Dyi install galaxy5000rs/2000rs remote start - Televison & Video
    Top Expert:
  • Televison & ... Master
  • 14,553 Answers
There are a number of diy forums based on type of vehicle with either photos or even videos----recently after looking around found great one for replacing door hinge pins on a vehicle I have----find someone who has done this on similar vehicle or with similar remote start---l WOULD GOOGLE.
Posted on Nov 05, 2012
Installing remote starter what does run start posisition mean
When testing the polarity of the vehicle's main power wires for remote starter installation; the run position is the vehicle running. The ignition, accessory and battery wires should read 12 volts in the RUN position. This same group of wires should read 12 volts in the ON position. The ignition, starter and battery wires should read 12 volts in the START position. The accessory and battery wires should read 12 volts in the ACC position. The battery wire should read 12 volts with the key OFF.
Oct 18, 2010 | 2000RS-M Remote Starters Manual...
I need the manual for this unit. (I recently had
Click HERE to download user manual copy of Galaxy 2000RS
Hope this will help you.
Thanks.
Dec 12, 2009 | 2000RS-M Remote Starters Manual...
Don't know how it works.
manual for the system can be found at scytek.net
Apr 30, 2009 | Scytek 2000RS Remote Control
The doors lock when I start the car - I don't want that!
the unit can be programmed to lock the doors after starting, to make it leave it alone you have to enter the programming(ignition on, press the valet switch 5 times within 5 seconds, the lights will flash 3 times to signal you have entered programming, then press valet switch 10 times(lock after start setting) within 5 seconds hit the unlock button on the remote (button closest to the side with the other buttons)
then turn off the ignition to save the settings and it should be done
manual for the system is found at scytek.net under the download section
Apr 14, 2009 | Scytek 2000RS Remote Control
Galaxy 2000RS-M not working
sounds like a defective remote, you can find new remotes for the starter on ebay ,
the manual can be downloaded from scytek.net
Dec 13, 2008 | Scytek 2000RS Remote Control
Galaxy 2000 Rs-m
yes, you can connect the tach sense wire from the controller(2000rs) to a fuel injector , and select tach monitor in the programming (see manual, available at scytek.net) and it will automaticcally adjust the starter crank time, other way to go is to install a delay card, sutch as the k 141 multi mode timer, and set it to crank for 3-6 seconds when triggered
May 26, 2008 | Scytek 2000RS-M Remote Control
Car Alarm Instructions
go to scytek.com you can download there
May 15, 2008 | Scytek 2000RS Remote Control
Galaxy 2100RS
if this vehicle has a white wire in the ignition harness it needs powered by the ignition out of the remote start if your remote start doesnt have a second ignition use relay not poering this wire will ruin your transmission the white wire must have power this should solve your problem dont use remote start until you fix this problem or it will cost alot of money.
Mar 13, 2008 | Scytek 2000RS Remote Control
Auto start
did you install yourself and what module did you use for the doorlocks or did you have it installed at a shop
Sep 26, 2007 | Scytek 2000RS Remote Control
Televison & Video Logo
23 people viewed this question
Top Televison & Video Experts
Electro Med Services...
