Question about Canon imageCLASS D320 All-In-One Laser Printer
Will not copy
I have toner in the Cannon Image class D320, but
the light to copy does not come on. Can I fix it
myself?
Thank you
    President:
  • 8,637 Answers
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Posted on Jan 25, 2009
ALL COPIES BLANK. NOT LOW ON TONER. ALREADY REMOVED AND SHOOK. D320
probably the problem is in laser shuter or toner cartridge pin in toner holder. But when you try to copy, when paper goes to the drum, open the right cover and produce paper jam, now look at drum for image, if on drum isnt image its laser problem...
If the laser shuter is faulty, these means that when you close the right door, the nose on door doesn't lift the laser shuter and so the laser unit cant write on drum.
If the toner crg. pin is faulty, when you insert toner in holder inside the copier, on right side of toner holder is small circle with pin that contacts the toner and gives voltage. You can apply some wd40 to that circle, that goes in and out when you open or close door.
But, probably is laser shuter... to check him you need to dismantle the copier.
Hope that helps!
Jun 23, 2011 | Canon imageCLASS D320 Digital Copier
E100 system error alarm on cannon image class d320
related to fuser unit.try to clear it in service mode
May 25, 2011 | Canon imageCLASS D320 Digital Copier
Copier make squeky sound while making copies...
Whatever you do, DO NOT PUT OIL ANYWHERE ON THE COPIER!!!
The rollers are wearing out; you will have to call Canon to send a tech, or, if you are a qualified Canon Tech or have one in your office, have them look at it and order the necessary parts.
Oct 07, 2009 | Canon imageCLASS D320 Digital Copier
I have a D320 Image Class
dear it is problem copy emage plese setup copy exproser
or printer set up
  1. edit toner save mode off
Jul 09, 2009 | Canon imageCLASS D320 Digital Copier
Replacing toner unit
i have a lot of quantity cartridge . open your copier front door and out the cartridge.Have your side any hp 1200 printer cartridge part no 15 change drum shatter put your old d320 cartridge then solve your problem
please send me success result
Jun 25, 2009 | Canon imageCLASS D320 All-In-One Laser...
Canon Image Class D320 does not copy entire page. New toner has been installed.
Has anyone changed the paper size in the paper tray to another size by accident? Have you tried the manual feed tray? If that copies the whole image then the problem is with the paper size input of the paper tray.
Apr 15, 2009 | Canon imageCLASS D320 Digital Copier
Canon imageCLASS D320 All-In-One Laser Printer Logo
71 people viewed this question
old marine
old marine
