer on a Windows 95/98 network
INSTALL THE PRINTER on a PC
ENABLE PRINTER SHARING
MARK the NEW PRINTER as a "Sharable" Printer
INSTALL THE PRINTER ON THE OTHER PCs
Troubleshooting Windows 95/98 networking problems
http://www.mcgill.ca/ncs/products/soho/networking/printer/
How to install a printer driver locally for a remote printer in Windows XP/ Windows 2000-
http://support.microsoft.com/kb/282842
Jan 06, 2009 | HP DeskJet F380 All-In-One Printer
New Laptop Vista Operating system Try to set up HP F380 printer
I am not technical some IT guru at our Head Office managed to install it and it's working fine!!
Nov 11, 2008 | HP DeskJet F380 All-In-One Printer
Scanning a photo
Make sure you have the HP imaging software installed and running first if you dont you can download the Vista version HERE that should do it
Jun 30, 2008 | HP DeskJet F380 All-In-One Printer
HP Deskjet F380 All-in-One Compatible with vista
I had the same problem. I could print, but not scan.
However, if you open up Paint and go to file and scan, it will scan your document. For some reason, using the scan button on the printer itself will not work with Vista, but using Paint will. I also heard that using Windows fax and scan will also work.
good luck
Nov 21, 2007 | HP DeskJet F380 All-In-One Printer
HP DeskJet F380 All-In-One Printer Logo
42 people viewed this question
Ben Johnson
