Question about Kyocera KM-1510 Copier
I have a kyocera 1810 copier. it has a error a 400
  • ebunny90 Jan 10, 2009
    that didn't work what else could it be
  • line_artist Apr 08, 2009
    Just got a free Kyocera 1810 with error code "A400". After looking through a few forums, found that it may be a faulty "laser motor". I've opened up the back of the copier and located the main motor for the scanner tray "looks like a rubber wheel. The wheel spins and moves the tray, the scanner light is also working. On warm up if the tray is out of default position it returns. So it seems to not be the motor since everything is moving correctly.
    The copier stops and displays the A400 after the scanner makes a pass... so what else should I be looking for? and are there any tech diagrams out there with part numbers and assembly?
    thanks
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 126 Answers
Does this machine have an ADF ( document feeder) on it? If so, check the connect cable from the document feeder to the machine. Also check the connectors from the scanner PWB to the document driver PWB. ( these are the 2 boards that do the communicating , the machine and the document feeder). If this machine does not have a ADF the check the side covers/ doors and make sure that they are closed securely.
Posted on Jan 05, 2009
What happen when kyocera KM-1505 is bringing error code J98
There's probably a time piece of paper or something blocking a sensor or pressing down on an actuator or something
try checking this then do a good clean of the unit.
Jan 16, 2015 | Kyocera Mita Km 1810 1510 1505 Copier Drum...
Kyocera 1810 A400 error. What is wrong and how do I fix it?
This error refers to a bad laser unit. The laser is what "etches" your image onto the drum as it transfers to the paper.
This is the cheapest replacement unit I have found for you.
Here
Aug 23, 2011 | Kyocera KM-1510 Copier
Kyocera model km-1810 laser copier error code a400
dependds on what the problem is and $ of repair ??????????????
Oct 06, 2008 | Kyocera KM-1510 Copier
Copystar CS-1810 Error Code
I'm sorry, Copystar is not a brand I am familiar with.
Be blessed.
Mar 19, 2008 | Copystar CS-1810 Copier
Kyocera mita KM 1810
Hi, sounds like Laser Unit is defective :(
Call service, or try to clean laser unit by Yourself
Regards.
Apr 25, 2007 | Kyocera Mita KMR-1810P Laser Printer
Kyocera KM-1510 Copier Logo
244 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
Chris Schutte
Henry Gertcher
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
