Question about Philips 150S4FB 15" LCD Monitor
Philips 150s4 disassemble opening of case
How do i open the plastic housing to gain access to this philips 150s4 flat screen i have undone all the screws but there seem to be a couple of clips i dont know how to access on the two sides of the plastic housing around screen
4 Suggested Answers
  • 556 Answers
SOURCE: monitor philips 150s4
r 3106 330k r 3117 47ohm
Posted on Oct 07, 2007
SOURCE: Disassembly of case
This is for a Viewsonic VX900. The bottom bezel with the button unclips.Unplug the connector, and put aside. ( Dont pull on the wires) Then there are two screws that are removed, and the grey frame around the monitor comes off next. Then remove the 4 bottom screws, and the two top tiny screws and the LCD comes away from the back. Remove the shielding, and replace your components. Good Luck !!
Posted on Oct 27, 2007
freetek
  • 5568 Answers
SOURCE: Philips 150S4 15" LCD Monitor Problem
If it just fails to turn on, the main power supply is probably at fault and without some technical background and a couple of test instruments, you will not likely be able to do the repair yourself.
Modern power supplies are designed to shut down if the current drawn exceeds the design level, which indicates that something the supply services or the supply itself has died.
If you are adventurous, you might pull the plug on the set, allow the set to sit overnight, gain access to the innards, and with good light, inspect any boards inside.
If you see one that has few ICs but many more larger discrete parts, this will be the power supply.
Again, before touching anything inside, especially on that board, allow at least several hours to be safe since the larger capacitors can hold a painful voltage charge for some hours.
You are looking for components called electrolytic capacitors that are almost always cylindrical and mostly installed upright at 90 degrees to the board with leads passing through to the solder side.
This same type of component in smaller dimensions is still used in a horizontal package with leads bent down and passing though holes to the solder side.
The latter are becoming more rare since they don't lend themselves well to robot assembly.
Many failed caps (not all) will show signs of pregnancy when they fail, bulging unnaturally at the top when compared with others. Now and then, there may be traces of a crystalline deposit around the end where the seal failed from internal pressure.
These will have values listed on them in uFd & VDC and sometimes, a plus/minus number lying about the precision.
Some also have a date code (rarer) that will look like four digits:
2403 = 24th week of 2003
Most electronics suppliers have a stock of the various values but if they have a date code at all, try to get only those made before 2002 or after 2006.
The larger caps will probably be OK since the failure is likely related to functions other than brute-force filtering. A pretty good 'rule of thumb' is to replace any caps you see bulging of any value but especially those that are 100 uFd or less.
If you see signs of overheating such as discoloration of the board material, it may not be repairable but if you can find a part number on the board, you might be able to buy the power supply and install it yourself.
If there are no signs of heat damage to the board, there may be companies offering to repair it as a subassembly instead of repairing the whole set which could be much more expensive.
If you choose to replace it or have it done, the power supply still may not be at fault since most are capable of switching on and off if a downstream problem is causing an overload.
If you choose to replace failed caps yourself, you will need a quality soldering iron with a small, preferably iron-plated tip, rosin core solder and a sponge which when wetted is used to frequently wipe oxidized solder from the tip this should be kept bright and clean and fresh tinning will keep it that way.
You should also buy some solder 'wick' with the iron; this is used to place on the solder you wish to remove and then heated with the iron. Properly used, the wick will absorb nearly all of the solder from the lands from which you wish to remove a component.
Posted on Oct 12, 2008
How to open toshiba satellite a75 to get to power connector
Hi.
Click on the video link below for instructions on how to disassemble the A75, you may have to watch the video a couple of times or pause the video.
Regards.
Feb 04, 2013 | Toshiba Satellite A75-S211 Notebook
Tip
Samsung SGH-X150 disassembly, take apart.
How to take apart Samsung SGH-X150 Black Cell phone:
Time Required: 10 to 15 minutes.
Tools needed: Precision tools, Small philips screwdriver, Case opening tool or a plastic stick, or your fingernails.
Difficulty: Easy
Step 1. Remove the back cover, battery and sim card.
Step 2. Are you replacing the screen? Or are you looking into the keys or the mainboard?
If you wish to get to the display Go to step 3.
If you wish to get to the keys and the mainboard Go to step 4.
Getting to the display.
Step 3.
To replace the display, unscrew two Philips screws from the bottom of the display, they are under two soft tabs that you have to remove from on top of them.
Step 3.1. Use your fingernails or case opening tool to open the display cover.
Begin from the back and work towards the top, open the back and the sides, do not force open the front its held in place from there and you need to pull the plastic cover off looking at the picture below to the left
Step 3.2. After the cover is off, you get to the back of the display, on the top you have a few speakers etc.
Step 3.3. From the bottom release the connector by carefully pulling the board upwards.
Step 3.4. From the top, use a flat screwdriver to get the speakers out of their slots so the circuit board with the display comes off.
Step 3.5. The display is now free from the cover, you can remove it from the case.
Getting to the mainboard and keys.
