Question about Sony XL-2100U Projector Lamp for KF-42WE610, KF-50WE610, KF-60WE610, KDF-60XBR950, KDF-70XBR95
Sudden picture problems - color distortion and "negative" picture appearance
I've owned my Sony KF-42WE610 for about 3 years now and all of a sudden when I came home and turned on the TV something was wrong with the picture. Certain colors do not appear to be showing up and the picture generally has a pink tone to it. Overall the picture is very snowy and the best way I can descibe the picture is that it has some sort of a "negative" effect. I'm wondering if this is a bulb problem given that I've had the TV for 3 years now, but I want to be sure before going out and buying a new bulb. Thanks, Chad
  • jamespa Apr 18, 2008
    I had a color issue with my Sony TV (KF-42WE610), which has been used for more than 3 years. Recently almost everytime it's turned on, the whole screen shows a green tone with kind of "negative" picture appearance. Sometimes after 20 ~ 30 mintes, the picture became normal. Sometimes it's stayed the same. I've called the Sony support and am waiting for technician to come to check it.
  • Anonymous Jul 16, 2008
    my projector
All of a sudden, my pictures have a pink splotch running vertically across the center of the picture. This is happening more often than not, and I can also see the splotch on the image display when I am...
Some symptoms of a defective CCD include distorted images or abnormal colors, scratchy purple lines, blank or black pictures, and/or black videos with good sound being recorded on the camera's flash card. A problem has been discovered in some of the CCDs used in Panasonic, Fuji, Sony and Canon digital camera and digital video camera products that causes images to appear distorted or not to appear at all. And the says apologize for the considerable inconvenience this represents for your customers. Along with our respectful apology, we would like to advise our customers of the details of this issue and our policy for handling it, which are as follows.
The Malfunction:
Among the CCDs used in the affected products listed above, it has been confirmed that, especially under high-temperature/high-humidity environments, the internal wiring may come undone in some places.
If this defect occurs, the signal is not output from the CCD correctly when in shooting mode, which results in symptoms like the following in captured images. These symptoms can be confirmed on the LCD monitor. The same symptoms may also occur in recorded images:
* images do not appear
* images appear distorted
In order to correct this issue, the repair facility needs to replace the CCD. This is not something you may do on your own; this, isn't a good new, but hope helps to solve it.
Jun 14, 2011 | Panasonic Cameras
Dim and reddish picture SONY lcd kf-50we610
Light Engine/optical block
Encompass Parts Distrubtion 1-800-638-3328
Apr 14, 2010 | Sony Grand WEGA KF50WE610 50" Rear...
KF42WE620 Red picture
I have the same problem that started tonight! It has a red hue that I can't get rid of,I tried all settings etc. Now what.....Any ideas?Thanks
Jun 10, 2008 | Sony XL-2100U Projector Lamp for...
Picture distorted and blurry with color
bad convergence amp ic
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Sony Convergence
http://www.techlore.com/blog/entry/19694/Sony-Convergence-Repair-My-Sony-TV-has-a-distorted-picture-/
http://www.techlore.com/article/19631/Sony-Convergence-Procedure/
Jan 28, 2008 | Mitsubishi WT-46809 46" Rear Projection...
I'm having a problem with the picture tube on my 51 inch sony rear projection TV, 3 years old. All of a sudden the display that reads "Video 1" or "Video 2" is slanted and so is the...
It is very common to have the convergance circuit on these sets go out and cause display distortions. Are the colors separated or is just the picture slanted?
Dec 31, 2007 | Televison & Video
60 " SONY KF60WE610 screen went greenish
Depending on when you bought this TV, this could be the lamp. Does the red light below the green light come on? (That's the lamp light). This light typically comes on around the 3rd year of use for an average individual. I've recently enountered the same problem and will try to replace the lamp myself. Apparently its very simple.
Dec 01, 2007 | Sony XL-2100U Projector Lamp for...
Sony KF-42WE610
Sound but no picture, tv will not turn off. Light goes red but a dim overall blue screen remains and fan is still running.
Nov 15, 2007 | Sony XL-2100U Projector Lamp for...
Distorted picture
dont touch those lenses that is not your problem the problem is your convergance ic are bad replace them and the fuses and this will fix your problem
Sep 15, 2007 | Sony KP-53HS30 53" Rear Projection...
Sony XL-2100U Projector Lamp for KF-42WE610, KF-50WE610, KF-60WE610, KDF-60XBR950, KDF-70XBR95 Logo
253 people viewed this question
Top Sony Office Equipment & Supplies Experts
shaun taylor
Jaime Hernandez
Are you a Sony Office Equipment and Supply Expert? Answer questions, earn points and help others
