Question about Home
I need instructions for using the rapid fit stopper to seal the tub. It doesn't appear to screw down. And if I push it down, it just pops back up. Is there a trick? I can remove it by unscrewing it. But I can't figure out how to use it.
  • 122 Answers
SOURCE: my tub is stopped up
you any thing that can fit the surface of the stopper and provide a good suction
Posted on Jun 05, 2009
  • 297 Answers
SOURCE: Slow water drain from Royal whirlpool tub. How to
under the decorative knob there is a screw,this is what holds the stopper in place.if not it should just unscrew.
Posted on Jul 30, 2009
  • 569 Answers
SOURCE: the tub stopper will not stay seal. It is a push
Pull out the stopper and adjust the threaded screw so that it does not protude so far. This means screwing it up (after loosening the locknut) into the stopper.
Posted on Mar 05, 2010
  • 81 Answers
SOURCE: i stopper on a garden
In my part of the country, the type of drain you refer to is commonly called a tip-toe drain because you can use your toes to open and close the drain. Their locking ability diminishes over time and use, and eventually won't lock at all. They cannot be repaired, and must be replaced. You must remove the one you have to get the correct replacement because there are variations in the thread diameter at the bottom of the stopper.
You will need to use pliers large enough to grab around the white plastic underneath the top of the stopper that appears to disappear into the drain. Once you have the white plastic shaft secured with pliers, grab the very top (the chrome part) and twist it counterclockwise to remove it. Once that is off you will see a round piece of brass that looks like the top of a very large screw. IT IS! Using a stantard screw driver, again turn counterclockwise to finish removing the rest of the stopper.
A good hardware store should have a replacement for you. Be sure to match up the thread diameter at the bottom of the stopper.
To reinstall, you can reverse the steps or simply thread the complete assembly into place.
Posted on Aug 08, 2010
SOURCE: How do I remove the
Does the tub have a lever to stop the drain below the spigot ?
Posted on Oct 28, 2010
I have a brand new Delta push down stopper for t14320 and it won't stay down to hold water in tub. What do I need to do?
pus down and unscrew. There is an adjustment screw on bottom side. Adjust, screw back in.
Oct 03, 2015 | Delta Home
Fridge washer GLWS1349AS0, have inner tub out, trunion lifted, not off yet due to slight rust. How do I change spin bearing and tub seal? thanks.
To remove the trunion totally reattach the inner tub to it and twist the inner tub,with the tub attached it gives you much more leverage to twist and pull the trunion off. After its off pull the small brass ring with the O seal in it up the transmission shaft and pop the tub seal off. To replace tub bearing remove the bolts on the side of the side of the outer tub off from the tub support and pull tub off of trans. shaft. to remove bearing flip tub upside down and remove the 2 screws from the tabs on bearing and turn tub back right side up and use a screwdriver on the top of bearing and knock it out of outer tub,push new bearing in by hand most of the way,being sure the tabs on bearing is lined up w/notches on tub and use old bearing placed on top of new one and drive it down all the way,reinstall screws into tabs. All the surface rust should be sanded off of trans shaft. Re install outer tub and secure with the bolts into tub support. push main tub seal into flange with normal palm pressure,install new brass ring and MAKE SURE O RING DOESNT POP OUT OF IT ( a little dawn,palmolive joy liquid dishwashing soap around inner part of o ring inside of brass ring will help it slip on easily) I use the old brass ring and press it over new brass ring to assist in o ring not popping out,once new brass ring is inserted ok and oring in place remove and discard old brass ring. Reistall trunion and inner tub ECT ECT ECT
Gene
Aug 12, 2011 | Frigidaire GLWS1349A Top Load Washer
I can not close my bath tub drain. the plunger is all internal and wont come out either. I tried a coat hanger to push it down. no go.
on most tubs the stopper is made to come out! does the stopper have 2 screws at the stopper lever. if it does just remove these screws and pull the stopper out slowly. when putting in a new one. have the same length as the old one, then slide it back in the drain fairly slow until it goes all the way in. replace screws and try it! good-day!
Aug 05, 2011 | Kohler Bath Drain KOH-K-7104
When the washer goes unto spin cycle, it makes a loud roaring noise and is leaking from the bottom
It sounds like the tub seal is leaking, allowing water to leak out of the tub and damage the drum bearing. Unfortunately you need specialized tools to replace the seal and bearing, so you may have to get a maytag service agent in to look at it. If you're handy with a welder you may be able to make up a tool yourself, it basically consists of a flat hexagon with tabs on the inside to fit the drum nut, and some handles on it. You'll need to remove the front panel and top panel. Then remove the cap around the top of the tub. The agitator is held on by a small screw near the base of the agitator, loosening it will allow you to remove it. Now you can see the tub nut, this is reverse threaded, so it's loosened clockwise. Then you can lift out the drum. Next on the shaft is the top part of the mechanical seal. Remove the grub screw out the side. Now you'll need the same tool you used for the tub nut to undo the seal, rotating in the same direction. Remove the outer tub by undoing the 3 bolts that fix it to the stays, and disconnect the level tube and drain hose. From here you should have printed instructions that come with the new parts to replace the seal and bearing. Please feel free to get back to me if you have any further questions.
Jul 28, 2011 | Maytag Washing Machines
I stopper on a garden tub with a delta faucet. The stopper pushes down and locks to stop water. It takes a few tries pushing it down to get it to stop and hold water. What is the best way to fix it or...
Aug 07, 2010 | Home
I have akohler bath drain that seals/drains simply by pushing down on the gasketed spring-loaded chrome stopper. The drain is clogged with hair but I can not figure out how to remove it and snake the...
Toe tap stoppers remove by just gripping the stopper and unscrewing it. Once the stopper has been removed the hair will be usually caught on the crossbar underneath the stopper where it can be removed with needlenose pliers.
Spring type stoppers for drains are just about as notorious for being hair catchers. Once again there is nothing to stop the hair from leaving the tub.
May 21, 2010 | Plumbing
The tub stopper will not stay seal. It is a push type system
Mar 05, 2010 | Delta Home
How do I change my cabin filter in a 2009 honda fit
pull down your glovebox(remove the two rubber stoppers on either side of the glovebox) just push on the inside of the plastic that the rubber stoppers are attached to. the stoppers pop out and the glovebox will swing down. behind the glovebox in teh new opening there is a tray snapped into the blower box... dbf4936.jpg
remove the tray with the old filter. insert the new filter and put the glovebox back.
Feb 28, 2010 | 2009 Honda Fit
Direct push-type Kohler bath drain won't drain.
Spring loaded chrome stopper will not stay down to fill tub with water.
Jan 12, 2010 | Kohler Plumbing
We have an American Standard lifetime whirlpool tub with the pop up drain (white). However, the pop up drain plug has always been tempermental but now it no longer wants to stay down.
Chances are that the drain assembly was not part of the tub but a 'generic' plumbing part. Is this pop up drain the type that you push down and it clicks closed and push down and then it pops up? It unscrews from the drain fitting and you can get a replacement at a big box store. A better pop up replacement is one called a Rapid-fit. It drains faster.
May 12, 2009 | American Standard Evolution 1599.205.020...
Home Logo
1,568 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
