Question about Whirlpool 24 in. ADP5962 Free-standing Dishwasher
Turned on dishwasher and water wouldn't flow in to it.
It's worked fine for the past 5 years, but when I turned it on today, it seemed to go through the cycles, but was not getting any water.
  • GENE2407 Jan 10, 2009
    My dishwasher runs through all the cycles but is not getting any water. I removed the water line and the water is coming out fine. The dishwasher is just not letting any in.
Check your float in the front of machince looks like a round cone must move up and down
Posted on Jan 05, 2009
My 2 year old frigidaire dishwasher is not filling up with water, goes through cycle but no water is coming out, valve is open all the way?
If the water flows then the flow should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor. The water pressure must be good and the spraying must be seen to be good. If there is low pumping or pressure then the spray arms will not turn around to inject with pressure. If so the pump must be checked for clogging.
Click on : Inlet valve
Jan 25, 2013 | Dishwashers
Too much sink water causes flooding from dishwasher.
If you let it sit with vinegar and it worked after for a while that tells me it may be plugged up with grease. Might be worth while trying to clean it out with Drain O a drain cleaner. Make sure its washed clean after. Grease and dirt builds up after a while in all machines. If vinegar works might be worth cleaning more often.
Mar 14, 2017 | Maytag PDB4600 Built-in Dishwasher
Maytag will not start, has power and control panel running fine
Do you ever clean it with a dishwasher cleaning agent and run it on any wash mode?
Mar 08, 2017 | Maytag MDB9600A Jetclean II Built-in...
Glasses in top rack not getting clean anymore.
-Have you changed the dishwasher soap recently? What are you using? Is the powder remaining behind in the soap dispenser?
-Have you removed the filter in the sump area, cleaned it and removed any debris under the filter. (watch out for broken glass that is almost always found in 5 year old dishwashers.)
-You are running water at the sink until it gets hot, but you may still have problems if the heating element has failed. Recommend you check that element. If you can get to the element, check resistence of the heater to see if is has any at all.
If heating element checks out good, the next common problem is a failing wash pump motor.
Mar 30, 2009 | Whirlpool 24 in. DU915QW Built-in...
Noritz tankless water heater/dishwasher not hot enough to clean
You are doing everything you can. Your dishwasher probably isn't drawing enough hot water to activate the unit so opening the faucet and flowing more water will activate the unit. Just try to adjust the flow from the faucet to a point it, plus the draw from the dishwasher, will activate the unit. This will come with trial and error as I am sure you have already experienced. Also, open the dishwasher when it does get filled and check the water temperature. You might have the unit set at a low discharge temperature. Do you have a touchpad to control the water temperature adjustment?
Feb 17, 2009 | Noritz 7.1 Gpm Natural Ng Gas Tankless Hot...
Water over flow on a1267302ew DWU9200ABX Maytag dishwasher
There are three common causes for water leaking from a dishwasher door or float.
1. A problem with the wash system. Check the wash arms for cracks and or splits in the underside that can cause water to jet down and out the front of the unit. Check all water supply tubing in the unit as this can cause the same problem.
2. It is not uncommon for a water inlet valve to fail open and allow too much water into the tank causing a leak.
3. Over sudsing can cause a leak. Make sure fresh dishwasher detergent is used in moderation.
Go here for Maytag Dishwasher Parts: http://www.repairclinic.com/Maytag-Dishwasher-Parts
www.RepairClinic.com
Feb 10, 2009 | Maytag 24 in. MDB5600A Jetclean II...
No water
Don't try running the machine without water, as I suspect you can burn out the pump. Our machine wasn't getting enough water, so we removed the water intake valve and cleaned out a bit of grit that came thro the water line. If you are hooked up to a well system, there is always the chance the valve's screen can be clogged. Do you have excessively hot water? A repairman told me that after about 5 yrs, water intake valves have a rubber part (washer?) that expands with the heat and blocks the water from flowing into the machine. This turned out to be our problem - it's an easy part to replace. As for an almost new machine, this hardly seems possible. Sorry I can't be more help.
Dec 28, 2008 | Dishwashers
KUDS24SEB3 - can't start cycle properly
I just had the same problem. I finally pressed Rinse Only and it started to fill. Without canceling, I depressed Normal, and it seems to be going through the proper cycle now.
Sep 17, 2008 | KitchenAid KUDS24SE Built-in Dishwasher
GE Triton Dishwasher will not drain they water after it's cycle...thoughts?
Peace,
Cut off the power at the breaker for 5 minutes and then turn it on and see if the system resets!
The machine was in your home 3 years , and used for more than that by someone else! I can tell you by the model that its at least 10 years old!
appliances more than 9 years old cost you money to run and fix! Throw it out and do not put good money into bad!
The new ones no matter how inexpensive will wash better and cost you a hell of a lot less to operate. They are so much more energy efficient today that they pay for them selves in a couple of years! With a new machine watch your water and power bill go down!!!
Other wise you need hands on service!
if you got the money do it new!
Bless You!
Sep 02, 2008 | GE 24 in. GSD6660GSS Built-in Dishwasher
Whirlpool 24 in. ADP5962 Free-standing Dishwasher Logo
131 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
