Question about Water Heaters
Whole house water filtration system Model WHKF-DWHV in filter position when purchased unable to turn to off position why?
FreshWaterSy
  • 13 Answers
SOURCE: I was changing my filter in the ge filtration
The red button is a pressure relieve valve. If the system is leaking from the valve, try pushing the valve up from the underside of the cap where the valve is located. If this does not work the housing needs to be replaced. You do not have to replace this with a name brand like GE. All you need to do is make sure the housing that you are purchasing is the same size.
Example of Replacement Filter Housing: http://www.freshwatersystems.com/c-107-filter-housings.aspx
FreshWaterSystems.com: The Water Super Store: 1-877-335-3339
Posted on Apr 28, 2009
co7196
  • 3433 Answers
before putting cover on, chk the button to make sure it isn't staying depressed and see what the button is doing when depressed. The cover may have to be in a certain position. with the cover in place, gently rotate untill button pops up
Posted on May 07, 2009
  • 832 Answers
SOURCE: The red pressure relief button on my GE Smartwater
To replace the filter cartridge. Do the following;
1. Assuming that you have a pump in your water filter
system, shut it off.
2 Close the intake valve before your filter system.
3.To relieve the pressure, open the faucet after your
filter system. Any of your faucet for that matter.
4.Once the pressure is relieved, you can of course
replace the the filter cartridge.
Posted on Nov 27, 2009
Testimonial: "That worked, thank you! After I removed the canister I inspected the pressure relief valve and couldn't see anything wrong with it. Thanks again."
heatman101
  • 43501 Answers
SOURCE: i have a whole house
I would shop around for a different water filter supplier...there is no reason ofr that happening unless you are not changing the filters regularly...like once a month...
most filters are a standard size and it should be easy to get them somewhere else...
heatman101
Posted on Aug 13, 2010
h2oservices
  • 306 Answers
SOURCE: GE Heavy Duty Household Filtration System
It sounds like there is quite a bit of sediment in the water. The filter you are using may be a very fine micron 5-10. Try using a 30-50 micron filter.
RJ
Posted on May 17, 2011
Purchasing a water filtration system for a house
This is very location dependant. Different parts of the country have different needs. I suggest that you contact 3-4 companies and have them submit proposals. They should take a sample of your water, analize it, and then make a reccomendation based on your needs.
Apr 15, 2014 | Water Heaters
Ge smartwater wholehouse waterfilter main housing failed flooded house
Why did it fail? How did it fail? Was it the plumbing that failed? Replace it with a Pentair filter housing, 10" housing, 20" housing or Big Blue housing and make sure it is plumbed in properly. It is very unusual for a filter housing to fail unless it freezes up.
RJ
Apr 18, 2011 | General Electric GE SmartWater Household...
Canisters on my ge smart water filtration system gxsv10c model are stuck tight. How do i get them open
Make sure the water is turned off to system. Open the faucet to system to drain any water and keep the faucet turned on to keep pressure off filter housings.
1.Use the wrench to take housings off.
2. If they still won't budge take a small 2x4 block of wood and hammer, set the block of wood on the RIB for the housing and tap with hammer.
3. Change the o-rings in both housings, lubricate with silicone lube and lubricate the threads on housings with silicone also.
3. Rinse housings with small amount of bleach and clean thoroughly.
4. Replace filters and housings.
5. IMPORTANT: Only tighten housings by hand. NEVER tighten housings with wrench.
RJ
Nov 10, 2010 | General Electric GE SmartWater Household...
I have a whole house water filter that uses a 30 micron FXHSC filter. the last two filters have come apart and sent fiber through the water lines in the house
heatman101
Aug 13, 2010 | General Electric GE SmartWater Household...
Cold water pipe is leeking...place a bucket under it but fills up fast...plumber will be her tomorrow what to do in the meantime
Find valve ahead of the filter and turn it off. If you can't find that turn off all the water in the house.
Jul 21, 2010 | General Electric GE SmartWater Household...
The red pressure relief button on my GE Smartwater GXWH35F whole house water filter system doesn't seem to be relieving pressure. As a result I cannot turn the filter cartridge in order to replace the...
Nov 26, 2009 | General Electric GE SmartWater Household...
I was changing my filter in the ge filtration system, and it says to turn off the water and press the red button. Then it says to unscrew the filter take the old one out and clean the filtrstion system...
Apr 27, 2009 | General Electric GE SmartWater Household...
Apr 22, 2009 | General Electric GE SmartWater Household...
Water Heaters Logo
322 people viewed this question
Top Water Heaters Experts
Paul Carew
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
