I have a front loader and it is not spinning during the spin cycle. The belt is not broken when I took the back off. Is there a repair service that can come out and fix it? I am in Jacksonville, FL
  • 15,935 Answers
It appears your pressure switch or main controller board has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 12, 2010
Frigidare gltf1670as
You likely have a broken or slipped drive belt or broken spring on the belt take up arm on the drum. Appliance Parts.com has a lot of DIY instructions on how to get at the belt and make repairs.
Jan 23, 2018 | Washing Machines
Front loader wont spin
Hello there:
It doesn't spin If your washer won't spin, check these: If the motor is running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it The motor coupler may be broken. Many Whirlpool®-manufactured washers use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. You may need to replace it. A belt may be broken. Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.) The clutch may be worn. If your washer is a GE, it may use a clutch to come up to the proper spin speed. As the clutch wears out, it may prevent the unit from spinning well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician. The drive motor may be defective. Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor. The transmission may not be shifting properly. Older washers produced by Whirlpool® have a transmission with an electro-mechanical shifter. If the shifter becomes even partially defective, the unit may drain the water but not spin. This is a complex system, if your washer has a shifter problem, you may want to hire a qualified appliance repair technician to repair it. The spin bearing or basket drive may be worn or seized. These components allow the inner tub to spin freely inside the outer tub. When this is the problem, you usually hear a loud sound during the spin cycle.
May 15, 2010 | Samsung Washing Machines
Have a front loader kenmore model # 41744052400 washing machine
Ours doesn't even spin. I'm trying to connect with a repair guy.
If we gets our repaired, I'll try to remember to get back to this page.
Good luck with yours.
Apr 07, 2010 | Kenmore Washing Machines
Kenmore front loader Model Number 970-C42162-00 bearing behind drum pully very noisy
Had noise during spin cycle called for repair $79 dollors later its tub assembly its clamp on the back of drum cost $1000 dollors to repair so if you have 747 during spin cycle buy yourself a new machine.
Mar 16, 2010 | Kenmore Elite 45986 Front Load Washer
Loud clanking noise during spin cycle. Will not
If it is a front loader, then remove the rear panel, remove the belt, and soin drum by hand, if it feels rough, or is noisy and rumbling, then the main drum bearings have failed.
This is a major repair.
Feb 01, 2010 | Whirlpool LHW0050PQ Front Load Washer
Do I need a belt? It stopped spinning during rinse cycle.
IT COULD BE A BROKEN BELT , open front panel and take a look at the bottom , you might need a flashlight for more accurate visual , good luck , AJ
Nov 20, 2009 | Video Game Consoles & Games
How to change the belt in my whirlpool washing
It's probably the washer transmission. Belts aren't common anymore & besides it wouldn't work at all if there was a belt broken.
Jun 18, 2009 | Whirlpool Washing Machines
Whirlpool AWM312/3 Front Loader Washing Machine - not spinning
I would recommend getting the service manual for your model as some models have clutches that control spin and others have belts. The service manual would be the best route if you are planning on repairing this yourself. If you would like the service manual let me know and I will post a link to where you can get one emailed to you.
Mar 27, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Indesit wg1130t front loader washing machine
maybe the drive belt is off/broken. Take the back off to check
Oct 09, 2007 | Indesit W 123 Front Load Washer
Whirlpool awm5125/4 washing machine
If the washer seems to complete all of its cycles, but it doesn't spin: 1) Be sure the load of clothes is not lop-sided. If the tub becomes unbalanced, it may spin erratically or not at all. Open the lid after 2 minute gap and reposition the clothes. This automatically resets an off-balance shut-off switch. Close the lid and re-try. 2) Check the lid switch and the tab on the lid that strikes it. If the plastic tab is broken, the washer may halt during the spin cycle. If the switch doesn't click when you press and release it, it's probably broken. If you're experienced at home repair, you can remove the switch, test it, and replace it if needed; otherwise, call an appliance repair service person. 3) The belt may be loose, worn, or broken. If you're fairly handy, tighten or replace the belt, otherwise call an appliance repairperson. Pl post back results
Apr 17, 2007 | Whirlpool AWM5125/1 Front Load Washer
Washing Machines Logo
26 people viewed this question
Top Washing Machines Experts