Step 4. With the back cover, battery and sim card out. On the back of the phone, there 4 Philips screws. Marked with red dots.
Step 4.1. With the 4 small screws out, start using the case opener tool or your fingernails to release the plastic casing from the back of the phone. It is held in place similarly as the top of the phone in step 3. Begin from the sides and the bottom of the phone, the top is held in place and won't open until the sides and the bottom are lose, then you can disconnect the top part.
Step 4.2. As you release the back cover, on the side the up and down plastic key drops out remember to replace it properly when you assemble the phone.
Step 4.3. Disconnect the display cable, the mainboard is held in place by plastic clips on the top, carefully release the mainboard, you may break off a clip or two from the case, if that happens, no worries. The screws will still hold the casing together. the area is again marked in red.
By now you should have the phone completely disassembled / taken apart.
We are done.
Assemble in reverse order. Total 6 screws in this phone, 2 on display 4 on case. Held in place mostly by plastic clips.
Thank you for reading, I hope this has helped you.
-Ekse
on Mar 14, 2010 | Samsung SGH-X150 Cellular Phone
Amana dishwasher handle
Push the screw driver against the center spring mechanism.
May 14, 2012 | Amana Dishwashers
My gateway M-1634u notebook screen backlight is not functioning are there any repair schematics available?
No, all that's available are disassembly diagrams.Looks like you have a bad "inverter'. Thisis a small circuit board (about 1/2inch by 4 inches) located inside the screens plastic case in the area just above the center of your keyboard. It has two small cables connected to it(one on each end).You'll have to take your screen off the laptop by the hinges and then open the screens plastic case with a small screwdriver.
Opening the laptop enough to get to the screens hinges is usually a job done by experience,since every laptop has a slightly different hinge mechanism and procedure for accessing them.
Apr 06, 2011 | Gateway M-1634U (LX.W090X.001) PC Notebook
Attempting to remove the back or split the case from screen on a Polaroid TLX-01911C LCD TV. Purpose is to gain access to power supply. There are only two visible screws at the bottom and the stand...
it likely has plastic clips that go all the way around the outside of the housing, just gently pry it with a flat head until you see whats holding it, just be careful not to break the plastic, you can break a couple clips with uot a big problem, just be careful
Sep 18, 2010 | Polaroid TLX-01911C LCD TV
I am trying to open the outer casing of the vacuum
There is a push in type flat plastic switch trim cover over the metal housing surrounding the switch.. You must unplug the cord, gently pry around the trim cover and you will find a screw, an irregular one underneath holding the switch in place. DO NOT OVERTIGHTEN when reinstalling this one or you will crack the switch.
Once removed the rear housing will come off. Then you will see several new philips round head screws holding the front housing onto the vac.With all screws removed the housing should open easily but there may be dirty film inside holding the halves together. The fan shaft will unscrew revealing the fan, a spacer behind and perhaps two different spacer washers. Install the new fan hand tight, washers and spacers in same order...
Good effort figuring this one out. Please post back with results.
Oct 29, 2009 | Vacuums
How do I Open / disassemble LG Flatron
Remove all the screws from the screen that you can, check for screws under all soft objects and labels, after all screws are removed, use a flat screwdriver or a case opener tool to start snapping the display cover open, it is hold in place with plastic clips, these will clip open but be carefull not to break any.
Sep 11, 2009 | LG Flatron L1750S 17" LCD Monitor
My headlight is out and I want to get the bulb out-how do I get to the hedlight?
I actually have a Acura CL 3.0 and changed the headlights on it 2 weeks ago. The first thing you do after propping the hood is start loosening the plastic fasteners (they should pop off). Once you have them all undone you can remove the entire plastic cover piece.
From there you can look to where the back of the headlights would be and see wires in a clip going into the headlight. There should be a little notch that you need to get the wire removed from the bulb. Simply twist and the old bulb comes out and you just follow the same steps backwards to get the new bulb in.
NOTE: There is a gel you can place on the inside of the plastic adapter to help your bulb from overheating and frying any wires/bulbs.
Sep 10, 2009 | 2003 Acura 3.2CL
How do i disassemble apple ipod housing model a1236
If its the square one then you need to get a plastic ipod case opener (So you don't wreck it) and pry the case open, Then the rest is either a very small phillips screwdriver or a stupidly tiny star driver.
Apr 21, 2009 | Apple iPod nano
CD tray not opening on Denon RCD-M35DAB
there are tthere are two transparent plastic switches under the tray
there (a gray plastic piece, intcasing the loading motor is nonot rotated enough, not allowing the necessry pressure on the switch.
you must in either case disassemble the reading module comprising the tray, otics annd spindle, so you gain access to the underside of it, from ence coperatrepositioning the tray or the lrotating the trigger\eloading motor.
May 14, 2008 | Audio Players & Recorders
Philips 150S4FB 15" LCD Monitor Logo
264 people viewed this question
Top Philips Computers & Internet Experts
Computer Repairing
Computer Repairing
micky dee
Are you a Philips Computer and Internet Expert? Answer questions, earn points and help others
